Loading...
Pages: [1]   Go Down
Author Topic: Ethernet only working in local network  (Read 285 times)
Offline Offline
Newbie
View Profile
Hello,
i'm using standard EthernetShield on multiple arduino boards (diecimila, duemilanove with atmega328, uno, mega 2560) and experiencing strange problem.
Example WebServer script works without problems, dhcp works, i can ping arduino but Web Client examples only works in local network, i don't get any response from servers outside it.
I did manage to successfully run ArduinoCosm (https://github.com/cosm/cosm-arduino) example, it posted values to Cosm.
Tried all of the arduinos, tried connecting without router but nothing seems to help. Arduino get's ip from dhcp (tried manualy specifying ip, dns, gateway, netmask), makes request, but that's all).
Any ideas?
regards,
Martin
Logged
0
Offline Offline
God Member
Get Bitlash: http://bitlash.net
View Profile
Sounds like the gateway configuration needs checking.  You'll get better help if you post your code.
-br
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Simple client test code you can try.
Code:
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
    client.println("Host: web.comporium.net");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
@billroy
code was example from ethernet library, unmodifided.
Code:
  Web client
 This sketch connects to a website (http://www.google.com)
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 18 Dec 2009
 modified 9 Apr 2012
 by David A. Mellis
#include <SPI.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
IPAddress server(173,194,33,104); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
    for(;;)
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.0");
    client.println();
  else {
    // kf you didn't get a connection to the server:
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    client.stop();
    // do nothing forevermore:
    for(;;)
@zoomkat
Output from posted code is:
Code:
connection failed
disconnecting.
But if i change serverName to
Code:
IPAddress server(192,168,1,2);
, i do get proper response. Tried even in 1.0.1 IDE, but that doesnt change anything.
Will try to inspect raw tcp traffic.
thanks,
Martin
Logged
0
Offline Offline
God Member
View Profile
Still smells like a gateway configuration issue.  A quick test might be to explicitly initialize the gateway using the "Ethernet.begin(mac, ip, dns, gateway); " form of the ethernet.begin call.
     http://arduino.cc/en/Reference/EthernetBegin
-br
Logged
Offline Offline
Newbie
View Profile
Tried that but doesn't change anything.
Looks like networking error to me too, but i don't now how to debug it on arduino.
thanks,
Martin
Logged
0
Offline Offline
God Member
View Profile
Your earlier post about capturing the network traffic is a good next step.  WireShark isn't too hard to set up if you have a PC on that network segment.
The ARP traffic should be highly revealing...
-br
Logged
UK
Offline Offline
Sr. Member
View Profile
@billroy
Code:
You said unmodified, but you do realise you have to modify this part to set your device MAC address?
The other thing is, might you have your router set for security where you need to specify allowed MAC addresses?
« Last Edit: January 19, 2013, 05:30:17 pm by tack » Logged
0
Offline Offline
God Member
View Profile
The shield has always worked fine for me with the 0xDEADBEEF MAC address, as long as there's not another node on the same LAN with the same address.
-br
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Client test code that allows for specifying ip addresses.
Code:
//zoomkat 4-04-12
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
//the arduino lan IP address { 192, 168, 1, 102 } may need
//to be modified modified to work with your router.
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 }; // ip in lan assigned to arduino
//byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
//byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte myserver[] = { 208, 104, 2, 86 }; // zoomkat web page server IP address
void setup(){
  Ethernet.begin(mac, ip);
  //Ethernet.begin(mac, ip, gateway, gateway, subnet);
  Serial.println("Better client test 4/04/12"); // so I can keep track of what is loaded
void loop(){
  if (client.connect(myserver, 80)) {  //starts client connection, checks for connection
  else {
Logged
Pages: [1]   Go Up
Print
Jump to:
