Loading...
Pages: [1]   Go Down
Author Topic: noInterrupts() and Serial.write issues  (Read 219 times)
Offline Offline
Full Member
View Profile
In my program I am getting two different behaviors regarding Serial writes depending if noInterrupts() is present or not, *even with Interrupts() not present in the code*
1) If noInterrupts() is present, I get a few characters and then the serial write appears to freeze
2) If noInterrupts() is commented out, the serial write functions properly
Any idea what is going on?  Are serial writes connected to interrupts somehow?
What I'm trying to do is execute an interrupt on an ADC complete while it is free running.
With a prescalar of 128 on an Arduino Uno (16MHz), I expect an interrupt every 100us or so (since it takes 13 clock cycles).
In case anyone wants to see code, I put a stripped down version below.  Oh, and I'm using version 1.03 of the IDE
Thanks in advance,
memotick
Code:
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
// Every Arduino program must have a setup section
  // ***********here is the problem area *********
  // noInterrupts();
  //clear ADCSRA and ADCSRB registers
  ADCSRA = 0;
  ADCSRB = 0;
  // ADCSRA: page 265
  // ADEN: Enable ADC
  sbi(ADCSRA, ADEN);
  // ADATE: ADC auto trigger enable
  sbi(ADCSRA, ADATE);
  // ADMUX page 264
  // select ADC0 channel
  cbi(ADMUX, MUX3);
  cbi(ADMUX, MUX2);
  cbi(ADMUX, MUX1);
  cbi(ADMUX, MUX0);
  // Quiet ADC inputs
  // Check page 266 of the ATmega328p datasheet
  // for more information.
  sbi(DIDR0,ADC5D);
  sbi(DIDR0,ADC4D);
  sbi(DIDR0,ADC3D);
  sbi(DIDR0,ADC2D);
  sbi(DIDR0,ADC1D);
  sbi(DIDR0,ADC0D);
  // Internal pull-ups interfere with the ADC. disable the pull-up on the
  // pin ifit's being used for ADC. either writing 0 to the port register
  // or setting it to output should be enough to disable pull-ups.
  DDRC = 0x00;
  // Set ADC prescalar to 128.  Thus one conversion every
  // (128*13)/16MHz = 104us
  sbi(ADCSRA, ADPS2);
  sbi(ADCSRA, ADPS1);
  sbi(ADCSRA, ADPS0);
  // ADSCRB: page 267
  // ADTST2:0 : ADC trigger select 000=Free running
  cbi(ADCSRB,ADTS2);
  cbi(ADCSRB,ADTS1);
  cbi(ADCSRB,ADTS0);
  Serial.begin(57600);
  // ADCSRA: page 265
  // ADSC: ADC start conversion and allow ISR to run
  sbi(ADCSRA, ADSC);
  //sei();//enable interrupts
////Interrupt Service Routine (ISR)
ISR(ADC_vect) {
  //when new ADC value ready, do something here
  Serial.write("Made it in the loop\n");
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Serial data is sent using interrupts. Turning interrupts off prevents sending serial data. There's nothing complicated about it.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
This is normal behaviour. The hardware serial library uses interrupts to move data to and from software memory buffers and the USART hardware, so as nointerrupts disables ALL interrupts serial data stops, millis() timer interrupts stops and any user interrupts or pin change interrupts you are using are all prevented from execution until you issue a Interrupts command.
Quote
Again as explained above.
Lefty
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Apart from this issue:
Code:
  // noInterrupts();
  // ADCSRA: page 265
  sbi(ADCSRA, ADSC);
You are hoping for an ADC interrupt but have interrupts off (if you call noInterrupts).
Logged
Offline Offline
Full Member
View Profile
Code:
  // noInterrupts();
  // ADCSRA: page 265
  sbi(ADCSRA, ADSC);
Nick,
     Wow, you pay attention to detail!
Logged
Pages: [1]   Go Up
Print
Jump to:
