Loading...
Pages: [1]   Go Down
Author Topic: Esplora power hack  (Read 541 times)
US
Offline Offline
Full Member
Electronics are the new Legos
View Profile
WWW
The Esplora was not really designed for battery power.  In the last two weeks I have used an Energizer "cell phone" backup battery into the USB port.
The more elegant (hack) solution is using a rechargeable LiPo battery. But this will not put out the 5 volts the Esplora needs.  This is where an Adafruit Mintyboost works well to boost the 3.6 volts from the battery circuit boosts to 5 volts.
To feed the voltage in, I put it into the Tinkerkit output pins rather than the USB to create a lower profile and free the port for programming.  Be careful not to have both connected at the same time.
Full details on how this was done are at http://21stdigitalhome.blogspot.com/2013/01/lipo-powered-arduino-esplora-game.html.
The project also adds an XBee radio that communicates via the two Tinkerkit digital pins which map to Arduino IDE digital pins 3 and 11.  The only two free pins to hack around with if you use a display.  I've documented the display interface if you want to hack those pins, see http://21stdigitalhome.blogspot.com/ under December.
« Last Edit: January 19, 2013, 12:01:04 pm by TheKitty » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
cross-post with - http://arduino.cc/forum/index.php/topic,143371.msg1076748.html#msg1076748 -
Please remove one of the threads. (advice keep the other with the pictures, they look good!)
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
