Loading...
Pages: [1] 2   Go Down
Author Topic: need help to modify this push button code  (Read 520 times)
Offline Offline
Jr. Member
View Profile
hi. hello everyone. i want to ask your help how i'm gonna modify this code so that the same push button can be use twice. the current code only allow me to use the same push button once. i want to modify it to so that it fulfill the condition as in the picture attached here.
Code:
#include <LiquidCrystal.h>
  The circuit:
 * LCD RS pin to digital pin 8
 * LCD Enable pin to digital pin 9
 * LCD D4 pin to digital pin 4
 * LCD D5 pin to digital pin 5
 * LCD D6 pin to digital pin 6
 * LCD D7 pin to digital pin 7
 * LCD R/W pin to ground
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int analogPin = A0;
int adc_key_old;
int adc_key_in;
int NUM_KEYS = 5;
int key=-1;
int adc_key_val[5] ={30, 150, 360, 535, 760};
* PRIVATE FUNCTION: setup()
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Define of I/O pin as Input or Output
// The setup() method runs once, when the sketch starts
void setup ()
  // initialize serial:
  Serial.begin(57600);
  lcd.begin(16, 2);                         // set the lcd dimension
  lcd.print("  CYTRON TECH.");              // display the text
  lcd.setCursor(0,1);                       // set lcd.setCursor (column,row)
  lcd.print(" Eg. LCD Shield");
  delay(1500);                              // delay for 3000ms
  lcd.clear();
  adc_key_old = analogRead(analogPin);      // store the unpress key value
* PRIVATE FUNCTION: loop()
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* Non-Stop looping
  adc_key_in = analogRead(analogPin);     // read ADC value
  adc_key_in = get_key(adc_key_in);
  if (adc_key_in==0)        // Right button menu
    lcd.print("Menu 1");
  else if (adc_key_in==1)   // Up button menu
    lcd.print("Menu 2");
  else if (adc_key_in==2)  // Down button menu
    lcd.print("Menu 3");
  else if (adc_key_in==3)  // Left button menu
    lcd.print("Menu 4");
  else if (adc_key_in==4)  // Select button menu
    lcd.print("Menu 5");
* PRIVATE FUNCTION: get_key
* PARAMETERS:
* ~ integer
* RETURN:
* ~ unsigned int input
* DESCRIPTIONS:
* convert the ADC value to number between 0 to 4
int get_key(unsigned int input)
  int k;
    for (k = 0; k < NUM_KEYS; k++)
      if (input < adc_key_val[k])
      return k;
  if (k >= NUM_KEYS)
    k = -1;     // No valid key pressed
    return k;
« Last Edit: January 18, 2013, 03:01:06 am by mr_hacker90 » Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Your sample uses 5 push button using on analog input and 5 different resistor values. What help do you exactly need with this?
Excuse me if I'm wrong, but this sounds a bit like "let the forum do my school work for me". We help you do it but we don't do it for you.
Logged
Offline Offline
Jr. Member
View Profile
i know. it maybe sound like that. but, this is not a homework actually. i'm juz graduated. i'm juz want to see the pattern. how the programming. perhaps, later maybe with the example, i can modify it to change the program from dual menu to triple menu. that's the way i learn the program. i only learned one semester subject programming. only the basic. and it is not enough. i'm not hoping u guys to do it. perhaps juz give a few hints how to modify the coding. that's all.
Logged
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
At the moment the code simply reads the buttons and prints a message to indicate which one has been pressed.  The program has no way of knowing what level of the menu is currently on the screen and what action to take when a button is pressed.  What you need to do is implement a state machine with a variable, lets call it state, whose value is changed when a button is pressed so that next time a button is pressed the appropriate action for the current state is taken.
So, in your example you could start with state set to 1 and display the top level menu.  If button 1 is pressed you update state to 2 and display the Add Fingerprint menu and wait for a button press.  When a button is pressed you check the current state and respond appropriately for that button in that state.  For instance, suppose button 5 is designated to exit from the Add Fingerprint menu and it is pressed.  You would update state to 1 and display the top level menu ready for another menu item to be selected.
Logged
Offline Offline
Jr. Member
View Profile
understood. now i have a clear image on that. buttonState. so, the buttonState will be a variable how many time it been push. Thank you very much. i'll give a try on that. thank you for the hint.
Logged
East Anglia (UK)
Offline Offline
Edison Member
View Profile
No !
The number of times the button has been pressed is not relevant.  buttonState simply tells the program whether a button is currently pressed or not.  The state that I am talking about indicates which level of the menu you are in so that button presses can be interpreted and acted on appropriately .  Button 1 will mean different things depending on the current state.  To expand on my example, if you are at the top level of the menu and press button 2 this might take you to a menu allowing you to delete fingerprints.  That might be state 3.  You decide on the state numbers.
Logged
Mauritius
Offline Offline
Jr. Member
Learning Never Ends . . .
View Profile
May be something like this may help to see things clearer :
Code:
//definition of Variables
int State = 0
if (ButtonState==1)
    {State = 1}
Then in your code you define at State = 1, what happen depending on your requirements.
taz . .
Logged
tz
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Your code-style has too much comments imho (not to bash you, just want to learn you how to type less and more tot the point smiley
Code can explain itself if you choose good names for variables, functions and constants.
Comment should tell primarly the WHY, not the HOW (that should the code do) and sometimes explain the WHAT
Some examples
Quote
This kind above is obfuscating at best, code will always win when there is a difference between code and comment.
A better comment could be // milliseconds as that explains the unit of delay (WHAT)
Quote
is much better, but can be improved by using consts or #defines, creating self explaining code
something like this
Code:
// at the top of sketch you define
#define RIGHT_BUTTON_MENU 0
#define UP_BUTTON_MENU 1
#define DOWN_BUTTON_MENU 2
#define LEFT_BUTTON_MENU 3
#define SELECT_BUTTON_MENU 4
etc
if (adc_key_in == RIGHT_BUTTON_MENU)
if (adc_key_in == LEFT_BUTTON_MENU)
From the big block above loop() only this line explains something, the rest can be seen in the code, no need to comment
Code:
* Non-Stop looping
Give it a try!
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Jr. Member
View Profile
thank you. thank you very much. wow. i'm very grateful to all of u. much much clear. thank you for the explanation & example provided.
Logged
Offline Offline
Jr. Member
View Profile
by the way, is this code correct in your opinion. i manage to scroll down to every operation. add fingerprint, delete fingerprint and so on. by when i want to go to second menu, it won't go to the second menu. need advice on that. perhaps maybe something wrong with my coding.
Code:
int analogPin = A0;
int adc_key_old;
int NUM_KEYS = 5;
int key=-1;
// Variables will change:
int adc_key_in=0;
int adc_key_in_last = 0;     // previous state of the button
int adc_key_in_PushCounter = 0;   // counter for the number of button presses
int State1 = 0;
int State2 = 0;
int State3 = 0;
int State4 = 0;
int State5 = 0;
int State6 = 0;
int State7 = 0;
void setup ()
  lcd.setCursor(0,0);
  delay(1500);  // delay for 1500ms
  lcd.clear();
  // compare the buttonState to its previous state
  if (adc_key_in != adc_key_in_last) {
    // if the state has changed, increment the counter
    if (adc_key_in == DOWN_BUTTON_MENU) {
      // if the current state is HIGH then the button
      // wend from off to on:
      adc_key_in_PushCounter++;
      delay (300);
      if (adc_key_in_PushCounter==1) {
        //{State1 = 1}
        lcd.clear();
        lcd.setCursor(0,0);                       // set lcd.setCursor (column,row)
        lcd.print("Add Fingerprint");
        if (adc_key_in == SELECT_BUTTON_MENU) {
          addFinger0;
      else if (adc_key_in_PushCounter==2){
        lcd.clear();
        lcd.print("Delete");
        lcd.print("Fingerprint");
      else if (adc_key_in_PushCounter==3){
        lcd.clear();
        lcd.print("Search");
      else if (adc_key_in_PushCounter==4){
        lcd.clear();
        lcd.print("Empty Database");
      else if (adc_key_in_PushCounter==5){
        lcd.clear();
        lcd.print("Search Database");
    else {
      // if the current state is LOW then the button
      // wend from on to off:
      //lcd.setCursor(0,0);                       // set lcd.setCursor (column,row)
      //lcd.print("off");
  // save the current state as the last state,
  //for next time through the loop
  adc_key_in_last = adc_key_in;
  int k;
      return k;
  if (k >= NUM_KEYS)
    return k;
void addFinger0(){
  // set the cursor to column 0, line 1
  lcd.setCursor(0, 1);
  // Print a message to the LCD.
  lcd.print("Add Fingerprint1");
  delay(1500);
Logged
East Anglia (UK)
Offline Offline
Edison Member
View Profile
You are still not setting a variable to a value that would indicate which menu is on display so the program does not know what to do when a button is pressed.  I see that you have experimented with variable called stateX where X is a number but what you need to do is to have a single variable, maybe call it currentState, whose value indicates which menu is on display.
As a start, list all of the screens to be displayed and allocate each of them a number.  This number will be the value to be given to currentState.  Now list each of the buttons that might be pressed when each screen is on display and the actions to be taken should the button be pressed.
Screen 1 on display.  currentState = 1
button 1 pressed. Set currentState to 2 and show screen 2
button 2 pressed. Set currentState to 3 and show screen 3
button 3 pressed. Set currentState to 4 and show screen 4
Screen 2 on display.  currentState = 2
Call addFingerprint function
Button 2 pressed.  Set currentState to 1 and show screen 1
Screen 3 on display.  currentState = 3
Call deleteFingerprint function
Can you see how you can then use statements like
Code:
if (currentState == 1 && buttonPressed == 2)
//show screen 3
//do actions for screen 3
and how that differs from
Code:
if (currentState == 2 && buttonPressed == 2)
//set currentState to 1
//show screen 1
even though the same button was pressed each time.
Logged
Offline Offline
Jr. Member
View Profile
let me give a try first. Thank you by the way, correcting me. by the way, how to increase the currentstate so that it won't interpret it as button pressed? i almost got it. with the implementation of &&. thank you for that.
« Last Edit: January 21, 2013, 03:56:05 am by mr_hacker90 » Logged
Offline Offline
Jr. Member
View Profile
i believe more visible like this. i understand what u meant. almost got it. but how to link the state while i pressed the down button.
Code:
if (currentState == 1 && buttonPressed == DOWN_BUTTON_MENU)
  lcd.clear();
else if (currentState == 2 && buttonPressed == DOWN_BUTTON_MENU)
  lcd.clear();
else if (currentState == 3 && buttonPressed == DOWN_BUTTON_MENU)
  lcd.clear();
else if (currentState == 4 && buttonPressed == DOWN_BUTTON_MENU)
  lcd.clear();
else if (currentState == 5 && buttonPressed == DOWN_BUTTON_MENU)
  lcd.clear();
Logged
East Anglia (UK)
Offline Offline
Edison Member
View Profile
Your code is not updating the value of currentState when you change screens so it will always be the same value.
Look at this again
NOTE - I deliberately referred to screens rather than menus because when updating a fingerprint, for example, there will not be a menu on the screen, rather a prompt asking for the user to put their finger on the device or press a button to exit.  Equally, when a fingerprint has been read you probably need a screen asking for confirmation, but that is up to you.
Logged
Offline Offline
Jr. Member
View Profile
Look at this again
understood! just like stepping a stairs.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
