Loading...
Pages: [1] 2   Go Down
Author Topic: Automatic reading of arduino values WEBSERVER  (Read 2159 times)
Offline Offline
Full Member
View Profile
Hello! I'm having difficulties to make the html page stored in the Ethernet shield SD card, and loaded into browser, to permanently receive the values of my ultrasonic sensor, and change the height of an image (make a dynamic image), using only arduino+ethernet shield+SD card and my intranet (independant system of internet, computers,etc).
Thanks!!
Logged
Offline Offline
Full Member
View Profile
Is it possible to host an php page on SD card of ethernet shield and when this page is loaded by IP (of the ethernet shield), the arduino keep sending sensor value to this loaded page without meta refresh tag? In other words... keep arduino connected to the page in real time, and who is seeing the page see the values changing in real time?
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
You should be able to test the PHP question yourself. As to the meta refresh data, put it in a frame on your main page.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Full Member
View Profile
I've had tested it before but if the webpage hosted in sd card has some images, the meta refresh makes it slow to refresh because arduino has to load all images everythime, and i only want it to refresh a specific place (sensor values). There's any solution to do this?
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Quote
Sure, "As to the meta refresh data, put it in a frame on your main page." No need to reload the images.
Logged
Tasmania - Australia
Offline Offline
Sr. Member
View Profile
WWW
Sounds like you are wanting to display a HTML page which displays something like an image that changes in height as the value of your ultrasonic changes, is my understanding correct ?
Also, you are wanting to do this without using any other devices, such as servers on a hosted site, just using the Arduino and router to connect it to the internet, is this correct ?
If this is correct, how about this for an idea.
Firstly, forget about using php, you will need a server that has php, and the Arduino doesn't, can't support that.
Next, instead of using an image would it be a better idea to use HTML5 and use the 'canvas' element and then use HTML stroke and fill commands to draw your shape, say a rectangle. The rectangle would be sized according to your value from your ultrasonic sensor.
I imagine this would be quite a small and simple html document.
You could also look at using jQuery and have the client side request the data from the Arduino typically in json format every few seconds as you wish.
Using this concept is very neat and allows you to expand upon your idea as your program starts to grow.
Have a look at something I am working on in my spare time.
I have an Arduino Mega with on board ethernet and SD card connected to my router.
The client side request data directly from the Arduino using json format.
Also, the Arduino pushes data up to the host server where I have a php file take that and store in a SQL database.
It is still a work in progress at this point in time.
But it might give you some ideas of what you can do.
Go to http://paulalting.com/hydrosolar.php
Regards,
Paul
« Last Edit: January 21, 2013, 08:39:39 am by rockwallaby » Logged
Renewable Energy Monitor Project http://paulalting.com/hydrosolar.php     No, I don't really suffer from insanity, I enjoy it.     I do it with Eclipse IDE and Jantje's AVR plugin http://baeyens.it/eclipse/
Offline Offline
Full Member
View Profile
You're right! That's exactaly what i want to do. I think i can use PHP because in this intranet there's servers with PHP (Apache) running so they can "decode" it. My problem is that i only want to use intranet to load the page (stored in SD card) in browser and this page receive sensor values and then modify an image height (only from bottom to the top direction). So i will read the link you posted and search for information you give, meanwhile i keep not understanding if an webpage loaded from arduino has the capability to "act by its own" (modify image with sensor value every 2 minutes, for exemple).
Thanks for helping me!
Logged
Topsham, Vermont USA
Offline Offline
Edison Member
... in The Woods In Vermont
View Profile
WWW
Very cool Paul,
Are you using Rgraph for the dials, or your own code or ??
I'm pushing data to KSduino.com and he has graphs like this running: http://ksduino.org/?devices&device_parameter_id=194
Main data here: http://ksduino.org/?devices&device_id=3330
But I'd like to learn how to use HTML5 Canvas myself to create "Control Panels".. Total Newbie on that!
Maybe you could start a thread on this subject???
Logged
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
0
Offline Offline
God Member
Get Bitlash: http://bitlash.net
View Profile
If it's control panels in HTML5 you want, take a look at Bitlash Commander:
    https://github.com/billroy/bitlash-commander
Commander is intended to work with USB-connected Arduinos, but it is happy to accept HTTP POST data from ethernet-connected Arduinos as well.
For a simpler example there's ArduinoLiveChart:
    https://github.com/billroy/arduino-livechart
Not a drop-in solution for the OP's request but may be some useful ideas there.
Best,
-br
Logged
Offline Offline
Sr. Member
View Profile
WWW
Hello there Terry,
Nice to chat again, thank you for your comments.
The dials are created in HTML5 with the various stroke commands, though I did not make them, but simply use them in the javascript.
The historical trending charts are done using Highcharts, (a lot of work to be done here yet).
I shall put together some info in the coming days then. But I am doing a lot of work on the offline web site at present which has a lot of information about the whole system. There are some issues with the javascript as it is on the server at present, I have some fixes to upload to the server tomorrow hopefully.
Also, note that if you use Internet Explorer < 9, you may get strange or no results. I run OSX and Ubuntu, so Firefox, Chrome or Safari.
Yes, I looked at your KSduino graphs today, they look like they work well, and probably without a lot of the pain and hair pulling I am going through. It is fun and I am using it to learn more.
Good idea about a new thread, I would be happy to participate with that.
P.S. remember I had my Arduino Mega fries by lightning, well I was happy to receive free replacements for both the fried Ether-Mega and Ether-Ten from Freetronics.
Sleep time now in Australia, 12:25am
Kind regards,
Paul
« Last Edit: January 20, 2013, 08:26:28 am by rockwallaby » Logged
Offline Offline
Sr. Member
View Profile
WWW
Bill,
That demo chart looks good.
I see you use Node.js, which is something I looked into some weeks ago, it's very fast.
Though I wasn't sure if I could put Node.js up on my hosted site.
Will look more tomorrow,
Paul
Logged
0
Offline Offline
God Member
View Profile
FWIW, Most vanilla hosting hasn't caught up to node.js yet, but you can host small node.js apps for free on Heroku: http://www.heroku.com among other places (NodeJitsu and AppFog, for example).
-br
Logged
Offline Offline
Full Member
View Profile
The projects you're been posting are possible to do with the webpage stored in the ethernet shield SD Card ??
rockwallaby   The project of hydrosolar.php it's excellent and has one thing that i wanted to do in mine, is that the values changing without reload the image. Thanks for helping me
« Last Edit: January 20, 2013, 01:52:59 pm by blastboot » Logged
Offline Offline
Sr. Member
View Profile
WWW
Quote
blastboot wrote:
The projects you're been posting are possible to do with the web page stored in the ethernet shield SD Card ??
Yes, it is. In fact my project started out this way, only using the Arduino itself.
But there are cautions of course. With the Arduino SD card, care is needed around programing when it comes to having the same system work with ethernet. I believe the SD card system is relatively slow also, which may impact on how and what you want to do.
Keep in mind the idea that you can serve up a simple html file from the SD card and have your html code point to external resources such as fancy stuff like CSS or external libraries. Doing this will help with performance as the browser will get those files from high speed servers.
The Arduino Mega I use has onboard SD card slot as well as wiznet 5100 ethernet controller, so I simply connect it to a power supply and with a cat 5 cable, to my router.
But to remotely access your Arduino, you need to know your external IP address.
I knew the situation with mine, as it is static, it does not change over time.
Depending on your internet service provider, you may have either a static or dynamic IP assigned.
If dynamic you will need to use a service like 'no-ip', or 'dyndns' to help you with this.
Maybe your router has the provision to do this also.
Remember for remote access of any sort you will need to connect your Arduino to your ADSL/DSL router which is then connected to the internet via your ISP.
As far as the program is concerned, there are a few ways to do this, and Bill's way would be quite a suitable solution I think from what I see of Bitlash.
I will need to let Bill say if it would work with what you are wanting to do.
I would start with something very simple and build up from there.
Have the Arduino reliably read the ultrasonic signal and confirm this firstly in your serial monitor in the IDE.
Play around with this and get to know the limits and conditions under which ultrasonics will work reliably.
Then start with a section of program to present this data to a web browser if that is your intention.
I played around initially with some of the example web server programs here on the Arduino site, but I ended up using Webduino library as I really liked what it is able to do, as well as providing a good working framework that part of the software.
So, just checking, you do want to remotely view the ultrasonic level that your Arduino is reading?
And that you wish to use the Arduino to present this information as a dynamically updating html page?
If all the above is correct, can you tell us what you have done so far in terms of the program for the Arduino or are you just at the beginning stage?
Regards,
Paul
« Last Edit: January 21, 2013, 05:57:28 am by rockwallaby » Logged
Offline Offline
Full Member
View Profile
At this time I have made a simple HTML like you can see and i have this code on arduino that you can see below.
