Loading...
Pages: [1]   Go Down
Author Topic: Serial.print() of a 64-bit DOUBLE  (Read 1026 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I've read in the Reference section that the DOUBLE data type on the Due is a 64-bit variable.  Unfortunately, the Serial.print won't handle a 64-bit variable.  I haven't been able to print out a uint64_t either.
Any ideas of how to print this?
I've looked into bit shifting the top 32-bits into an unsigned int, and then printing the high 32-bits followed by the low 32-bits, but apparently the bit shift operator defaults to a 32-bit operation as well.
The reason I'm trying to do this is because I stuck a 16 GB SD card into my wifi shield and can read it using the SD library, but it won't show the correct size of the SD card because it's so large.  The unsigned int will only show up to ~4 GB.  (0xFFFFFFFF = 4294967295 decimal).
Time to program the BigInt class?
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Made this code for printing int64_t and uint64_t some time ago on an UNO - IDE 0.22;
Should work for DUE too I guess, but is not tested other than on my UNO (so all disclaimers apply smiley-wink.
Just received my first DUE yesterday not downloaded the IDE for that to play with it.
Add this snippet to print.cpp to print the 64 bit integers, mind you! a simple sketch adds about 8KB!
Snippet for print.cpp
Code:
#ifdef SUPPORT_LONGLONG
void Print::println(int64_t n, uint8_t base)
  print(n, base);
  println();
void Print::print(int64_t n, uint8_t base)
  if (n < 0)
    print((char)'-');
    n = -n;
  if (base < 2) base = 2;
  print((uint64_t)n, base);
void Print::println(uint64_t n, uint8_t base)
  print(n, base);
  println();
void Print::print(uint64_t n, uint8_t base)
  printLLNumber(n, base);
void Print::printLLNumber(uint64_t n, uint8_t base)
  unsigned char buf[16 * sizeof(long)];
  unsigned int i = 0;
  if (n == 0)
    print((char)'0');
    return;
  while (n > 0)
    buf[i++] = n % base;
    n /= base;
  for (; i > 0; i--)
    print((char) (buf[i - 1] < 10 ?
      '0' + buf[i - 1] :
      'A' + buf[i - 1] - 10));
#endif
patched version of print.h
Code:
  Print.h - Base class that provides print() and println()
  Copyright (c) 2008 David A. Mellis.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#ifndef Print_h
#define Print_h
#include <inttypes.h>
#include <stdio.h> // for size_t
#include "WString.h"
#define DEC 10
#define HEX 16
#define OCT 8
#define BIN 2
#define BYTE 0
// uncomment next line to support printing of 64 bit ints.
#define SUPPORT_LONGLONG
class Print
  private:
    void printNumber(unsigned long, uint8_t);
void printLLNumber(uint64_t, uint8_t );
#endif
    void printFloat(double, uint8_t);
  public:
    virtual void write(uint8_t) = 0;
    virtual void write(const char *str);
    virtual void write(const uint8_t *buffer, size_t size);
    void print(const String &);
    void print(const char[]);
    void print(char, uint8_t = BYTE);
    void print(unsigned char, uint8_t = BYTE);
    void print(int, uint8_t = DEC);
    void print(unsigned int, uint8_t = DEC);
    void print(long, uint8_t = DEC);
    void print(unsigned long, uint8_t = DEC);
    void print(double, uint8_t = 2);
    void println(const String &s);
    void println(const char[]);
    void println(char, uint8_t = BYTE);
    void println(unsigned char, uint8_t = BYTE);
    void println(int, uint8_t = DEC);
    void println(unsigned int, uint8_t = DEC);
    void println(long, uint8_t = DEC);
    void println(unsigned long, uint8_t = DEC);
    void println(double, uint8_t = 2);
    void println(void);
void println(int64_t, uint8_t = DEC);
void print(int64_t, uint8_t = DEC);
void println(uint64_t, uint8_t = DEC);
void print(uint64_t, uint8_t = DEC);
#endif
#endif
Can you confirm this works on DUE?
