Topic: Project Timer with DS1307 - Array of TimeElements; - Is Possible ? (Read 14536 times) previous topic - next topic
johncc
#15
Jan 22, 2013, 10:02 pm Last Edit: Jan 22, 2013, 10:08 pm by johncc Reason: 1
 tm.Year = 2011;
 tm.Month = 01;
 tm.Day = 01;
 tm.Hour = 8;
 tm.Minute = 31;
 tm.Second = 00;
 Alarm.timerOnce(makeTime(tm), OnceOnly) ;
... the condition is never verified ...
Maybe the alarm actually triggered-- where were you at 8:31am on 1/1/2011?
Just kidding.
As UkHeliBob pointed out you should be using Alarm.triggerOnce() instead of timerOnce().  The documentation doesn't seem to describe this.  But you can get really good information about the TimeAlarms library by finding your Arduino/libraries/Timealarms/ directory and looking at readme.txt and TimeAlarms.h.  It is very well documented there as are many/most ARduino libraries:
  (TimeAlarms.h)
 AlarmID_t triggerOnce(time_t value, OnTick_t onTickHandler);   // trigger once at the given time_t
 AlarmID_t timerOnce(time_t value, OnTick_t onTickHandler);   // trigger once after the given number of seconds
Also I noticed in Time.h that it is expecting a year in the form of "years since 1970", so you should put in some reasonable values like:
 static tmElements_t tm; // this is fine static is ok here but not necessary
 tm.Year = 2013 - 1970;  // this would be year 2013
 tm.Month = 01;
 tm.Day = 22;
 tm.Hour = 15;
 tm.Minute = 01;
 tm.Second = 00;
 Alarm.triggerOnce(makeTime(tm), OnceOnly) ;
HTH,
John
UKHeliBob
From the readme :
"Low level functions to convert between system time and individual time elements are provided:
  breakTime( time, &tm);  // break time_t into elements stored in tm struct
  makeTime( &tm);  // return time_t  from elements stored in tm struct "
So you can convert both ways.
gnusso
Hi Guys,
really thanks I've understood now ...  so thanks for the very great support !!! I've adjust my sketch and now it's working ... so this morning I will try to play well with this  ;) thanks again,
warm regards,
Gnux
gnusso
Good Morning,
I've note using the TimerAlarmExample:
#include <Time.h>
#include <TimeAlarms.h>
  setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011
  // create the alarms
  Alarm.alarmRepeat(8,30,0, MorningAlarm);  // 8:30am every day
  Alarm.alarmRepeat(17,45,0,EveningAlarm);  // 5:45pm every day
  Alarm.alarmRepeat(dowSaturday,8,30,30,WeeklyAlarm);  // 8:30:30 every Saturday
  Alarm.timerRepeat(15, Repeats);            // timer for every 15 seconds
  Alarm.timerOnce(10, OnceOnly);             // called once after 10 seconds
void  loop(){
  //digitalClockDisplay();
   Alarm.delay(1000); // wait one second between clock display
// functions to be called when an alarm triggers:
void MorningAlarm(){
  Serial.println("Alarm: - turn lights off");
void EveningAlarm(){
  Serial.println("Alarm: - turn lights on");
void WeeklyAlarm(){
  Serial.println("Alarm: - its Monday Morning");
void ExplicitAlarm(){
  Serial.println("Alarm: - this triggers only at the given date and time");
void Repeats(){
  Serial.println("15 second timer");
void OnceOnly(){
  Serial.println("This timer only triggers once");
void digitalClockDisplay()
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.println();
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
If I didn't put
Alarm.delay(1000);
the timer doesn't work ...
My understanding is that the timer should work in background without block the cpu each time for a second ...
is there a way to change it ?
thx
gnux
UKHeliBob
The documentation for TimeAlarms specifically says that you must use Alarm.delay() for it to work otherwise it cannot check for alarms.  There is no reason why you should not use Alarm.delay(1) if you want it not to block for 1 second.  You could also arrange to call Alarm.delay() at less frequent intervals using millis() as your own non blocking timer and only calling it when the delay will not affect your program.
gnusso
#20
Jan 25, 2013, 10:37 am Last Edit: Jan 25, 2013, 11:41 am by gnusso Reason: 1
Thanks for information,
so then Alarm.delay(); is mandatory for start timer ...
into Example there is Alarm.delay(1000); just for see the time that change each 1 seconds...
correct ?
Also another curiosity ... if I use  Alarm.triggerOnce(); into setup of course is used one time only , if call  Alarm.triggerOnce() into loop after the first time that alarm is triggered each time is call the function ... due the fact the condition is always verify ...
Is there the possibility to Triggered off the alarm just after that is verify ? in this way I can pass several arguments to the triggeronce into the loop and i will able to change my timer ...
Make sense the questions ?
thanks
gnux
UKHeliBob
Post you whole code that is not working properly so that we can see how it is written and give advice.
I am sorry but I cannot make sense of your questions.  Can you please rephrase them ?
If you are asking if you can disable an alarm once it is set then, yes you can.  There is a limit to how many alarms can be set, normally 6 but the limit can be increased up to a limit of 255.
gnusso
Hi, here you are the code ...
for sure the value into the ram are correct ... due the fact if i call the routine
Alarm.triggerOnce(makeTime(tm0stop), StopTimer0);
into the loop it's work ...
the code for the sketch :
void FaiTempo0()
   // make time stop timer 1
TimerWakeup0 = memoria[0];
tm0start.Hour =   memoria[2];
tm0start.Minute = memoria[3];
tm0start.Second = 00;
tm0start.Day =   memoria[4];
tm0start.Month = memoria[5];
tm0start.Year = (memoria[6]+2000) - 1970;
StartTimer0 = memoria[7];
// make time stop timer 0
tm0stop.Hour =   memoria[8];
tm0stop.Minute = memoria[8];
tm0stop.Second = 00;
tm0stop.Day =   memoria[10];
tm0stop.Month = memoria[11];
tm0stop.Year = (memoria[12]+2000) - 1970;
StopTimer0 = memoria[13];
void Timer()
     FaiTempo0();
      Alarm.triggerOnce(makeTime(tm0start), FunctionStartTimer0);
     if (TimerWakeup0 == 1)
        if (StartTimer0 == 0)
          memoria[7] = 1;
          EEPROM.write(7, memoria[7]);
             if (StopTimer0 == 0);
                Alarm.triggerOnce(makeTime(tm0stop), FunctionStopTimer0);
                memoria[13] = 1;
                memoria[0] = 0;
                EEPROM.write(13, memoria[13]);
                EEPROM.write(0, memoria[0]);
    Timer();
  m2.checkKey();
  m2.checkKey();
  if ( m2.handleKey() )
    m2.draw();
  m2.checkKey();
  Alarm.delay(1);
of course there is all variable declared ...and memoria red value from eeprom correctly at the setup()
my purpose when will be ok is change from a menu value timer (date start and time start,devstart etc etc)
this was the scope of my question ... if is possible call triggerOnce ... into the loop and stop it after will be excute ... but I don't know how ...
thanks for the support,
gnux
UKHeliBob
We need to see the whole sketch to understand what you are doing
gnusso
Ok was to long I will split in 2 part :-)
1°st part:
#include <Time.h>
#include <LiquidCrystal.h> // ensure that the include path is set
#include "M2tk.h"
#include <VirtualWire.h>
#include <Wire.h>
#include <DS1307.h>
#include <EEPROM.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
//Variabili Globali
char dev;
char testo[15];
// usata per mandare il messaggio
char messaggio[15];
// usato nell'index del close del keypad
int ind = 0;
// usato nel keypad
char Tasto;
// usato nel keyoad
unsigned long UltimoTasto = 0;
// usato nel nella procedura seriale
String LeggiStringa;
byte memoria[105];
uint8_t TimerWakeup0;  // serve per controllare se il timer è enable/disable
uint8_t StartTimer0;   // serve per controllare se è stato attivato il primo timer
uint8_t StopTimer0;    // serve per controllare se è stato attivato il secondo timer
TimeElements tm0start;
TimeElements tm0stop;
TimeElements tm1start;
TimeElements tm1stop;
TimeElements tm2start;
TimeElements tm2stop;
TimeElements tm3start;
TimeElements tm3stop;
TimeElements tm4start;
TimeElements tm4stop;
TimeElements tm5start;
TimeElements tm5stop;
TimeElements tm6start;
TimeElements tm6stop;
TimeElements tm7start;
TimeElements tm7stop;
void LeggiEeprom()
  int ind;
   for (ind =0; ind <= 105 ; ind++)
        memoria[ind] = EEPROM.read(ind);
void FaiTempo0()
void Timer()
     FaiTempo0();
          memoria[7] = 1;
                memoria[13] = 1;
                memoria[0] = 0;
void FunctionStartTimer0()
  messaggio[0]='1';
  messaggio[1]='0';
  messaggio[2]='#';
  Serial.println("Start Timer 0");
  // TxMsg(messaggio);
void FunctionStopTimer0()
  messaggio[0]='*';
  messaggio[1]='0';
  messaggio[2]='#';
  Serial.println("Stop Timer 0");
now will continue with the second one :
gnusso
Second Part:
void DefinizionePin()
  //Piedini Utilizzati per Gestire LCD
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
  pinMode(A4, INPUT);
  pinMode(A5, INPUT);
  pinMode(13, OUTPUT);
void Comunicazione()
   Wire.begin();         // Inizializzo la Comunicazione I2C
   Serial.begin(9600); // Inizializzo la Seriale
   vw_setup(1200); // Inizializzo al Comunicazione TTL su Virtual Wire
   vw_rx_start();        // Start the receiver PLL running
   RTC.start();          // Fai partire il clock
void TxMsg(char buffer[15])
   vw_send((uint8_t *)buffer, strlen(buffer));
   vw_wait_tx(); // Wait until the whole message is gone
   Serial.println(buffer);
   buffer[0]='\0';
   Serial.println("Comando Inviato");
// Forward declaration of the toplevel element
M2_EXTERN_HLIST(top_el_expandable_menu);
/* SetDate 1-1  */
uint8_t dt_day = 1;
uint8_t dt_month = 1;
uint8_t dt_year = 12;
uint8_t dt_min = 1;
uint8_t dt_hour = 1;
void dt_current(void)
  Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
  Serial.print(":");
  Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
  Serial.print(":");
  Serial.print(RTC.get(DS1307_SEC,false));//read seconds
  Serial.print("      ");                 // some space for a more happy life
  Serial.print(RTC.get(DS1307_DATE,false));//read date
  Serial.print("/");
  Serial.print(RTC.get(DS1307_MTH,false));//read month
  Serial.print("/");
  Serial.print(RTC.get(DS1307_YR,false)); //read year
  Serial.println();
  Serial.print(minute());
  Serial.print(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
  Serial.println();
void dt_get_from_RTC(void)
  dt_day = RTC.get(DS1307_DATE,false);
  dt_month = RTC.get(DS1307_MTH,false);
  dt_year = (RTC.get(DS1307_YR,false)-2000);
  dt_min = RTC.get(DS1307_MIN,false);
  dt_hour = RTC.get(DS1307_HR,true);
void dt_put_to_RTC(void)
  RTC.stop();
  RTC.set(DS1307_DATE,dt_day);
  RTC.set(DS1307_MTH,dt_month);
  RTC.set(DS1307_YR,dt_year);
  RTC.set(DS1307_HR,dt_hour);
  RTC.set(DS1307_MIN,dt_min);
  RTC.start();
  setTime(RTC.get(DS1307_HR,true),RTC.get(DS1307_MIN,false),RTC.get(DS1307_SEC,false),RTC.get(DS1307_DATE,false),RTC.get(DS1307_MTH,false),(RTC.get(DS1307_YR,false)-2000));
void dt_ok_date(m2_el_fnarg_p fnarg)
  dt_put_to_RTC();
  m2_SetRoot(&top_el_expandable_menu);
void time_ok_button(m2_el_fnarg_p fnarg)
dt_put_to_RTC();
void view_ok_button(m2_el_fnarg_p fnarg)
  dt_current();
M2_U8NUM(el_dt_year, "c2", 0,99,&dt_year);
M2_LABEL(el_dt_sep1, "b1", "-");
M2_U8NUM(el_dt_month, "c2", 1,12,&dt_month);
M2_LABEL(el_dt_sep2, "b1", "-");
M2_U8NUM(el_dt_day, "c2", 1,31,&dt_day);
M2_LIST(list_date) = { &el_dt_year, &el_dt_sep1, &el_dt_month, &el_dt_sep2, &el_dt_day };
M2_HLIST(el_date, NULL, list_date);
M2_ROOT(el_dt_cancel, NULL, "cancel", &top_el_expandable_menu);
M2_BUTTON(el_dt_ok, NULL, "ok", dt_ok_date);
M2_LIST(list_dt_buttons) = {&el_dt_cancel, &el_dt_ok };
M2_HLIST(el_dt_buttons, NULL, list_dt_buttons);
M2_LIST(list_dt) = {&el_date, &el_dt_buttons };
M2_VLIST(el_top_dt, NULL, list_dt);
/* Set time 1-2 ---------------------------------------------------------------------*/
M2_U8NUM(el_dt_hour, "c2", 0,23,&dt_hour);
M2_LABEL(el_dt_c, "b1", ":");
M2_U8NUM(el_dt_min, "c2", 0,59,&dt_min);
M2_LIST(list_time) = { &el_dt_hour, &el_dt_c, &el_dt_min};
M2_HLIST(el_time, NULL, list_time);
M2_ROOT(el_time_cancel, NULL, "cancel", &top_el_expandable_menu);
M2_BUTTON(el_time_ok, NULL, "ok", time_ok_button);
M2_LIST(list_time_buttons) = {&el_time_cancel, &el_time_ok };
M2_HLIST(el_time_buttons, NULL, list_time_buttons);
M2_LIST(list_t) = {&el_time, &el_time_buttons};
M2_VLIST(el_top_time, NULL, list_t);
/* View DateTime 1-3  */
M2_LABEL(el_dt_view, "b1", "DateTimeNow");
M2_LIST(list_view) = {&el_dt_view};
M2_HLIST(el_view, NULL, list_view);
M2_ROOT(el_view_cancel, NULL, "cancel", &top_el_expandable_menu);
M2_BUTTON(el_view_ok, NULL, "ok", view_ok_button);
M2_LIST(list_view_buttons) = {&el_view_cancel, &el_view_ok };
M2_HLIST(el_view_buttons, NULL, list_view_buttons);
M2_LIST(list_v) = {&el_view, &el_view_buttons};
M2_VLIST(el_top_view, NULL, list_v);
/* -------------- DEVICE 2 ----------------------*/
uint8_t u8dev = 0;
uint8_t u8stato = 0;
void fn_clean_dev(m2_el_fnarg_p fnarg) {
  u8dev = 0;
void dev_ok_button(m2_el_fnarg_p fnarg) {
  if (u8dev <= 9)
     messaggio[1] = u8dev + 48;
     messaggio[2] = '#';
     messaggio[3] = '\0';
    if (u8dev > 9)
      int x,y;
      y = u8dev/10;
      messaggio[1] = y + 48;
      x = u8dev % 10;
      messaggio[2] = x + 48;
      messaggio[3] = '#';
      messaggio[4] = '\0';
    if (u8stato == 0)
      messaggio[0] ='*';
    if (u8stato == 1)
      messaggio[0] ='1';
  TxMsg(messaggio);
  messaggio[0] = '\0';
void dev_stato_button(m2_el_fnarg_p fnarg) {
// procedura per recuperare lo stato della periferica
M2_LABEL(el_num_label1, NULL, "Select Dev:");
M2_U8NUM(el_num_1, NULL, 0, 64, &u8dev);
M2_LABEL(el_num_label2,NULL, "Turn Off/On:");
M2_U8NUM(el_num_2, NULL, 0, 1, &u8stato);
M2_BUTTON(el_num_zero, "f4", "zero", fn_clean_dev);
M2_BUTTON(el_dev_ok, NULL, "ok", dev_ok_button);
M2_BUTTON(el_dev_stato, NULL, "stato", dev_stato_button);
M2_ROOT(el_num_goto_top, "f4", "back", &top_el_expandable_menu);
M2_LIST(num_list) = {
    &el_num_label1, &el_num_1,
    &el_num_label2, &el_num_2,
    &el_dev_ok, &el_num_zero, &el_num_goto_top,&el_dev_stato
M2_GRIDLIST(el_num_menu, "c2", num_list);
/* --------------------------- main menu-------------------------- */
m2_menu_entry m2_2lmenu_data[] =
  { "DATE/TIME 1", NULL },
  { ". SetDate 1-1", &el_top_dt },
  { ". SetTime 1-2", &el_top_time},
  { ". View DateTime 1-3", &el_top_view},
  { "DEVICES 2", NULL},
  { ". Manage 2-1", &el_num_menu},
  { NULL, NULL },
uint8_t m2_2lmenu_first;
uint8_t m2_2lmenu_cnt;
M2_2LMENU(el_2lmenu,"l4e1w12",&m2_2lmenu_first,&m2_2lmenu_cnt, m2_2lmenu_data,'+','-','\0');
M2_VSB(el_vsb, "l4w1r1", &m2_2lmenu_first, &m2_2lmenu_cnt);
M2_LIST(list_2lmenu) = { &el_2lmenu, &el_vsb };
M2_HLIST(top_el_expandable_menu, NULL, list_2lmenu);
// m2 object and constructor
M2tk m2(&top_el_expandable_menu, m2_es_arduino_serial, m2_eh_2bs, m2_gh_arduino_serial);
/* --------------------------- end menu-------------------------- */
     Comunicazione();
     LeggiEeprom();
    Timer();
     // Alarm.triggerOnce(makeTime(tm0stop), StopTimer0);
  m2.checkKey();
  m2.checkKey();
    m2.draw();
  m2.checkKey();
  Alarm.delay(1);
Now just past the 2 in only one sketch,
regards,
gnux
gnusso
Good Morning Folks,
with the sketch upload reported I've tried to set a Alarm.TriggerOnce(); for try to set timer dynamically changes the timer values from a menu ...
with the sketch that I've did I've put a If,Then,Else Structure for execute Alarm.TriggerOnce(); one time only check a flag inside a EEPROM.
The fact the function is execute but of course the timer doesn't start because the timer is match ...
So then I need to find a solution for call Alarm.TriggerOnce(); when I've want with dynamically value check this until is verify the first times that is verified change the value into the register and didn't check again until the value will be correct again...
is there something flag for check it inside a library ?
Please let me know if you want more specifics,
thanks
gnux
UKHeliBob
Sorry, but I am not sure what you want to do and what the problem is.
Can you please explain it step by step ?
I think that you want to set an alarm time from user input and to have the alarm trigger once.  Is that right ?
If so, does the user input collect the data correctly (send it to Serial.print to check) and does the alarm trigger if you set the alarm time explicitly in code ?
gnusso
Good Afternoon,
"I think that you want to set an alarm time from user input and to have the alarm trigger once.  Is that right ?"
More or less, better ...
I want to set an alarm time from user input and to have the "Alarm TriggerOnce" each time that the user input match the trigger ...
So for example:
- Call Timer1 ---> for start at 15:00 28/01/2013
and Can call Timer 1 each time base on the user input ...
If put Alarm TriggerOnce(); into the setup will be excute only one time or every time that value will change ? (of course behind the of value MakeTime() will change )
It is  more clear now ? :-)
Thansk 1000 for the support,
gnux
UKHeliBob
Good Afternoon,
You do realise that TriggerOnce will only do what it says and only trigger once ?
To repeat my previous question
