Pages: [1] 2   Go Down
Author Topic: analogWrite freeze the arduino  (Read 449 times)
    i'm trying to do a sketch that when receive string with 3 value R,G,B, it put the value on three pwn pin so that i could change the colors of my led strip with any browser. the sketche work like a charm, value is correctly displayed in the serial monitor but as soon as i put in the code
the three analogWrite, it freeze.
i put
analogWrite(redPin, r);
analoWrite(greenPin, g);
analogWrite(bluePin, b
here the partial of the code
EthernetClient client = Ledserver.available();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Michael led server</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Michael test server</H1>");
          client.println("<a href=\"/?on\"\">ON</a>");
          client.println("<a href=\"/?off\"\">OFF</a>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
readString = readString.substring(5, readString.length() - 11);
Serial.println(readString); //print to serial monitor for debuging
int commaIndex = readString.indexOf(',');
//  Search for the next comma just after the first
int secondCommaIndex = readString.indexOf(',', commaIndex+1);
String firstValue = readString.substring(0, commaIndex);
String secondValue = readString.substring(commaIndex+1, secondCommaIndex);
String thirdValue = readString.substring(secondCommaIndex+1); // To the end of the string
int r = firstValue.toInt();
int g = secondValue.toInt();
int b = thirdValue.toInt();
Serial.println(r);
Serial.println(g);
Serial.println(b);
          //clearing string for next read
          readString="";
Thanks in advance
Seattle, WA USA
Seattle, WA USA
Nope. We need to see all of the code. Which pins are you using for the LEDs?
Boston area, metrowest
Isn't this the problem?
These are ints (0x0000 to 0xFFFF), while analogWrite expects bytes (0x00 to 0xFF)?
USA
... it freeze.
What does freeze mean in this context?
That should produce a compiler error.  I think freeze means the sketch doesn't work anymore.
here the code
//Michael sketche
//Arduino server for 8 relay, stove and RGB led strip
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//address will look like http://192.168.1.102:84 for the ledserver
//address will look like http://192.168.1.102:85 for the relayserver
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
boolean reading = false;
// Debug mode
#define DEBUG true
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 2, 16 }; // ip in lan
EthernetServer Ledserver(84); //Led server port
EthernetServer Relayserver(85); //Relay server port
//For arduino input
#define Doorbelloff "76" //Scene for pin 2 LOW (door bell On)
#define Doorbellon "83" //Scene for pin 2 high (door bell OFF)
#define Phoneon "81" //Scene for pin 3 LOW (telephoe ring On)
#define Phoneoff "82" //Scene for pin 3 high (telephoe ring OFF)
#define Doorbell 2
#define Phone    3
boolean DoorbellState = false;
boolean PhoneState = false;
boolean Phonedelay = false;
//Variable for debonce phone ring
unsigned long pressed;
int pwrtime = 600;
unsigned long time;
unsigned long unpressed;
char serverName[] = "192.168.2.19"; //Vera ip address
EthernetClient client;
String readString;
//RGB led pin
const int redPin =   9;
const int greenPin = 10;
const int bluePin =  11;
void setup(){
  //start Ethernet
  Ethernet.begin(mac, ip);
  Ledserver.begin();
  //Led pin
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  //input
  pinMode(Doorbell, INPUT);
  pinMode(Phone, INPUT);
  //relay pin
  pinMode(22, OUTPUT); //output relay pin
  pinMode(23, OUTPUT); //output relay pin
  pinMode(24, OUTPUT); //output relay pin
  pinMode(25, OUTPUT); //output relay pin
  pinMode(26, OUTPUT); //output relay pin
  pinMode(27, OUTPUT); //output relay pin
  pinMode(28, OUTPUT); //output relay pin
  pinMode(29, OUTPUT); //output relay pin
  Serial.println("Arduino starting"); // so I can keep track of what is loaded
   if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  else{
    Serial.println("Ethernet ready local IP:");
    Serial.println(Ethernet.localIP());
  // give the Ethernet shield a second to initialize:
void loop(){
  Led();
  Relay();
  DoorbellDetection();
  TelephoneDetection();
void Led(){
  // Create a client connection
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
          client.println();
          delay(1);
          //stopping client
          client.stop();
Serial.println(r);
Serial.println(g);
Serial.println(b);
          readString="";
[code]void Relay(){
  EthernetClient client = Relayserver.available();
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    boolean sentHeader = false;
        if(!sentHeader){
          // send a standard http response header
          client.println();
          sentHeader = true;
        if(reading && c == ' ') reading = false;
        if(c == '?') reading = true; //found the ?, begin reading the info
        if(reading){
          Serial.print(c);
           switch (c) {
            case '1':
              //relay pin 22 on
              digitalWrite(22, HIGH);
              Serial.println("Relay 1 on");
              break;
            case '2':
              //relay pin 22 off
              digitalWrite(22, LOW);
              Serial.println("Relay 1 off");
              break;
            case '3':
              //relay pin 23 on
              digitalWrite(23, HIGH);
              Serial.println("Relay 2 on");
              break;
            case '4':
            //relay pin 23 off
              digitalWrite(23, LOW);
              Serial.println("Relay 2 off");
              break;
            case '5':
              //relay pin 24 on
              digitalWrite(24, HIGH);
              Serial.println("Relay 3 on");
              break;
            case '6':
            //relay pin 24 off
              digitalWrite(24, LOW);
              Serial.println("Relay 3 off");
              break;
            case '7':
              //relay pin 25 on
              digitalWrite(25, HIGH);
              Serial.println("Relay 4 on");
              break;
            case '8':
            //relay pin 25 off
              digitalWrite(25, LOW);
              Serial.println("Relay 4 off");
              break;
              case '9':
              //relay pin 26 on
              digitalWrite(26, HIGH);
              Serial.println("Relay 5 on");
              break;
            case '0':
              //relay pin 26 off
              digitalWrite(26, LOW);
              Serial.println("Relay 5 off");
              break;
            case 'a':
              //relay pin 27 on
              digitalWrite(27, HIGH);
              Serial.println("Relay 6 on");
              break;
            case 'b':
            //relay pin 27 off
              digitalWrite(27, LOW);
              Serial.println("Relay 6 off");
              break;
            case 'c':
              //relay pin 28 on
              digitalWrite(28, HIGH);
              Serial.println("Relay 7 on");
              break;
            case 'd':
            //relay pin 28 off
              digitalWrite(28, LOW);
              Serial.println("Relay 7 off");
              break;
            case 'e':
              //relay pin 29 on
              digitalWrite(29, HIGH);
              Serial.println("Relay 8 on");
              break;
            case 'f':
            //relay pin 29 off
              digitalWrite(29, LOW);
              Serial.println("Relay 8 off");
              break;
              case 'g':
              //relay pin 29 on
              digitalWrite(30, HIGH);
              Serial.println("Foyer on");
              break;
            case 'h':
            //relay pin 29 off
              digitalWrite(30, LOW);
              Serial.println("Foyer off");
              break;
        if (c == '\n' && currentLineIsBlank)  break;
        if (c == '\n') {
        }else if (c != '\r') {
          currentLineIsBlank = false;
    delay(1); // give the web browser time to receive the data
    client.stop(); // close the connection:
 void DoorbellDetection(){
      // Arduino input detection code
      if (digitalRead(Doorbell) == HIGH && DoorbellState == false) // switch on pinDevid1 is ON
        if(DEBUG){Serial.println("Doorbell off");}
        DoorbellState = true;
        //Sending request to Vera
        sendToVera(Doorbelloff);
       if (digitalRead(Doorbell) == LOW && DoorbellState == true) // switch on pinDevid1 is OFF
        if(DEBUG){Serial.println("Doorbell on");}
        sendToVera(Doorbellon);
 void TelephoneDetection (){
      time = millis();
      // Listening for the pin3 state
       if (digitalRead(Phone) == HIGH && PhoneState == false) // switch on pinDevid1 is ON
        PhoneState = true;
         if(DEBUG){Serial.println("Phone off");}
        sendToVera(Phoneoff);
       if (digitalRead(Phone) == LOW && PhoneState == true) // switch on pinDevid1 is OFF
      pressed = time,
      PhoneState = false;}
       if ((PhoneState == false) && ((time - pressed) > pwrtime))
        if(DEBUG){Serial.println("Phone on");}
        Phonedelay = true;
        sendToVera(Phoneon);
 void sendToVera(String devid){
  if (client.connect(serverName, 49451)) {
    if(DEBUG){Serial.println("connected to Vera");}
    if(DEBUG){Serial.println("sendind request");}
    client.print("GET /data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=");
    client.print(devid);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(serverName);
    client.println("User-Agent: Arduino");
    client.println();
  else {
    if(DEBUG){Serial.println("connection failed");}
  // if there are incoming bytes available
  // from the server, read them and print them:
  if(DEBUG){
    Serial.print(c);
    if(DEBUG){Serial.println();}
    if(DEBUG){Serial.println("disconnecting.");}
    client.stop();
    if (Phonedelay == true)
     delay(1500);
     Phonedelay = false;
[/code]
yes i'm able to compile it, as soon as i send a http request and i compile it with the analogwrite, it freeze. but if the analogwrite isn't there, it's ok and i'm able to see the three value r,g,b in the serial. the rest of the sketches work like charm.
thanks
USA
You maybe running out of RAM.  Insert the following code into the sketch and print (Serial.println()) the result of StackCount().  Also, what board are you using?
#define STACK_CHECK_BUILT
#ifdef STACK_CHECK_BUILT
extern uint8_t _end;
extern uint8_t __stack;
#define STACK_CANARY 0xc5
void StackPaint(void) __attribute__ ((naked)) __attribute__ ((section (".init1")));
#if 0
   uint8_t *p = &_end;
   while(p <= &__stack) {
      *p = STACK_CANARY;
       p++;
#else
    __asm volatile ("    ldi r30,lo8(_end)\n"
                    "    ldi r31,hi8(_end)\n"
                    "    ldi r24,lo8(0xc5)\n" // STACK_CANARY = 0xc5
                    "    ldi r25,hi8(__stack)\n"
                    "    rjmp .cmp\n"
                    ".loop:\n"
                    "    st Z+,r24\n"
                    ".cmp:\n"
                    "    cpi r30,lo8(__stack)\n"
                    "    cpc r31,r25\n"
                    "    brlo .loop\n"
                    "    breq .loop"::);
#endif
uint16_t StackCount(void)
   const uint8_t *p = &_end;
   while(*p == STACK_CANARY && p <= &__stack)
      p++;
   return p - &_end;
#endif
the board is a mega2650
thanks
Seattle, WA USA
Seattle, WA USA
With the Ethernet shield in use? I don't think so.
Milton Keynes UK
To paraphrase your problem:
My sketch is doing weird things. It uses the String class a lot.
Stop using the String class. It can cause memory corruption which can make your sketch do weird things.
Yes i use the ethernet shield,  Don't know how to extract the rgb value without using the string, cause when the server receive a data, it look like
(get/ 255,255,255 / HTTP1.1) So could you point me on how to extrat 255,255,255 and put them individually to r = 255 g = 255 b = 255 without using string.
Thanks again
You can use a string.  What you can't use is the String class.
If the data will look basically the same every time, then store it in a char array and then do the same thing you're doing now, find the commas and the numbers in between.
Milton Keynes UK
Use c-strings (not Strings) and the standard 'C' runtime library functions to manipulate them. The Arduino runtime environment includes a reasonably complete AVR 'C' runtime library and the Arduino reference section contains a link to the AVR documentation for it. The functions you want are declared in string.h. Since these standard 'C' runtime library functions are common to a huge number of platforms, there is an enormous quantity of documentation and tutorials on the internet explaining how to use them. To give you a start, the strtok() function lets you divide a string into tokens separated by defined characters, and there are many functions such as atoi() to parse a numeric string into the corresponding number.
thanks guys i will make a shot
Pages: [1] 2   Go Up
