Topic: Which arduino mega ? (Read 847 times) previous topic - next topic
PGT
never used a mega before, and so i notice there are two versions
I like to use the normal arduino IDE to program it in c++
As i understand it the adk version is for android devices (which seams cool too) however would it still be programmable by the normal IDE ?
AND this is important to me wont i loose pins because of its extra functionality, as i am planning to control 50 I/O ports with it
(if you've seen my prev post i'm thinking of using 3 of these resulting in 150 I/O pins)
PaulS
Yes, both versions are.
Did you look at the Products page? Both Mega versions have 54 I/O pins. The ADK has an extra chip that handles the USB Host duties. That does not require the use of any digital pins.
CrossRoads
#2
Jan 19, 2013, 12:50 am Last Edit: Jan 19, 2013, 12:53 am by CrossRoads Reason: 1
"i'm thinking of using 3 of these resulting in 150 I/O pins"
Can't handle a few shift registers, so you're going to spend $210 on boards instead?
http://www.mouser.com/ProductDetail/Arduino/A000069/?qs=%2fha2pyFadujj3xA%2fzo7HllO9RZ0StfazAnaxISN%2fW8vi4I1Htytw4Q%3d%3d
Good luck with the project.
PGT
Well actually i have been thinking seriously about the shift registers board too, and a lot of thanks for that !.
Though i think programmable boards might allow me to add some more fun, extra tricks
Also i know how to program them so it would speedup building and i might have good use for them after this is over.
I can use 1 smaller arduino board to drive 2 mega versions it would be under 130 euro total.
Excluded other electronics
If it where a permanent thing i would have gone for your version.
JohnHoward
For the uninitiated, what does that mean?  The link seems to be simply to a board for sale, I don't get the 'handle a fiew shift registers' comment.
CrossRoads
It goes with the other thread, where building up a few shift registers to control the 150 IO pins was discussed.
I was pointing out the cost of 3 boards.  Building a simple design with 20 shift registers all daisy chained would be far less expensive.
Send out 20 bytes at a time via SPI commnands when an output needed changing.
Buying 3 cards for the IO, writing up a protocol to send messages for driving the IO, thats another way to go.
