Topic: uint32_t to int32_t conversion help needed (Read 4502 times) previous topic - next topic
_Leo_
Hi everyone,
today I did some tests with a sensor in temperatures below 0 Celsius.
Unfortunately I made the mistake in declaring the temperature variable with uint32_t instead of int32_t.
Arduino shows these 3 measurements:
167771.20
167771.18
167770.95
Can anyone tell me what minus values these are? It should be somewhere around -1 Celsius or so.
Thanks.
Leo
Leo
Project "ALTDuino" - A homemade altimeter for model rockets.
http://www.altduino.de
pYro_65
Read this: http://arduino.cc/forum/index.php/topic,97455.0.html
You'll have to post some code as 167771.20 is neither an unsigned or signed integer.
Forum Mod anyone?
https://arduino.land/Moduino/
_Leo_
You are correct. The ones I posted are converted to float values (/100).
The int vlaues are:
16777120
16777118
16777095
Sorry about that.
Leo
pYro_65
If the values you posted are unsigned and you need signed, then there is no conversion. 16777120 will not overflow a signed 32-bit int. Which also means the reverse is true.
Forum Mod anyone?
_Leo_
Thank you very much for the help and opening my eyes!
I am now realizing that it's a lot more complicated than I had thought.
I'm going to reverse engineer my code to find the correct value.
If that doesn't work then no big deal. It was only a "nice to have" for knowing.
I found the error in my code which is the most important thing.
Thanks again.
Leo
PaulS
Why?
So, fix the mistake.
robtillaart
the numbers sound like a 24 bit int - can that be possible?
Can you tell more about the sensor ?
Link datasheet?
16777216 = 2^24
16777120 = -96
16777118 = -98
16777095 = -121
If the number is to be interpreted with 2 decimals it would be -0.96, -0.98, -1.21 which looks like a stable T measurement
Post your code if you need help with reverse engineering,
Rob Tillaart
_Leo_
Why?
Because I'm nosey.
There is a saying: "He who can read has a clear advantage"
This thread isn't to long. Give it a try.
Leo
_Leo_
Link datasheet?
16777216 = 2^24
16777120 = -96
16777118 = -98
16777095 = -121
Thanks Rob. I think you may have goten it! I will verify.
Again, knowing the values was only a "nice to know" for me. I've already corrected my code. Problem is sovled.
Case closed.
Leo
_Leo_
Rob, if I could I'd send you some Bavarian beer.
I just verified your numbers with my code -> Bull's-eye  :)
Thanks!
Leo
robtillaart
I'll drink one here on your health,
Still open question:
Can you tell more about the sensor ?  I really want to know what does 24 bit :)
Link datasheet?
Rob Tillaart
