« on: January 18, 2013, 03:29:24 pm » |
Hi, i'm trying to do a sketch that when receive string with 3 value R,G,B, it put the value on three pwn pin so that i could change the colors of my led strip with any browser. the sketche work like a charm, value is correctly displayed in the serial monitor but as soon as i put in the code the three analogWrite, it freeze. i put analogWrite(redPin, r); analoWrite(greenPin, g); analogWrite(bluePin, b here the partial of the code EthernetClient client = Ledserver.available(); if (client) { while (client.connected()) { if (client.available()) { char c = client.read();
//read char by char HTTP request if (readString.length() < 100) {
//store characters to string readString += c; //Serial.print(c); }
//if HTTP request has ended if (c == '\n') {
client.println("HTTP/1.1 200 OK"); //send new page client.println("Content-Type: text/html"); client.println();
client.println("<HTML>"); client.println("<HEAD>"); client.println("<TITLE>Michael led server</TITLE>"); client.println("</HEAD>"); client.println("<BODY>");
client.println("<H1>Michael test server</H1>"); client.println("<a href=\"/?on\"\">ON</a>"); client.println("<a href=\"/?off\"\">OFF</a>");
client.println("</BODY>"); client.println("</HTML>"); delay(1); //stopping client client.stop(); readString = readString.substring(5, readString.length() - 11); Serial.println(readString); //print to serial monitor for debuging
int commaIndex = readString.indexOf(','); // Search for the next comma just after the first int secondCommaIndex = readString.indexOf(',', commaIndex+1);
String firstValue = readString.substring(0, commaIndex); String secondValue = readString.substring(commaIndex+1, secondCommaIndex); String thirdValue = readString.substring(secondCommaIndex+1); // To the end of the string
int r = firstValue.toInt(); int g = secondValue.toInt(); int b = thirdValue.toInt();
Serial.println(r); Serial.println(g); Serial.println(b);
//clearing string for next read readString="";
Thanks in advance
Seattle, WA USA
Online
Seattle, WA USA
« Reply #1 on: January 18, 2013, 03:34:48 pm » |
here the partial of the code Nope. We need to see all of the code. Which pins are you using for the LEDs?
Boston area, metrowest
« Reply #2 on: January 18, 2013, 04:03:08 pm » |
Isn't this the problem?
These are ints (0x0000 to 0xFFFF), while analogWrite expects bytes (0x00 to 0xFF)?
USA
« Reply #3 on: January 18, 2013, 04:29:35 pm » |
... it freeze.
What does freeze mean in this context? Isn't this the problem?
That should produce a compiler error. I think freeze means the sketch doesn't work anymore.
« Reply #4 on: January 18, 2013, 04:51:10 pm » |
here the code //Michael sketche //Arduino server for 8 relay, stove and RGB led strip //for use with IDE 1.0 //open serial monitor to see what the arduino receives //address will look like http://192.168.1.102:84 for the ledserver //address will look like http://192.168.1.102:85 for the relayserver //for use with W5100 based ethernet shields
#include <SPI.h> #include <Ethernet.h> boolean reading = false;
// Debug mode #define DEBUG true
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address byte ip[] = { 192, 168, 2, 16 }; // ip in lan EthernetServer Ledserver(84); //Led server port EthernetServer Relayserver(85); //Relay server port
//For arduino input #define Doorbelloff "76" //Scene for pin 2 LOW (door bell On) #define Doorbellon "83" //Scene for pin 2 high (door bell OFF) #define Phoneon "81" //Scene for pin 3 LOW (telephoe ring On) #define Phoneoff "82" //Scene for pin 3 high (telephoe ring OFF) #define Doorbell 2 #define Phone 3 boolean DoorbellState = false; boolean PhoneState = false; boolean Phonedelay = false;
//Variable for debonce phone ring unsigned long pressed; int pwrtime = 600; unsigned long time; unsigned long unpressed;
char serverName[] = "192.168.2.19"; //Vera ip address EthernetClient client;
String readString;
//RGB led pin const int redPin = 9; const int greenPin = 10; const int bluePin = 11;
void setup(){ //start Ethernet Ethernet.begin(mac, ip); Ledserver.begin();
//Led pin pinMode(redPin, OUTPUT); pinMode(greenPin, OUTPUT); pinMode(bluePin, OUTPUT); //input pinMode(Doorbell, INPUT); pinMode(Phone, INPUT); //relay pin pinMode(22, OUTPUT); //output relay pin pinMode(23, OUTPUT); //output relay pin pinMode(24, OUTPUT); //output relay pin pinMode(25, OUTPUT); //output relay pin pinMode(26, OUTPUT); //output relay pin pinMode(27, OUTPUT); //output relay pin pinMode(28, OUTPUT); //output relay pin pinMode(29, OUTPUT); //output relay pin pinMode(29, OUTPUT); //output relay pin Serial.begin(9600); Serial.println("Arduino starting"); // so I can keep track of what is loaded if (Ethernet.begin(mac) == 0) { Serial.println("Failed to configure Ethernet using DHCP"); // no point in carrying on, so do nothing forevermore: while(true); } else{ Serial.println("Ethernet ready local IP:"); Serial.println(Ethernet.localIP()); } // give the Ethernet shield a second to initialize: delay(1000); }
void loop(){ Led(); Relay(); DoorbellDetection(); TelephoneDetection(); }
void Led(){ // Create a client connection EthernetClient client = Ledserver.available(); if (client) { while (client.connected()) { if (client.available()) { char c = client.read();
« Reply #5 on: January 18, 2013, 04:51:37 pm » |
[code]void Relay(){
EthernetClient client = Relayserver.available();
if (client) {
// an http request ends with a blank line boolean currentLineIsBlank = true; boolean sentHeader = false;
if(!sentHeader){ // send a standard http response header client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html"); client.println(); sentHeader = true; }
if(reading && c == ' ') reading = false; if(c == '?') reading = true; //found the ?, begin reading the info
if(reading){ Serial.print(c);
switch (c) { case '1': //relay pin 22 on digitalWrite(22, HIGH); Serial.println("Relay 1 on"); break; case '2': //relay pin 22 off digitalWrite(22, LOW); Serial.println("Relay 1 off"); break; case '3': //relay pin 23 on digitalWrite(23, HIGH); Serial.println("Relay 2 on"); break; case '4': //relay pin 23 off digitalWrite(23, LOW); Serial.println("Relay 2 off"); break; case '5': //relay pin 24 on digitalWrite(24, HIGH); Serial.println("Relay 3 on"); break; case '6': //relay pin 24 off digitalWrite(24, LOW); Serial.println("Relay 3 off"); break; case '7': //relay pin 25 on digitalWrite(25, HIGH); Serial.println("Relay 4 on"); break; case '8': //relay pin 25 off digitalWrite(25, LOW); Serial.println("Relay 4 off"); break; case '9': //relay pin 26 on digitalWrite(26, HIGH); Serial.println("Relay 5 on"); break; case '0': //relay pin 26 off digitalWrite(26, LOW); Serial.println("Relay 5 off"); break; case 'a': //relay pin 27 on digitalWrite(27, HIGH); Serial.println("Relay 6 on"); break; case 'b': //relay pin 27 off digitalWrite(27, LOW); Serial.println("Relay 6 off"); break; case 'c': //relay pin 28 on digitalWrite(28, HIGH); Serial.println("Relay 7 on"); break; case 'd': //relay pin 28 off digitalWrite(28, LOW); Serial.println("Relay 7 off"); break; case 'e': //relay pin 29 on digitalWrite(29, HIGH); Serial.println("Relay 8 on"); break; case 'f': //relay pin 29 off digitalWrite(29, LOW); Serial.println("Relay 8 off"); break; case 'g': //relay pin 29 on digitalWrite(30, HIGH); Serial.println("Foyer on"); break; case 'h': //relay pin 29 off digitalWrite(30, LOW); Serial.println("Foyer off"); break; }
if (c == '\n' && currentLineIsBlank) break;
if (c == '\n') { currentLineIsBlank = true; }else if (c != '\r') { currentLineIsBlank = false; }
delay(1); // give the web browser time to receive the data client.stop(); // close the connection: } } void DoorbellDetection(){ //// // Arduino input detection code //// if (digitalRead(Doorbell) == HIGH && DoorbellState == false) // switch on pinDevid1 is ON { if(DEBUG){Serial.println("Doorbell off");} DoorbellState = true; //Sending request to Vera sendToVera(Doorbelloff); } if (digitalRead(Doorbell) == LOW && DoorbellState == true) // switch on pinDevid1 is OFF { if(DEBUG){Serial.println("Doorbell on");} DoorbellState = false; //Sending request to Vera sendToVera(Doorbellon); } } void TelephoneDetection (){ time = millis(); //// // Listening for the pin3 state //// if (digitalRead(Phone) == HIGH && PhoneState == false) // switch on pinDevid1 is ON { PhoneState = true; if(DEBUG){Serial.println("Phone off");} sendToVera(Phoneoff); } if (digitalRead(Phone) == LOW && PhoneState == true) // switch on pinDevid1 is OFF { pressed = time, PhoneState = false;} if ((PhoneState == false) && ((time - pressed) > pwrtime)) { if(DEBUG){Serial.println("Phone on");} Phonedelay = true; sendToVera(Phoneon); } } void sendToVera(String devid){
if (client.connect(serverName, 49451)) { if(DEBUG){Serial.println("connected to Vera");}
if(DEBUG){Serial.println("sendind request");} client.print("GET /data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum="); client.print(devid); client.println(" HTTP/1.1"); client.print("Host: "); client.println(serverName); client.println("User-Agent: Arduino"); client.println(); } else { if(DEBUG){Serial.println("connection failed");} } // if there are incoming bytes available // from the server, read them and print them: if(DEBUG){ if (client.available()) { char c = client.read(); Serial.print(c); } }
if(DEBUG){Serial.println();} if(DEBUG){Serial.println("disconnecting.");} client.stop(); if (Phonedelay == true) { delay(1500); Phonedelay = false; } } [/code]
« Reply #6 on: January 18, 2013, 04:56:10 pm » |
yes i'm able to compile it, as soon as i send a http request and i compile it with the analogwrite, it freeze. but if the analogwrite isn't there, it's ok and i'm able to see the three value r,g,b in the serial. the rest of the sketches work like charm.
thanks
USA
« Reply #7 on: January 18, 2013, 05:05:08 pm » |
You maybe running out of RAM. Insert the following code into the sketch and print ( Serial.println()) the result of StackCount(). Also, what board are you using? #define STACK_CHECK_BUILT
#ifdef STACK_CHECK_BUILT extern uint8_t _end; extern uint8_t __stack; #define STACK_CANARY 0xc5 void StackPaint(void) __attribute__ ((naked)) __attribute__ ((section (".init1"))); void StackPaint(void) { #if 0 uint8_t *p = &_end; while(p <= &__stack) { *p = STACK_CANARY; p++; } #else __asm volatile (" ldi r30,lo8(_end)\n" " ldi r31,hi8(_end)\n" " ldi r24,lo8(0xc5)\n" // STACK_CANARY = 0xc5 " ldi r25,hi8(__stack)\n" " rjmp .cmp\n" ".loop:\n" " st Z+,r24\n" ".cmp:\n" " cpi r30,lo8(__stack)\n" " cpc r31,r25\n" " brlo .loop\n" " breq .loop"::); #endif } //---------------------------------------------------------------------------
uint16_t StackCount(void) { const uint8_t *p = &_end; while(*p == STACK_CANARY && p <= &__stack) p++; return p - &_end; } //--------------------------------------------------------------------------- #endif
« Reply #8 on: January 18, 2013, 05:05:46 pm » |
the board is a mega2650
thanks
Seattle, WA USA
Online
Seattle, WA USA
« Reply #9 on: January 18, 2013, 05:29:05 pm » |
const int greenPin = 10; With the Ethernet shield in use? I don't think so.
UK
« Reply #10 on: January 18, 2013, 05:41:29 pm » |
To paraphrase your problem: My sketch is doing weird things. It uses the String class a lot.
Stop using the String class. It can cause memory corruption which can make your sketch do weird things.
« Reply #11 on: January 18, 2013, 05:49:13 pm » |
Yes i use the ethernet shield, Don't know how to extract the rgb value without using the string, cause when the server receive a data, it look like (get/ 255,255,255 / HTTP1.1) So could you point me on how to extrat 255,255,255 and put them individually to r = 255 g = 255 b = 255 without using string.
Thanks again
« Reply #12 on: January 18, 2013, 06:18:47 pm » |
You can use a string. What you can't use is the String class.
If the data will look basically the same every time, then store it in a char array and then do the same thing you're doing now, find the commas and the numbers in between.
UK
« Reply #13 on: January 18, 2013, 09:22:24 pm » |
Use c-strings (not Strings) and the standard 'C' runtime library functions to manipulate them. The Arduino runtime environment includes a reasonably complete AVR 'C' runtime library and the Arduino reference section contains a link to the AVR documentation for it. The functions you want are declared in string.h. Since these standard 'C' runtime library functions are common to a huge number of platforms, there is an enormous quantity of documentation and tutorials on the internet explaining how to use them. To give you a start, the strtok() function lets you divide a string into tokens separated by defined characters, and there are many functions such as atoi() to parse a numeric string into the corresponding number.
« Reply #14 on: January 19, 2013, 09:52:02 am » |
thanks guys i will make a shot
