Topic: Recommendations on getting things to blink? (Read 942 times) previous topic - next topic
mewshi
Hey there, everyone!  I'm trying to create a project that requires lights to blink after a button is pressed, but it requires that buttons still be 'listened' for.  I can design something using interrupts, but I would much prefer to just turn on a digital output and have some auxiliary circuitry to handle the blinking part, rather than it being handled by the software, since that is ridiculously expensive to get done.
So, any recommendations or suggestions on what sort of components I can use to get the blinking done?
Osgeld
Erni
http://www.cappels.org/dproj/simplest_LED_flasher/Simplest_LED_Flasher_Circuit.html
or even simpler, yoy can buy flashing LED's
fungus
Huh? Software was free last time I checked.
Delta_G
Look at the example called blink without delay.  Understand how it works.  Welcome yourself to the world of non-blocking code.
Ad hoc, ad loc, and quid pro quo.  So little time - so much to know!  ~Jeremy Hillary Boob Ph.D
MAS3
Costs can be much higher than any monetary expression can describe.
To blink using "blink", might cost you too much time to see a key being pressed.
So Delta_G's solution is the best.
Delay is a waste in all kinds of meaning of that word.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
marco_c
Don't use delay then.  Look at the blink without delay example.  There is a lot of processing power that you are wasting with delay().
Arduino Libraries http://arduinocode.codeplex.com
Parola for Arduino http://parola.codeplex.com
cjdelphi