My problem is to make an animation inside the water tank that simulates water level according the ultrasonic values.
Another problem is to refresh values (% and Lt) without refreshing the whole page, because arduino is a little bit slower to upload images in browser. Keep in mind that i'm working on a Intranet and i don't have access to internet and the system has to be independant (no server storage files, only ethernet shield SD card).
I'm portugese so i've made some portuguese comments on program. This arduino program was searched on internet and it was a little adapted to survey my project. I'm trying to make an iframe like zoomkat said. Thanks for helping me  smiley-lol
Code:
/* SETUP CARTÃO SD: O SD DEVE ESTAR FORMATADO EM "FAT" E DEVE CONTER UM FICHEIRO
 * COM O NOME "index.htm". TODOS OS FICHEIROS NO CARTÃO DEVEM TER NOMES COM NO
 * MÁXIMO 8 CARACTERES E EXTENSÕES COM NO MÁXIMO 3 CARACTERES.
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#define greenLEDandBEEP 2
//O BUFFER DEVE SER GRANDE
#define BUFSIZ 128
float leitura = 0;
float percentagem = 0;
float litros = 0;
char buffer[3];
//CONFIGURAÇÃO DO ETHERNET SHIELD
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0xEA, 0x8C };
IPAddress ip(196,168,0,3);
char rootFileName[] = "index.htm";
EthernetServer server(80);
//PROGRAMAÇÃO PARA O CARTÃO SD
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
//ARMAZENA SEQUÊNCIAS DE ERRO NA MEMÓRIA FLASH PARA ECONOMIZAR RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
  PgmPrint("Erro: ");
  SerialPrintln_P(str);
  if (card.errorCode()) {
    PgmPrint("Erro cartao SD: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1);
  pinMode(greenLEDandBEEP, OUTPUT);
  PgmPrint("Memoria RAM Livre: ");
  Serial.println(FreeRam());
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
//INICIALIZA O CARTÃO SD EM "FULL SPEED", MÁXIMO DESEMPENHO. (PARA EVITAR ERROS COM LIGAÇÃO À BREADBOARD DEVE ESTAR EM "HALF SPEED"
  if (!card.init(SPI_FULL_SPEED, 4)) error("Falha no card.init!");
//INICIALIZA O VOLUME FAT
  if (!volume.init(&card)) error("Falha no vol.init!");
  PgmPrint("O volume e FAT");
  Serial.println(volume.fatType(),DEC);
  if (!root.openRoot(&volume)) error("Falha no openRoot!");
  PgmPrintln("Ficheiros na raiz do cartao:");
//LISTA NA SÉRIE OS FICHEIROS QUE ESTÃO NA RAIZ DO CARTÃO SD, COM DATA E TAMANHO
  root.ls(LS_DATE | LS_SIZE);
//LISTA OS FICHEIROS DE TODOS OS DIRECTÓRIOS DO CARTÃO SD
  PgmPrintln("Ficheiros encontrados em todos os directorios do cartao:");
  root.ls(LS_R);
  PgmPrintln("Concluido");
//CONCLUI A DEPURAÇÃO E INICIA O SERVIDOR
  Ethernet.begin(mac, ip);
  server.begin();
  delay(1);
  char clientline[BUFSIZ];
  char *filename;
  int image = 0;
  int index = 0;
  if (client) {
    boolean current_line_is_blank = true;
//REPÕE O BUFFER DE ENTRADA
    index = 0;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
//SE NÃO É UMA NOVA LINHA, GUARDA OS CARACTERES RECEBIDOS
        if (c != '\n' && c != '\r') {
          clientline[index] = c;
          index++;
//SE O BUFFER NÃO FOR GRANDE O SUFICIENTE, APAGA ALGUNS DADOS
          if (index >= BUFSIZ)
            index = BUFSIZ -1;
          //CONTINUA A LER MAIS DADOS
          continue;
//SE TEM \n OU \r ENTÃO A RECEPÇÃO DE DADOS ESTÁ CONCLUÍDA
        clientline[index] = 0;
        filename = 0;
//IMPRIME NA SÉRIE PARA DEPURAÇÃO
        Serial.println(clientline);
//PROCURA "GET / " PARA ENVIAR O index.htm
        if (strstr(clientline, "GET / ") != 0) {
          filename = rootFileName;
        if (strstr(clientline, "GET /") != 0) {
//SE NÃO HOUVER ESPAÇO A SEGUIR À "/", ENTÃO ESTÁ A PEDIR UM SUBDIRECTÓRIO OU FICHEIRO
          if (!filename) filename = clientline + 5;
//VÊ OS 5 CARACTERES APÓS O "GET /"
          (strstr(clientline, " HTTP"))[0] = 0;
//IMPRIME O NOME DO FICHEIRO "index.htm" NA SÉRIE
          Serial.println(filename);
          if (! file.open(&root, filename, O_READ)) {
            client.println("HTTP/1.1 404 Not Found");
            client.println("Content-Type: text/html");
            client.println();
            client.println("<h2>Erro 404</h2>");
            client.println("<s2>O ficheiro nao existe.<s2>");
            client.println("");
          Serial.println("Ligado!");
//TIPOS DE FICHEIRO QUE PODEM ESTAR NO CARTÃO SD
          if (strstr(filename, ".htm") != 0)
          else if (strstr(filename, ".css") != 0)
            client.println("Content-Type: text/css");
          else if (strstr(filename, ".png") != 0)
            client.println("Content-Type: text/php");
          else if (strstr(filename, ".php") != 0)
            client.println("Content-Type: image/png");
          else if (strstr(filename, ".jpg") != 0)
            client.println("Content-Type: image/jpeg");
          else if (strstr(filename, ".gif") != 0)
            client.println("Content-Type: image/gif");
          else if (strstr(filename, ".3gp") != 0)
            client.println("Content-Type: video/mpeg");
          else if (strstr(filename, ".pdf") != 0)
            client.println("Content-Type: application/pdf");
          else if (strstr(filename, ".js") != 0)
            client.println("Content-Type: application/x-javascript");
          else if (strstr(filename, ".xml") != 0)
            client.println("Content-Type: application/xml");
            client.println("Content-Type: text");
          client.println();
          int16_t c;
          while ((c = file.read()) >= 0) {
//IMPRIME NA SÉRIE TODO O CÓDIGO HTML (LENTO!) POR ISSO ESTÁ DESACTIVADO
            /*  Serial.print((char)c);  */
//IMPRIME NO BROWSER A PÁGINA HTML (CÓDIGO DO FICHEIRO "index.htm")
            client.print((char)c);
//A PARTIR DAQUI SERÁ CÓDIGO HTML A ACRESCENTAR AO "index.htm"
          client.print("<html><body>");
          //client.print("<P align=\"center\">");
          //client.print("Pagina elaborada por GRUPO 1 <b>");
          //client.print("</b><br>");
//LEITURA DOS DADOS DO SENSOR E CONVERSÃO PARA PERCENTAGEM
        if ( Serial.available () > 0 )
    if (Serial.read() == 'R')
     Serial.readBytesUntil ( '\r', &buffer[0], 3 );
  leitura = atoi(buffer);
  percentagem = (leitura*100)/465;
  Serial.print("Nivel do Tanque:");
  Serial.print(percentagem, 1);
  Serial.println("%");
 //CÁLCULOS DA QUANTIDADE DE ÀGUA NO TANQUE
  litros = (percentagem*700000)/100;
  Serial.print("Quantidade de agua no Tanque:");
  Serial.print(litros, 1);
  Serial.println("litros");
       if (percentagem >= 90 || percentagem <=10){
          client.print("<p>Nivel do Tanque: ");
          client.print("<b><font color=#E60000>");
          client.print(percentagem, 1);
          client.println("%");
          client.print("</font></b>");
          client.print("<p>Quantidade de agua no tanque: ");
          client.print(litros, 1);
          client.println(" litros");
       else {
          client.print("<b>");
          client.print("</b>");
          client.print("</p></body></html>");
//FIM DO CÓDIGO HTML A IMPRIMIR NO BROWSER
          file.close();
        else {
//TUDO O QUE NÃO ESTEJA INSERIDO NAS DEFINIÇÕES, É UM ERRO 404
          client.println();
          client.println("<h2>Error 404</h2>");
          client.println("");
    digitalWrite(greenLEDandBEEP, HIGH);
    delay(1);
    digitalWrite(greenLEDandBEEP, LOW);
    delay(1);
    client.stop();
//FIM DO PROGRAMA
« Last Edit: January 21, 2013, 10:49:46 am by blastboot » Logged
Pages: [1] 2   Go Up
Print
Jump to:
