Topic: Newbie - HS-311 Servo 360 Continuous Rotation help (Read 9532 times) previous topic - next topic
chiques
Code for testing and setup of servos. For my DIY continous rotation servos I send a 1500us position signal to the servo and tweek the pot until the motor stopps turning, then secure the pot in place. the below sail servo might be of interest, but is $$$.
http://www.robotshop.com/ca/hitec-hs785hb-servo-motor-2.html
Code: [Select]
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
 myservo.writeMicroseconds(1500); //set initial servo position if desired
 myservo.attach(7);  //the pin for the servo control
 Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
 while (Serial.available()) {
   char c = Serial.read();  //gets one byte from serial buffer
   readString += c; //makes the string readString
   delay(2);  //slow looping to allow buffer to fill with next character
 if (readString.length() >0) {
   Serial.println(readString);  //so you can see the captured string
   int n = readString.toInt();  //convert readString into a number
   // auto select appropriate value, copied from someone elses code.
   if(n >= 500)
     Serial.print("writing Microseconds: ");
     Serial.println(n);
     myservo.writeMicroseconds(n);
     Serial.print("writing Angle: ");
     Serial.println(n);
     myservo.write(n);
   readString=""; //empty for next input
This code works great! Just purchased a HS-311 from ServoCity and it had a POT. I had no idea what it did and now I see it simply sets the STOP point depending on the value inputted from the keyboard. Thanks for this.
zoomkat
Quote
If you remove the stop, the servo will be 'stopped' by the potentiometer which will probably break.  Or perhaps you will strip some gear.
The pots in the servos I've taken apart and modified do not have stops. The only mechanical stop has been the plastic tab on the output shaft. Soon I plan to just remove the servo plastic stop tab and then do some testing with the servo.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
kgoveas
A HITEC HS-311 is rated for 4.8V-6V. As you mentioned that you have provided with 'live' , which I am assuming is 9V, you might have probably damaged the HS-311 circuit. You should connect the 9V to the Vin of the Arduino and 5V of the Arduino to the 'live' of the Servo Motor.
2010-506
Please guide me i am using Hitec hs 311 but it only goes toward a angle 180 degree whatever the input is and cannot goes to a angle which i desire i have tried different codes but problem is same help me please.
i am using arduino uno r3 board :smiley-sad-blue:
zoomkat
Quote
Most continuous rotation servos can not be commanded to stop at an "angle".
2010-506
The problem i mention earlier is now solved can u tell me Is it possible that i can use infrared sensor without using analogue pins of Arduino uno instead can i use pin o and 1 TXd RXD for this purpose?
