Topic: I2C interface with DAC6573- RESOLVED (Read 2670 times) previous topic - next topic
ichris93
Jan 19, 2013, 07:21 am Last Edit: Jan 21, 2013, 09:29 pm by ichris93 Reason: 1
Hi guys,
I am trying to communicate with a DAC6574 but I get the same I2C sequence no matter how I change the code. It looks like the attached image.
Do you need the code for it?  This is the Arduino sketch
Code: [Select]
#include <Wire.h>
#include <DAC6573.h>
DAC6573 myDAC6573(DAC6573_DEFAULT_ADDRESS);
   Wire.begin(); //Start the I2C bus
   Serial.begin (9600);
 byte channel=1;
 static word DAC;
 static int delta=10;
 Serial.print("DAC");
 Serial.println(DAC);
 delay(100);
 myDAC6573.DAC6573_SetChannel(DAC,channel);
 DAC=DAC+delta;
 if (DAC > 1020) {delta = -10;}
 if (DAC < 20) {delta = 10;}
I will post library too if it is needed.
robtillaart
Where do you read the value of the DAC?
Which statement does that?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
PaulS
If you include header files in the library header file, it is not necessary to include them in the library source file, too.
ichris93
I set the value.
robtillaart
Sorry, stupid slip of the mind  :smiley-red:
Rob Tillaart
ichris93
That wouldn't create a problem though, right?
robtillaart
Lets try another "stupid "question ;)
How are the address lines of the chip connected?
Are they GND?
Rob Tillaart
ichris93
Are they GND?
If "stupid" questions get me to a solution, it is no problem ;)
Yes, they are all connected to GND.
ichris93
I got it working by changing the A0 pin to 5V and then changing the address.
Thanks guys.
robtillaart
one question remains, could you test:
If you GND both address lines and you use the I2C scanner of nick Gammon, does it find the device?
similar for other address pin combinations (high/low)?
- http://www.gammon.com.au/forum/?id=10896 - search for scanner (~@ 80% of the page)
Rob Tillaart
ichris93
Thank you for the source.  Yes it does find it with all of them low and the same address, so I do not know why it didn't work with all of them low.
robtillaart
loose connections, happens all around the world ;)
Rob Tillaart
ichris93
No, because it doesn't work with that address. It finds it, but doesn't communicate properly.
Papa G
Please publish a link to the library.
