Topic: Webpage sending information to serial port (Read 3449 times) previous topic - next topic
arduinohabib
Hi all! I don't have nearly no experience on webpage design and stuff like that. I have dreamweaver, and I once tried to build a website. I was just thinking if I use XAMPP, can I build a webpage that can be accessed within my local area network, that can send something to the serial port my Arduino is connected to?
Thanks a lot.
Habib
What is man's best friend? The breadboard!
terryking228
Hi Habib,
To connect your Arduino to the network you need one of these things:
- connect serial port to a computer that is on the network
- connect an Ethernet Shield or Module to your Arduino, and wire that to your network.
On the http://ArduinoInfo.Info WIKI see more here: http://arduino-info.wikispaces.com/Ethernet
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
billroy
Bitlash Commander may be worth a look.  It allows you to control a usb-connected Arduino from a web dashboard:
https://github.com/billroy/bitlash-commander
-br
arduinohabib
Thank you all! Due to my budget, I don't think I can afford an ethernet shield yet.  :)
arduinohabib
Bitlash looks really cool! But does it work with windows?
zoomkat
You can use the apache web server on the pc and use a simple batch file as a cgi interface to send commands to the pc serial port.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
billroy
I haven't tested Bitlash Commander on Windows but it "should work".  Which is to say, let me know when you find problems…
Bitlash itself runs on the Arduino so Windows is not a factor.
-br
arduinohabib
Wow thanks @billroy! I managed to use bitlash with the Arduino serial monitor. But how do I use it over the network?
billroy
Congratulations!
Now you need to install the web part.  Follow the instructions to install Bitlash Commander here: https://github.com/billroy/bitlash-commander
Commander runs a web server on your PC.  The instructions tell you how to set it up and feed it.
Please note you do need development tools installed on your system (a compiler) for the Commander install to succeed.  On Windows, you need Visual Studio 2010.  On OS X, you need the free XCode install, and on Linux you need gcc / build-essential.
-br
arduinohabib
Thanks a lot! I already have visual studio.
Oh, I am also trying to sart an apache server with XXAMP.
Thanks!
arduinohabib
How do I install Bitlash Commander in windows? I can't open a terminal window.
billroy
I don't do Windows, but last time I did you could get a command console up with Start -> Run -> cmd or some similar incantation.
-br
