Loading...
Pages: [1]   Go Down
Author Topic: L3G4200D gyroscope  (Read 268 times)
Offline Offline
Newbie
View Profile
Hi guys,
I am trying to hook up a L3G4200D gyroscope with an Arduino UNO system. I found some code online that is specific for this gyroscope but am having some difficulties. I can't seem to get an output other than "000". I think there is a problem with the I2C communication between the the gyro and Arduino but I am not sure. Does anyone know what might be the problem with our code or something we could try to fix our problem.
The code we are using is below:
Code:
#define GYROSCOPE 0x69
#include <L3G.h>
#include <Wire.h>
L3G gyro;
int x, y, z;
int L3G4200D_Address = 107;
byte buff[6];
    Wire.begin();
 if (!gyro.init(L3G4200D_DEVICE, L3G_SA0_LOW))
    Serial.println("Failed to autodetect gyro type!");
    while (1);
  gyro.enableDefault();
    // Delay the flow
    Wire.beginTransmission(107);
    Wire.print(0x1D);
    Wire.endTransmission();
    Wire.requestFrom(107,6);
    int i = 0;
    while(Wire.available()) {
       buff[i] = Wire.read();
       i++;
    // Convert to ints
    x = (((int)buff[1]) << 8) | buff[0];
    y = (((int)buff[3]) << 8) | buff[2];
    z = (((int)buff[5]) << 8) | buff[4];
    Serial.print(x);
    Serial.print(" ");
    Serial.print(y);
    Serial.print(" ");
    Serial.print(z);
    Serial.print("\n");
Thx!
« Last Edit: January 18, 2013, 03:31:23 pm by asmehta » Logged
Offline Offline
God Member
View Profile
There are several example programs for accessing this device.
Just be aware that some of them don't actually work.
I suggest you download several of them and compare them carefully
with your code.
I find the whole scheme of when to use beginTransmission() and
endTransmission(),  and when not to use them,   to be highly
counter-intuitive  and needs a bit of tinkering to get it to work.
Logged
Offline Offline
Edison Member
View Profile
Are you communicating with the sensor at all ?
First things first, use the i2c_scanner : http://playground.arduino.cc/Main/I2cScanner
At the sparkfun page https://www.sparkfun.com/products/10612
is a link to a bildr tutorial.
You could try that, but I think the code is wrong.
There is a small error in that code, since it waits for Wire.available() and that is not how it should be used.
« Last Edit: January 20, 2013, 04:18:55 am by Krodal » Logged
Pages: [1]   Go Up
Print
Jump to:
