Loading...
Pages: [1] 2   Go Down
Author Topic: Power arduino with an external battery!!!  (Read 405 times)
Offline Offline
Newbie
View Profile
Hello all, i wanted know if you can turn Arduino with external battery!!! Thank you!!!
Logged
Sweden
Offline Offline
Full Member
View Profile
Yes you can!  smiley
Logged
Offline Offline
Newbie
View Profile
I am using arduino uno. It has a port named as "Power". At that port there are pins available for 5v and GNG. So you can connect those pins to your external battery. I have tried it and it works fine.
Regards
Logged
Offline Offline
Newbie
View Profile
Thank you for replies, how many ampere can absorb arduino?
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Approimately 50mA...plus whatever you connect to it.
Logged
Ayer, Massachusetts, USA
Offline Offline
Edison Member
View Profile
WWW
Instead of using the external power port, I tend to like the rechargeable batteries meant for cell phones and plug in the USB cable to the battery and the USB port on Arduino.  I bought a unit with 5000 maH unit with two USB ports, and it lasted about 4 days running blink with no power conservation techniques.
If you do want to use the external power connector, I would suggest not using the 9 volt batteries sold for smoke detectors, since those don't hold much charge, and you will continually need to buy batteries.  I do keep a few 9v batteries that I take off of my smoke detectors that I use the battery until they are fully drained.  You can get cases that hold 6 rechargeable Nimh AA batteries fairly cheaply, which provide typically 7.2v to the power port, or 8 AA batteries which provide 9.6v in case you need to power things like motors or servos as well as the Arduino.
« Last Edit: January 18, 2013, 08:25:46 am by MichaelMeissner » Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
It's amazing that people rarely talk about applying power at the "Power Jack", but seem
to talk a lot about applying voltage at the Power header, especially to the 5V pin, and
which bypasses all of the protection circuitry built into the board. Can't figure it out.
If you hook any battery at all to the 5V pin, you'll never ever get a proper 5V on the 5V
buss of the board. ???????
Logged
Murphy's Corollary: the "real" problem is usually what they don't tell you about, which leads to endless second-guessing. m
Valencia, Spain
Offline Offline
Edison Member
View Profile
It doesn't need to be 5V. Anything between 1.8-5.5V will run the chip.
(Whether or not the attached devices will be happy is another thing...)
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
I connected 12v to the external power jack and noticed the board LEDs seemed brighter. Checked the voltage on the board 5v pin and it was ~8v! The external power circuit seems to be somewhat of a tutti-frutti design.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
Well that seems more like a on-board voltage regulator fault or failure. A operating regulator should only have 5v output with a 12v input, as that is certainly within it's operating limits.
Lefty
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Quote
buss of the board.
Why not? That pin IS the 5V bus on the card.  Whether that pin is supplied from the 5V regulator, the USB port, or directly from outside, the devices connected to it will not see a difference, and devices connected to IO pins will not see a difference.
I would put a 1N4001 diode from 5V (anode) to Vin (cathode), the currently used regulator NCP1117 is susceptible to damage from being reverse driven.
Zoomkat, sounds like you have a busted regulator.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Edison Member
View Profile
Quote
buss of the board.
I don't understand this comment. If you hook a battery directly to the 5V pin on the Power header,
how can you still expect to have 5V?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
I then powered the board with another 7805 connected to the arduino 5v pin and things then worked as expected. The arduino was an early ebay board, so the onboard 7805 could have been bad from the start.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
"If you hook a battery directly to the 5V pin on the Power header, how can you still expect to have 5V? "
I see what you're saying.  I interpreted that as "any 5V source" and not so much a battery literally.
You can have a 5V, or nearly 5V battery, connected - such as 4 x 1.2V NuMH batteries, for ~4.8V.
Or a battery or two with a boost converter, such as
http://www.pololu.com/catalog/product/798
http://www.pololu.com/catalog/product/2119
Logged
Online Online
Brattain Member
View Profile
Regards
And the current answer from the Arduino product people is:
Quote
5V.This pin outputs a regulated 5V from the regulator on the board. The board can be supplied with power either from the DC power jack (7 - 12V), the USB connector (5V), or the VIN pin of the board (7-12V). Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.
Of course this topic has been discussed so often in the past, to no satisfactory conclusion for all.
Lefty
Logged
Pages: [1] 2   Go Up
Print
Jump to:
