Topic: How can one read an integer from serial as fast as possible? (Read 2519 times) previous topic - next topic
P1X3
As I mentioned earlier code is no polished.
I actually cast data[0] data[1] as bytes
Code: [Select]
    motor.write((byte)(data[0]));
    servo.write((byte)(data[1]));
robtillaart
[not read all the posts]
Quote
...serial as fast as possible?
The first thing I would do to is use a higher baud-rate if possible 115200 is 12x faster than 9600
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
P1X3
For those that are kinda interested here is an update. Everything is going according to the plan. I'll leave the code that works for me as of today. Still not polished and I plan to send one byte for motor speed and steering. Also have to upgrade esc and motor along with setting up dual servo for steering. Plus some CNC milling for custom mounts. But really happy as of now
Code: [Select]
#include <Servo.h>
//#define DEBUG
Servo motor;
Servo servo;
char data[2];
boolean serial_start = false;
boolean serial_end = false;
int index = 0;
byte startchar = 254;
byte endchar = 255;
 Serial.println("Waiting...");
 delay(2000);
 Serial.println("Arming...");
 motor.attach(2);
 servo.attach(10);
 motor.write(0);
 delay(2000);
 Serial.println("Armed");
// Receives {CC} where C is a char
// Only CC is stored in data
 while(Serial.available() > 0)
   byte readChar = Serial.read();
   #ifdef DEBUG
   Serial.print("Received: ");
   Serial.println(readChar);
   #endif
   if (readChar == startchar)
     serial_start = true;
     index = 0;
     #ifdef DEBUG
       Serial.println("Starting char received");
     #endif
   else if (readChar == endchar)
     serial_end = true;
     #ifdef DEBUG
       Serial.println("Ending char received");
     #endif
     #ifdef DEBUG
       Serial.println("Data char received");
     #endif
     if (index <= 1)
      data[index] = readChar;
      #ifdef DEBUG
       Serial.print("Data char assigned to index ");
       Serial.println(index);
      #endif
      index++;
 if (serial_start && serial_end)
   #ifdef DEBUG
     Serial.print("Packet received with data [");
     Serial.print(data[0]);
     Serial.print(",");
     Serial.print(data[1]);
     Serial.println("]");
   #endif
   Serial.print("Setting motor and servo to: ");
   Serial.print((byte)(data[0]));
   Serial.print(" ");
   Serial.println((byte)(data[1]));
   serial_end = false;
And here is C# code that sends xbox input to arduino. It's a mess and I should make it better, but it will happen in time.
Code: [Select]
       void timer1_Tick(object sender, EventArgs e)
           // Update controller data
           gs.Update();
           float leftStickX = gs.LeftStick.Position.X;
           float leftStickY = gs.LeftStick.Position.Y;
           int leftStickXINT = (int)(leftStickX * 1000);
           int leftStickYINT = (int)(leftStickY * 1000);
           if (leftStickYINT < 0)
               leftStickYINT = 0;
           seriesX.Points.Clear();
           seriesY.Points.Clear();
           seriesX.Points.Add(leftStickXINT);
           seriesY.Points.Add(leftStickYINT);
           lblControllerX.Text = leftStickXINT.ToString();
           lblControllerY.Text = leftStickYINT.ToString();
           seriesX2.Points.Clear();
           seriesY2.Points.Clear();
           seriesX2.Points.Add(leftStickX);
           seriesY2.Points.Add(leftStickY);
           lblControllerX2.Text = leftStickX.ToString();
           lblControllerY2.Text = leftStickY.ToString();
           byte motorSpeed = Map(leftStickYINT, 0, 1000, 94, 100 + 1);
           byte steerValue = Map(leftStickXINT, -1000, 1000, 180, 0 );
           lblRCThrottle.Text = motorSpeed.ToString();
           progressBar1.Value = Map(leftStickYINT, 0, 1000, 0, 100 + 1);
           lblRCSteer.Text = steerValue.ToString();
           if (sp.IsOpen && (motorSpeed != oldSpeed || steerValue != oldSteer))
               sp.Write(new byte[] { 254, motorSpeed, steerValue, 255 }, 0, 4);
               oldSpeed = motorSpeed;
               oldSteer = steerValue;
[font=Verdana]LOWER YOUR VOLUME AT THE END!!! I WARNED YOU!![/font][/size]
http://www.youtube.com/watch?v=K6s6QX5N2Mg
Enjoy my engrish
