Topic: My Self Balancing robot -Mini Bot Full documentation (Read 14792 times) previous topic - next topic
arkadiraf
Jan 17, 2013, 03:25 pm Last Edit: Jan 17, 2013, 03:42 pm by arkadiraf Reason: 1
Attached the full documentation of my small self balancing robot with codes included.
Share, Build and have fun.
Will be glad for feedback.
Arkadi.
// Links to some video`s of the robot:
http://www.youtube.com/watch?v=K2tlKteO_ZU
http://www.youtube.com/watch?v=GIyY5aSZYEo&feature=youtu.be
Update:
added a link to the file if the download fails
https://docs.google.com/file/d/0B48zmIh9CjavVktuVTJscjg3YWs/edit
strykeroz
Hi
Love it :)   I'm getting a Error 503 Service Unavailable on both the links below your video though?
Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
codlink
Hi
Geoff
The whole site is like that.  Has been almost a week with the attachments of the site not working.
//LiNK
arkadiraf
added a link to the documentation, hope it works
fungus
I managed to download the PDF from google docs.
Cool project...and thanks for taking the time to document it.
Can it spin around on two wheels?
It would be neat if the robot could stand up all by itself (4->2 wheels).
strykeroz
Perfect now, thanks !
And thanks again for documenting this so well.
Cheers ! Geoff
arkadiraf
There are two video`s the in the second i show a control from an android and there its rotates on two and can stand up by approaching a wall.
zzz2b2
Great project and write up! I have started building a 2 wheel version using the arduino minipro, H bridge and 6050.
The motors start turning when the bot is upright so I have something mounted wrong.
These are the 6050 values I get when bot is upright , using this code: accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
   484ax    -16888ay    -1644az    -410gx    -155gy    -254gz
  I disabled the lines using 'top motor and motor2'.
Question: how did you mount the 6050? My 6050 is perpendicular to the axis of rotation of the wheels, whith Y pointing down when the bot is upright. Thanks.
sudhakar.yg
Thank you very much Arkadi!!
Your project helped my long time dream come true. I have been able to build a SBR using the info you have given here.
I still need to do fine tuning. Will post the video soon I am done.
Thank you very much for sharing the info!!
apfelstumpf
#9
May 20, 2015, 09:08 pm Last Edit: Jun 13, 2015, 10:09 am by apfelstumpf
problem solved thanks
vittoriofatih
hi i have a question.Now i have to measure values via serialmonitor.I get really stupid numbers around 2 and smaller than it,after i measure the angles,how should i put it on loop function.(I use 12C and MPU examples directly and my own motor function)
