Loading...
Pages: [1]   Go Down
Author Topic: Arduino Micro and MIDI Library  (Read 268 times)
Offline Offline
Newbie
View Profile
Hi all,
I recently bought a Arduino Micro board. I intent to use it for a midi footcontroller project. I tried a few basic sketches and the confirmed the board functions OK.
I want to use Franky's MIDI library for this project. The midi over serial is also an other option. Anyways, I tried a few basic codes for sending the midi message, but non of them working. Do I need to modify the code especially for arduino MICRO? All documentation on arduino Micro is based on Leonardo board, and it seems like some parts are out of date or doesnot really apply to MICRO board. I would really appreciate any help on this.
Midi out; pin3 goes to arduino ground, pin4 goes to 5v with a 220ohm resistor, pin5 goes to arduino TX with a 220ohm resistor.
Button is connected to arduino digital 2.
I tested the following codes but
The first code I tried:
Code:
#include <MIDI.h>
// set pin numbers:
const int ledPin =  13;      // the number of the LED pin
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  MIDI.begin();
void loop(){
    MIDI.sendNoteOn(42,127,1);
    MIDI.sendNoteOff(42,0,1);
    MIDI.sendNoteOn(25,127,1);
    MIDI.sendNoteOff(25,0,1);
This code is constantly sending note on/off messages but midi in monitor displays nothing.
The second code is to send to note when a button is pressed. The led flashes when is pressed.
Code:
#include <MIDI.h>
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  MIDI.begin(1);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    digitalWrite(ledPin,HIGH);
    MIDI.sendNoteOn(42,127,1);  // Send a Note (pitch 42, velo 127 on channel 1)
    delay(1000);         // Wait for a second
    MIDI.sendNoteOff(42,0,1);   // Stop the note
    digitalWrite(ledPin,LOW);
Button is working and the led is flashing when it is pressed. But again no signal in midi monitor.
The final code I tried is just using serial.write and doesnt include the midi library. This also didnt work. Again No midi signals
Code:
const int button1 = 2;     // the number of the pushbutton pin
  pinMode(button1, INPUT);
  Serial.begin(31250);
void loop(){
  buttonState = digitalRead(button1);
    noteOn(0x90, 0x1E, 0x45);
    delay(100);
void noteOn(int cmd, int pitch, int velocity) {
  Serial.write(cmd);
  Serial.write(pitch);
  Serial.write(velocity);
I checked my midi cable and it is working perfectly. MIDI in port at my soundcard also functions OK with other devices. So all external factors are isolated.
Thanks in advance...
Logged
Offline Offline
Newbie
View Profile
I'm having a similar issue with my UNO.   trying to send MIDI data and I get nothing.  wish I could help.  I'm using the Roland UM1 MIDI/USB cable and MIDIOX, very simple MIDI commands yeild nothing.
Logged
Pages: [1]   Go Up
Print
Jump to:
