Topic: need help to modify this push button code (Read 3682 times) previous topic - next topic
mr_hacker90
#15
Jan 21, 2013, 10:46 am Last Edit: Jan 21, 2013, 10:51 am by mr_hacker90 Reason: 1
am i correct like this? but why it not goes to state 1. remain at state zero after i push down button.
 if (currentState == 0 && buttonPressed == DOWN_BUTTON_MENU)
   (currentState == 1);
   lcd.clear();
   lcd.setCursor(0,0);                       // set lcd.setCursor (column,row)
   lcd.print("Add Fingerprint");
 else if (currentState == 1 && buttonPressed == DOWN_BUTTON_MENU)
   (currentState == 2);
   lcd.clear();
   lcd.print("Delete");
   lcd.setCursor(0,1);                       // set lcd.setCursor (column,row)
   lcd.print("Fingerprint");
 else if (currentState == 2 && buttonPressed == DOWN_BUTTON_MENU)
   (currentState == 3);
   lcd.clear();
   lcd.print("Search");
 else if (currentState == 3 && buttonPressed == DOWN_BUTTON_MENU)
   (currentState == 4);
   lcd.clear();
   lcd.print("Empty Database");
 else if (currentState == 4 && buttonPressed == DOWN_BUTTON_MENU)
   //(currentState == 0);
   lcd.clear();
   lcd.print("Search Database");
Silverdog63
UKHeliBob
(currentState == 1); does nothing.  Actually not quite true, but not what you want
currentState = 1; sets the currentState variable to 1
== compares 2 things
= sets the variable on the left to the value on the right.
mr_hacker90
actually not quite true? i think my coding is like this. my initial state is zero by the way. currentState = 0; sets the currentState variable to 1
Quick5pnt0
In your code you have: (currentState == 1);
That won't do as you are intending. Assuming you want currentState to change to 1 you need to change it to: currentState = 1;
mr_hacker90
haha. thank you for that. now it is working. thanks buddy.
