Loading...
Pages: [1] 2   Go Down
Author Topic: Simple Image Processing  (Read 1125 times)
Offline Offline
Newbie
View Profile
Hello,
Basically I want to implement simple image processing using Arduino (whichever works).
The board with a camera will be mounted on a small 4-wheeled car.
Basically I will be holding a bright Red LED and the objective of the car is to follow me using that LED.
Being new to Arduino platform I wanted a bit of advice on which camera and board to use if I want the image processing done by the controller?
How will go about doing that? Like are there any build in libraries I can use?
I will also need a bit of help interfacing the camera with the controller.
And is there a way to do the image processing from the camera mounted on the car on my computer and send the commands back to the controller wirelessly?
It will be awesome if someone can help me out getting things together.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
So have you searched this forum for similar posts?
What happens is I say no, you can't do it.
Then other people jump in and say maybe but it is complex.
Then you go away to look at another platform.
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
To have a robot follow light, you don't need a camera and image processing- you can get by with two LDRs (Light Dependent Resistors).
Unless there are some other constraints to this project that mean you have to use a camera and image processing, Google "photovore" (light eater...) and you'll get some good info.
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Poole, Dorset, UK
Offline Offline
God Member
View Profile
You also don't need to have one processor do every thing. Use a WiFi cam mounted on the 'bot. Link the cam to the PC and have the PC do the image processing and send instructions to the 'bot. Lookup robotics - horse and rider.
Mark
Logged
UK
Offline Offline
Tesla Member
View Profile
... but it's complex.
Logged
Offline Offline
Newbie
View Profile
Mark
That sounds like a better idea.
Can you explain me a bit more about this?
So what I make out of what you said is:
1. Wifi Camera sends image to PC.
2. I process the image in say MATLAB.
3. I send the instructions to the controller wirelessly from my results generated in MATLAB.
Now I am not very well versed with MATLAB. It would be really great if you could guide me on this.
How would I automate results from my MATLAB scripts to be sent over to the controller?
Give me some sources to study. Also, I am planning to get the XBEE module with the shield for my UNO board. How exactly would XBEE talk to my PC. (Is it possible to do that on an AD-Hoc network? or I would need a Wireless Router?)
It would be really helpful if you could give me more pointers on this.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
1. Wifi Camera sends image to PC. >  Not associated with arduino
2. I process the image in say MATLAB. > Matlab forum
3. I send the instructions to the controller wirelessly from my results generated in MATLAB. > possible arduino interface
How would I automate results from my MATLAB scripts to be sent over to the controller? > serial is the usual format
Give me some sources to study. > google is your friend
How exactly would XBEE talk to my PC. > probably thru another XBEE attached to your pc.
Is it possible to do that on an AD-Hoc network? or I would need a Wireless Router? > I think you are trying to mix apples and oranges.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Israel
Offline Offline
Full Member
View Profile
I am no expert at this, but the company I work for was using image processing hardware in their machines over 20 years ago(!). Isn't the Arduino (or a few of them connected together) "strong" enough to do what was done by hardware 20 years ago?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I too did image processing over twenty years ago.
We used 32 bit processors, often lots of them in parallel, with (for then) bucket loads of wide, fast RAM.
It wasn't a beginner's project.
Have a look at the video experimenter's board.
There's example code.
« Last Edit: January 19, 2013, 04:16:23 pm by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
universe
Offline Offline
Sr. Member
I'm enjoying my Life
View Profile
WWW
Using Kinect Camera to do color tracking and determine its coordinate using depth sensor, it is interesting since you also could use Processing to receive any data from Kinect and send data to your Arduino. Check this out: http://zugiduino.wordpress.com/2012/12/30/kinect-color-tracking/
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Forget colour.
Use optical filters.
Logged
Offline Offline
Brattain Member
View Profile
WWW
I did image processing 30 years ago on a TRS80 computer.
While the processing power was roughly the same as an arduino the memory capacity was not. That is what stops you using the Arduino to do any meaningful image processing. Also I build my own real time frame grabber. I programmed it in Fourth.
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Arduino could process 1-bit video, extracting 240 points on regular NTSC frame. Applying simple math it would be possible to distinguish straight lines, cycles etc.
http://coolarduino.wordpress.com/2012/07/28/visual-navigator-making-it-mobile/
and
http://coolarduino.wordpress.com/2011/12/29/optical-magnet-arduino-project-next-in-a-series-laser-tracking-3d/
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Pauses thread here for a moment and rewinds.....
Is this really an image processing issue or just light following?
Logged
IT Crowd:
Offline Offline
Newbie
View Profile
It will be image processing cause the light which the bot has to follow, I will be holding it in my hand waving around in a 3-D space. If it was just following something on the floor I would've used LDR's.
Using Kinect is an awesome idea...but Sir I have no Idea how to send Kinect's data wirelessly back to my computer.
Could you help me a bit in that?
If that can be worked out it will be amazing!
Logged
Pages: [1] 2   Go Up
Print
Jump to:
