Loading...
Pages: [1]   Go Down
Author Topic: uint32_t to int32_t conversion help needed  (Read 474 times)
Germany
Offline Offline
Newbie
I'm a newbie
View Profile
WWW
Hi everyone,
today I did some tests with a sensor in temperatures below 0 Celsius.
Unfortunately I made the mistake in declaring the temperature variable with uint32_t instead of int32_t.
Arduino shows these 3 measurements:
167771.20
167771.18
167770.95
Can anyone tell me what minus values these are? It should be somewhere around -1 Celsius or so.
Thanks.
Leo
Logged
Leo
Project "ALTDuino" - A homemade altimeter for model rockets.
http://www.altduino.de
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
Read this: http://arduino.cc/forum/index.php/topic,97455.0.html
You'll have to post some code as 167771.20 is neither an unsigned or signed integer.
Logged
Germany
Offline Offline
Newbie
I'm a newbie
View Profile
WWW
You are correct. The ones I posted are converted to float values (/100).
The int vlaues are:
16777120
16777118
16777095
Sorry about that.
Logged
Leo
Offline Offline
Edison Member
View Profile
WWW
If the values you posted are unsigned and you need signed, then there is no conversion. 16777120 will not overflow a signed 32-bit int. Which also means the reverse is true.
Logged
Germany
Offline Offline
Newbie
I'm a newbie
View Profile
WWW
Thank you very much for the help and opening my eyes!
I am now realizing that it's a lot more complicated than I had thought.
I'm going to reverse engineer my code to find the correct value.
If that doesn't work then no big deal. It was only a "nice to have" for knowing.
I found the error in my code which is the most important thing.
Thanks again.
Logged
Leo
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Why?
Quote
So, fix the mistake.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
the numbers sound like a 24 bit int - can that be possible?
Can you tell more about the sensor ?
Link datasheet?
16777216 = 2^24
16777120 = -96
16777118 = -98
16777095 = -121
If the number is to be interpreted with 2 decimals it would be -0.96, -0.98, -1.21 which looks like a stable T measurement
Post your code if you need help with reverse engineering,
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Germany
Offline Offline
Newbie
I'm a newbie
View Profile
WWW
Quote
Why?
Because I'm nosey.
Quote
There is a saying: "He who can read has a clear advantage"
This thread isn't to long. Give it a try.
Logged
Leo
Germany
Offline Offline
Newbie
I'm a newbie
View Profile
WWW
Link datasheet?
16777216 = 2^24
16777120 = -96
16777118 = -98
16777095 = -121
Thanks Rob. I think you may have goten it! I will verify.
Again, knowing the values was only a "nice to know" for me. I've already corrected my code. Problem is sovled.
Case closed.
Logged
Leo
Germany
Offline Offline
Newbie
I'm a newbie
View Profile
WWW
Rob, if I could I'd send you some Bavarian beer.
I just verified your numbers with my code -> Bull's-eye  smiley
Thanks!
Logged
Leo
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
I'll drink one here on your health,
Still open question:
Can you tell more about the sensor ?  I really want to know what does 24 bit smiley
Link datasheet?
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
