Author Topic: uint32_t to int32_t conversion help needed  (Read 421 times)
Germany
I'm a newbie
Hi everyone,
today I did some tests with a sensor in temperatures below 0 Celsius.
Unfortunately I made the mistake in declaring the temperature variable with uint32_t instead of int32_t.
Arduino shows these 3 measurements:
167771.20
167771.18
167770.95
Can anyone tell me what minus values these are? It should be somewhere around -1 Celsius or so.
Thanks.
Leo
Leo
Project "ALTDuino" - A homemade altimeter for model rockets.
http://www.altduino.de
North Queensland, Australia
Read this: http://arduino.cc/forum/index.php/topic,97455.0.html
You'll have to post some code as 167771.20 is neither an unsigned or signed integer.
Germany
I'm a newbie
You are correct. The ones I posted are converted to float values (/100).
The int vlaues are:
16777120
16777118
16777095
Sorry about that.
Leo
If the values you posted are unsigned and you need signed, then there is no conversion. 16777120 will not overflow a signed 32-bit int. Which also means the reverse is true.
Germany
I'm a newbie
Thank you very much for the help and opening my eyes!
I am now realizing that it's a lot more complicated than I had thought.
I'm going to reverse engineer my code to find the correct value.
If that doesn't work then no big deal. It was only a "nice to have" for knowing.
I found the error in my code which is the most important thing.
Thanks again.
Leo
Seattle, WA USA
Online Online
Seattle, WA USA
Why?
So, fix the mistake.
Netherlands
the numbers sound like a 24 bit int - can that be possible?
Can you tell more about the sensor ?
Link datasheet?
16777216 = 2^24
16777120 = -96
16777118 = -98
16777095 = -121
If the number is to be interpreted with 2 decimals it would be -0.96, -0.98, -1.21 which looks like a stable T measurement
Post your code if you need help with reverse engineering,
Rob Tillaart
Germany
I'm a newbie
Why?
Because I'm nosey.
There is a saying: "He who can read has a clear advantage"
This thread isn't to long. Give it a try.
Leo
Germany
I'm a newbie
Link datasheet?
16777216 = 2^24
16777120 = -96
16777118 = -98
16777095 = -121
Thanks Rob. I think you may have goten it! I will verify.
Again, knowing the values was only a "nice to know" for me. I've already corrected my code. Problem is sovled.
Case closed.
Leo
Germany
I'm a newbie
Rob, if I could I'd send you some Bavarian beer.
I just verified your numbers with my code -> Bull's-eye  smiley
Thanks!
Leo
Netherlands
I'll drink one here on your health,
Still open question:
Can you tell more about the sensor ?  I really want to know what does 24 bit smiley
Link datasheet?
Rob Tillaart
