Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: Project Timer with DS1307 - Array of TimeElements; - Is Possible ?  (Read 1238 times)
Offline Offline
Sr. Member
View Profile
Yes could be used for example for turn on a "Coffe Machine" ... it a general purpose ...
for example :
- turn on at 9:45 of 30-01-2013
- turn on off at 10:10 of 30-01-2013
so, now it's working ... i'm testing in all position on the loop, out loop etc etc,
thanks for the support,
john very great!
Logged
East Anglia (UK)
Online Online
Edison Member
May all of your blinks be without delay
View Profile
Setting/changing/cancelling the alarm on/off times will need to be done inside loop() or a function called from it or you will need to reset the Arduino to enable setup() to run again.
What is it that you have got working ?
Logged
Offline Offline
Sr. Member
View Profile
I've tried to setup a timer with Alarm.TriggerOnce(); from a menu and it's working ... also changing the timer with new value it's working again ... so now i need to adjust a little bit and clean a program ... then when i will finish the project i can did some Minutes with my experience ... maybe could be useful :-) for the moment I think could be solved :-)
very appreciate it,
regards,
gnux
Logged
East Anglia (UK)
Online Online
Edison Member
View Profile
That's good news.
Good luck with tidying it up - don't break it !
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
You Should deservedly be Very Proud of your self. You did a fine job all the way, A very fine Joj.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Offline Offline
Sr. Member
View Profile
Thanks Bob,
I'm try to put "all of me" for "understand", "try", "know", and then at end give the answer because I thinks is a respect for the people that have helped you to fix a issues ... this is the "sense" of the forum I thinks ...
warm regards,
gnux
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
Hey gnusso, that's terrific!  Congratulations!
John
Logged
Offline Offline
Sr. Member
View Profile
so, it's the true ... for example without you i was not able to understand how it's working what there into the background :-) and then this is important ...:-)
Logged
Offline Offline
Sr. Member
View Profile
Hi, good morning again,
so now that i've take a little bit confidence with that, I would like to create an array of TimeElements in order to do some operations using the "Top Down Methodologies" ...
Is possible to do that ? if yes how ? So, i've did just for give you an idea this quickly steps could be fine ?
Code:
#include <Time.h>
#include <TimeAlarms.h>
#include <LiquidCrystal.h> // ensure that the include path is set
#include "M2tk.h"
#include <VirtualWire.h>
#include <Wire.h>
#include <DS1307.h>
#include <EEPROM.h>
#include "utility/m2ghlc.h"
     TimeElements tm0start[10];
     tm0start[0].Day = 01;
     tm0start[0].Month = 12;
     tm0start[0].Year = 2013;
     tm0start[0].Hour = 01;
     tm0start[0].Minute = 25;
     tm0start[0].Second = 00;
     tm0start[1].Day = 03;
     tm0start[1].Month = 4;
     tm0start[1].Year = 2013;
     tm0start[1].Hour = 07;
     tm0start[1].Minute = 43;
     tm0start[1].Second = 23;
so, I didn't have back issues than can i hope :-) or better i need to try but now i didn't have with me the stuff :-(
gnux
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
An array of TimeElements that is local to setup() doesn't seem too useful. Other than that, the code looks fine. Does it compile?
Logged
Offline Offline
Sr. Member
View Profile
yes the compilation it's fine but you have reason it need to be declare into global scope ... the example was for see the array of time elements can works ...
« Last Edit: February 05, 2013, 11:20:32 am by gnusso » Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
