Loading...
Pages: [1]   Go Down
Author Topic: TFT 3.2 Touch Arduino MEGA Ghost Lines!!!  (Read 692 times)
Caracas - Venezuela
Offline Offline
Jr. Member
Arduino Experimental User
View Profile
Greattings,
I have bought a tft 3,2 touch screen from saintsmart
http://www.sainsmart.com/arduino-compatibles/atmel-avr-board/sainsmart-mega2560-board-3-5-tft-lcd-module-display-shield-kit-for-atmel-atmega-avr-16au-atmega8u2.html
it include the shield for plug in it to the arduino Mega 2560,
I have downloaded all documentation, libraries, etc.
The problem is the following: when I run the example coming with the library, the screen seems to make interferece  and destroy the image on screen, appear bad lines, and looks really bad.
The libraries I have used to test the screen are: ITDB02_Graph16.h and the new version of this library, called UTFT.
I have recorded a video on youtube, and the example is loaded from library UTFT > UTFT_Demo_320x240. There you can see that the program runs correctly, but the image on screen is awful.
Here is the video of my screen working...
And here is the demostration video of the original screen of the manufacturer...
I thinks there is a big difference....
The white lines are statics.
I have do all I can do to solve the problem, looking for a solution on internet, etc. And I need to know if the screen is broken or can be repaired
Thanks in advance,
Nataly Lopez
« Last Edit: January 18, 2013, 08:13:03 pm by Nataly » Logged
You can do it, If you want!
The Netherlands
Offline Offline
Sr. Member
View Profile
Did you check your power supply ?
Is it instable ?
Is it within specs for both Arduino and displayshield ?
Logged
0
Offline Offline
Sr. Member
what?
View Profile
ITDB02_Graph16.h is redundant, just use UTFT
but this looks like a bad display, ask sainsmart for a replacement
Logged
Caracas - Venezuela
Offline Offline
Jr. Member
View Profile
smiley-sad  ... smiley-cry
Logged
Philippines
Offline Offline
Newbie
View Profile
My TFT 3.2 is showing some display problems as well. I'm trying to simply get two images to display alternately (each desired image is attached. A "Tower" and "Logo"). Usually the first two rounds work fine, but once the "Logo" appears a third time, I get a distorted image (example shown in the http://www.youtube.com/watch?v=6QjzpIKqI8k&feature=youtu.be). And when loading the images onto the TFT the screen gets all "crackly."
I am using an Arduino MEGA ADK with UTFT, UTFT_tinyFAT, and UTouch libraries. I've tried rewiring the apparatus and using a couple different power sources. What's weird is that when it was first connected it displayed just fine, but after a couple of days started becoming errant.
Anyone else ever experienced this or know what might be going on? Thanks.
Logged
Offline Offline
Newbie
View Profile
yeah,i think so, this looks like a bad display, ask sainsmart for a replacement, thanks for your sharing
Logged
UK
Offline Offline
Newbie
View Profile
Hello, it may sound stupid, but did you remove the protective screen film that the screen comes with?
Else it's probably something wrong with the controller.
Logged
Tonto el que no entienda
Philippines
Offline Offline
Newbie
View Profile
Thanks for the replies. Removing the protective screen didn't do anything, and I tried using a second, new TFT screen that gave me the same headaches.
Logged
Pages: [1]   Go Up
Print
Jump to:
