Loading...
Pages: [1]   Go Down
Author Topic: Temperature Probe  (Read 379 times)
(USA)
Offline Offline
Full Member
View Profile
Hello,
I just bought a temperature probe and I need some help. Does anybody know if it is a 5v or 3.3v sensor and which wire is positive and which wire do I attach into my analog port on the Arduino. Both of the wires are black, but one as a grey stripe on it.
Thanks,
Drew
http://media.digikey.com/pdf/Data%20Sheets/U.S.Sensors/USP10979.pdf
Logged
Offline Offline
Edison Member
View Profile
One of the wires is perhaps shielded against electric noise.
But I don't know which one.
It is a NTC resistor of 10k at 25 degrees Celsius, maximum 105 degrees Celsius.
You have to find some examples how to connect it, and how to calculate the temperature.
Logged
(USA)
Offline Offline
Full Member
View Profile
I have looked all over for examples and I can't find any. I can calculate the temperature by using a thermometer and comparing what the probe values are vs the temperature, but I don't know how to connect the probe to the Arduino.
Any ideas?
Thanks,
Drew
« Last Edit: January 20, 2013, 04:32:44 pm by Drew Davis » Logged
Offline Offline
Sr. Member
The last thing you did is where you should start looking.
View Profile
You can try this schematic.
The R5 resistor can be adjusted to get the voltage you want at the temperature you want.
Logged
Offline Offline
Edison Member
View Profile
Some add a capacitor to eliminate noise.
Simple example:
http://playground.arduino.cc//Main/Kty81-110
Extended library:
http://playground.arduino.cc//ComponentLib/Thermistor4
Logged
(USA)
Offline Offline
Full Member
View Profile
Wow! This is a lot more complicated then I thought.
LarryD: On your schematic what is "Arduino 0v" and "RT1"? (I'v never really used a schematic before)
Krodal: Where would I put the capacitor in LarryD's schematic?
Also I don't have an R5 resistor and I would like to get this working ASAP. Could I use a 10K Ohm resistor for now?
Thanks!!!
Logged
Offline Offline
Sr. Member
View Profile
Quote
This is the GND pin, found on the Power header on your Arduino board
Put a .1uF capacitor Across the Thermistor (RT1, your temperature sensor)
Quote
R5 is 10K
Logged
(USA)
Offline Offline
Full Member
View Profile
Thanks!!! I will try it out and post the results.
Logged
(USA)
Offline Offline
Full Member
View Profile
It works perfect! I did not need to use the capacitor.
Thanks for all the help!!!
Logged
Offline Offline
Sr. Member
View Profile
The capacitor is used to protect the analog input from transient noisy problems.
This may result from long cables in a electrical noisy environment.
If you are just doing a test you don't need the capacitor.
Logged
(USA)
Offline Offline
Full Member
View Profile
Thanks! I will put a capacitor in when I put the probe into my project.
« Last Edit: January 21, 2013, 12:01:39 pm by Drew Davis » Logged
Pages: [1]   Go Up
Print
Jump to:
