Topic: Record audio and save as .wav with on board mic (Read 3156 times) previous topic - next topic
mikejonesab1
So I would like to record audio and save it as a .wav file onto a SD card with an onboard mic. I was thinking of using this: http://www.mouser.com/new/stmicroelectronics/stmicromp34db01/
How would I go about interfacing? Do I need a preamp? Thanks in advance.
--Mike
CrossRoads
Looking at the larger setup:  The arduino records 10-bit analog at ~10KHz, for <5KHz bandwidth. There will be pauses in the sampling as the SD card is written to.
Will those limitations be okay?
mikejonesab1
How often?
And if that was a problem how would you get around that?
CrossRoads
I'd say every 512 bytes, maybe every 1024 tops, because of the limited SRAM available for data buffering.
mikejonesab1
That will be fine. How should I/can I interface with the microphone I linked above?
CrossRoads
Connect it up per page 12 of the data sheet.
Power is 1.8V.
Clock speed - typical is 2.4MHz. If you use SPI at 1/4 processor speed, that is 2MHz.
You will have 512 bytes of data every couple of mS.
SD uses SPI to write data to the card.
You can try a loop to read the data
for (x=0; x<512; x=x+1){
dataArray[x] = SPI.transfer(0); //MOSI connects to nothing,  MISO connects mic data pin, SCK connects to mic CLK pin
then use SD library to send it to the card.
mikejonesab1
