Topic: Programming issue on Mac (solved) (Read 992 times) previous topic - next topic
Volta500
Jan 03, 2013, 11:50 am Last Edit: Jan 03, 2013, 06:33 pm by Volta500 Reason: 1
Hello,
I have a serious issue with trying to program my Arduino on my MacBook Pro running OSX 10.8.2.
This is the verbose output trying to program the built-in blink example:
Code: [Select]
Binaire sketch-grootte: 890 bytes (van een 7.680-byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega8 -carduino -P/dev/tty.usbmodemfa141 -b115200 -D -Uflash:w:/var/folders/tw/xv4jt_md7p76rtn173stmx040000gn/T/build3330199445503663606.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
        User configuration file is "/Users/Pelle/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : /dev/tty.usbmodemfa141
        Using Programmer              : arduino
        Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
        AVR Part                      : ATMEGA8
        Chip Erase delay              : 10000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
          flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
          lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
          lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
          calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : Arduino
        Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
        Hardware Version: 3
        Firmware Version: 4.4
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
        Vtarget         : 0.3 V
        Varef           : 0.3 V
        Oscillator      : 28.800 kHz
        SCK period      : 3.3 us
avrdude: Send: B [42] p [70] . [00] . [00] . [01] . [01] . [01] . [01] . [02] . [ff] . [00] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00]   [20] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: Expected signature for ATMEGA8 is 1E 93 07
        Double check chip, or use -F to override this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
Loopback test was sucessfull.
I tried programming it from a windows computer and every programe programmed just fine so i know it is a software issue on my mac.
Reinstalling Arduino IDE didn't help, countless reboots didn't work, plugging the arduino in and out didn't help.
I am in quite a loss here to what to do. This mac is my main machine so I would really like to solve this problem.
If you need more information, just ask
Thank you.
Volta500
Weird thing is that the output differs from time to time. Here is my last verbose output: (without compiling because of the 9500 characters limit)
This is the error I get the most
Code: [Select]
         AVR Part                      : ATMEGA8
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
avrdude: ser_recv(): programmer is not responding
Nick Gammon
Code: [Select]
AVR Part                      : ATMEGA8
What sort of Arduino do you have?
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Volta500
It is an Arduino Uno, but I have just solved the issue.
What I did was do a search for Arduino and delete everything except my own projects.
After that I reinstalled the IDE and everything is back to normal.
There must have been some error in a configuration file that was remade in the reinstall.
joachimsw
Could you describe a bit more what you removed?
I'm having similar issues interfacing Due in OSX 10.8.2. I can get it to work in Windows 8 running in Parallels, see:
http://arduino.cc/forum/index.php/topic,142550.0.html
James C4S
Your problem is entirely unrelated to this one.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