Code:
  Serial.print(1000000000000LL, 10);
  Serial.print(-1000000000000LL, 10);
  Serial.println(1000000000000LL, 10);
  Serial.println(-1000000000000LL, 10);
void loop(){}
printing doubles I did not investigate yet but can be tackled in the same way as printing floats are handled using the printing of longs (on UNO)
« Last Edit: January 19, 2013, 02:20:32 pm by robtillaart » Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Netherlands
Offline Offline
Tesla Member
View Profile
Just had a look at the 1.0 IDE version, (still not downloaded DUE IDE )
The code should be extended with size_t return values, and some math to calc the right value ...
Logged
Rob Tillaart
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I made those modifications to print.cpp and print.h, and it worked just great on my DUE.  I am now able to display the true size of my 16 GB SD Card:
Code:
Volume size (bytes): 15923150848
I didn't change the methods to size_t though, it worked fine without that change.  (I did try it, and it threw a bunch of errors, so I left them as void).
As you noted, the change does add about 8KB, but heck, I've got a DUE with 512K program memory, so I can spare the extra 8K.  Woot.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
good to hear it works!
Is the performance fast enough?
can you test printing 100 int64's @115200 and time it with micros?
and do the same with 100 int32's?
The size_t thing should be solved someday but apparently not now smiley-wink
You also stated that you were not able to print a double ? but floats works?
(there is definitely no x.yyyE-nnn engineering format yet)
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
Did some rework on the printing of int64's.
Most important, I replaced the % math with less expensive code => test app size went from 9766 => 6966
+ added constrain for base
+ merged the printLLnumber into print(uint64_t, int); as that was the only one that called.
still todo
- need to support base = BYTE. not supported in 1.0 so will not be implemented. (patched below)
- include size_t  for 1.0 version
Code:
void Print::println(int64_t number, uint8_t base)
  print(number, base);
  println();
void Print::print(int64_t number, uint8_t base)
  if (number < 0)
    write('-');
    number = -number;
  print((uint64_t)number, base);
void Print::println(uint64_t number, uint8_t base)
  println();
void Print::print(uint64_t number, uint8_t base)
  unsigned char buf[64];
  uint8_t i = 0;
  if (number == 0)
    print((char)'0');
    return;
  else if (base > 16) base = 16;
  while (number > 0)
    uint64_t q = number/base;
    buf[i++] = number - q*base;
    number = q;
  for (; i > 0; i--)
    write((char) (buf[i - 1] < 10 ?
      '0' + buf[i - 1] :
#endif
update ==> remove printLLnumber() from print.h too
update ==> I had already patched print.cpp  to use uint8_t for param base in all functions. [change to int will solve this]
« Last Edit: January 20, 2013, 08:29:21 am by robtillaart » Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
extra code to append to for 1.0x print.cpp
Code:
size_t Print::println(int64_t number, int base)
  size_t n = 0;
  n += print(number, base);
  n += println();
  return n;
size_t Print::print(int64_t number, int base)
  size_t n = 0;
  if (number < 0)
    write('-');
number = -number;
n++;
  n += print((uint64_t)number, base);
  return n;
size_t Print::println(uint64_t number, int base)
  size_t n = 0;
  n += println();
  return n;
size_t Print::print(uint64_t number, int base)
  size_t n = 0;
  uint8_t i = 0;
  if (number == 0)
    n += print((char)'0');
    return n;
  while (number > 0)
    number = q;
  for (; i > 0; i--)
    n += write((char) (buf[i - 1] < 10 ?
      '0' + buf[i - 1] :
   return n;
#endif
additional code for 1.0x print.h
Code:
// uncomment next line for int64 support
size_t println(int64_t, int = DEC);
size_t print(int64_t, int = DEC);
size_t println(uint64_t, int = DEC);
size_t print(uint64_t, int = DEC);
#endif
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
robtillaart, thanks for your great code
i test with uint64_t a = 4294329243;
it's can display in DEC, BIN, OCT, HEX all correct.
thank you very much.   smiley
Code:
  size_t n = 0;
  n += println();
  return n;
  size_t n = 0;
  if (number < 0)
    write('-');
number = -number;
n++;
  return n;
  size_t n = 0;
  n += println();
  return n;
  size_t n = 0;
  uint8_t i = 0;
  if (number == 0)
    return n;
  while (number > 0)
    number = q;
  for (; i > 0; i--)
      '0' + buf[i - 1] :
   return n;
#endif
Code:
#endif
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
you're welcome !
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
