Loading...
Pages: [1]   Go Down
Author Topic: Interfacing with more than one tx/rx serial device  (Read 152 times)
Offline Offline
Newbie
View Profile
So I know the catch is that only one device can use the tx and rx lines. I have two devices that require serial tx/rx communication. Is there a way around this problem? I was thinking a switch that can be switched on/off with one of the other digital pins? Thoughts? Thanks in advance.
--Mike
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Well, the Uno can Tx to both at same time.
Need a way to only Rx from one at a time.
What voltage levels are being used? TTL? RS232? RS485?
With TTL, you could use a pin as you suggested to enable one Rx line or the other thru their own 74HC125 buffer.
http://www.digikey.com/product-detail/en/74HC125N,652/568-1393-5-ND/762997
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
You can also use SoftwareSerial to talk to one of (or both of) the devices.
Logged
Pages: [1]   Go Up
Print
Jump to:
