Loading...
Pages: [1]   Go Down
Author Topic: Compiling error with IRremote  (Read 130 times)
Offline Offline
Newbie
View Profile
Getting the following compiling error when trying to run IRtest from the example library.
Any help would be greatly appreciated.
ArduinoIRremotemaster\IRremote.cpp.o: In function `MATCH(int, int)':
/IRremoteInt.h:176: multiple definition of `MATCH(int, int)'
IRtest.cpp.o:C:\Users\Phil\Documents\Arduino\libraries\ArduinoIRremotemaster/IRremoteInt.h:176: first defined here
ArduinoIRremotemaster\IRremote.cpp.o: In function `MATCH_MARK(int, int)':
/IRremoteInt.h:177: multiple definition of `MATCH_MARK(int, int)'
IRtest.cpp.o:C:\Users\Phil\Documents\Arduino\libraries\ArduinoIRremotemaster/IRremoteInt.h:177: first defined here
ArduinoIRremotemaster\IRremote.cpp.o: In function `MATCH_SPACE(int, int)':
/IRremoteInt.h:178: multiple definition of `MATCH_SPACE(int, int)'
IRtest.cpp.o:C:\Users\Phil\Documents\Arduino\libraries\ArduinoIRremotemaster/IRremoteInt.h:178: first defined here
IRtest code:
 * IRremote: IRtest unittest
 * Version 0.1 July, 2009
 * Copyright 2009 Ken Shirriff
 * http://arcfn.com
 * Note: to run these tests, edit IRremote/IRremote.h to add "#define TEST"
 * You must then recompile the library by removing IRremote.o and restarting
 * the arduino IDE.
#include <IRremote.h>
#include <IRremoteInt.h>
// Dumps out the decode_results structure.
// Call this after IRrecv::decode()
// void * to work around compiler issue
//void dump(void *v) {
//  decode_results *results = (decode_results *)v
void dump(decode_results *results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN) {
    Serial.println("Could not decode message");
  else {
    if (results->decode_type == NEC) {
      Serial.print("Decoded NEC: ");
    else if (results->decode_type == SONY) {
      Serial.print("Decoded SONY: ");
    else if (results->decode_type == RC5) {
      Serial.print("Decoded RC5: ");
    else if (results->decode_type == RC6) {
      Serial.print("Decoded RC6: ");
    Serial.print(results->value, HEX);
    Serial.print(" (");
    Serial.print(results->bits, DEC);
    Serial.println(" bits)");
  Serial.print("Raw (");
  Serial.print(count, DEC);
  Serial.print("): ");
  for (int i = 0; i < count; i++) {
    if ((i % 2) == 1) {
      Serial.print(results->rawbuf*USECPERTICK, DEC);
    else {
      Serial.print(-(int)results->rawbuf*USECPERTICK, DEC);
    Serial.print(" ");
  Serial.println("");
IRrecv irrecv(0);
decode_results results;
class IRsendDummy :
public IRsend
public:
  // For testing, just log the marks/spaces
#define SENDLOG_LEN 128
  int sendlog[SENDLOG_LEN];
  int sendlogcnt;
  IRsendDummy() :
  IRsend() {
  void reset() {
    sendlogcnt = 0;
  void mark(int time) {
    sendlog[sendlogcnt] = time;
    if (sendlogcnt < SENDLOG_LEN) sendlogcnt++;
  void space(int time) {
    sendlog[sendlogcnt] = -time;
  // Copies the dummy buf into the interrupt buf
  void useDummyBuf() {
    int last = SPACE;
    irparams.rcvstate = STATE_STOP;
    irparams.rawlen = 1; // Skip the gap
    for (int i = 0 ; i < sendlogcnt; i++) {
      if (sendlog < 0) {
        if (last == MARK) {
          // New space
          irparams.rawbuf[irparams.rawlen++] = (-sendlog - MARK_EXCESS) / USECPERTICK;
          last = SPACE;
        else {
          // More space
          irparams.rawbuf[irparams.rawlen - 1] += -sendlog / USECPERTICK;
      else if (sendlog > 0) {
        if (last == SPACE) {
          // New mark
          irparams.rawbuf[irparams.rawlen++] = (sendlog + MARK_EXCESS) / USECPERTICK;
          last = MARK;
        else {
          // More mark
          irparams.rawbuf[irparams.rawlen - 1] += sendlog / USECPERTICK;
    if (irparams.rawlen % 2) {
      irparams.rawlen--; // Remove trailing space
IRsendDummy irsenddummy;
void verify(unsigned long val, int bits, int type) {
  irsenddummy.useDummyBuf();
  irrecv.decode(&results);
  Serial.print("Testing ");
  Serial.print(val, HEX);
  if (results.value == val && results.bits == bits && results.decode_type == type) {
    Serial.println(": OK");
  else {
    Serial.println(": Error");
    dump(&results);
void testNEC(unsigned long val, int bits) {
  irsenddummy.reset();
  irsenddummy.sendNEC(val, bits);
  verify(val, bits, NEC);
void testSony(unsigned long val, int bits) {
  irsenddummy.sendSony(val, bits);
  verify(val, bits, SONY);
void testRC5(unsigned long val, int bits) {
  irsenddummy.sendRC5(val, bits);
  verify(val, bits, RC5);
void testRC6(unsigned long val, int bits) {
  irsenddummy.sendRC6(val, bits);
  verify(val, bits, RC6);
void test() {
  Serial.println("NEC tests");
  testNEC(0x00000000, 32);
  testNEC(0xffffffff, 32);
  testNEC(0xaaaaaaaa, 32);
  testNEC(0x55555555, 32);
  testNEC(0x12345678, 32);
  Serial.println("Sony tests");
  testSony(0xfff, 12);
  testSony(0x000, 12);
  testSony(0xaaa, 12);
  testSony(0x555, 12);
  testSony(0x123, 12);
  Serial.println("RC5 tests");
  testRC5(0xfff, 12);
  testRC5(0x000, 12);
  testRC5(0xaaa, 12);
  testRC5(0x555, 12);
  testRC5(0x123, 12);
  Serial.println("RC6 tests");
  testRC6(0xfffff, 20);
  testRC6(0x00000, 20);
  testRC6(0xaaaaa, 20);
  testRC6(0x55555, 20);
  testRC6(0x12345, 20);
  test();
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
Could you put some spaces in the code, so it's not bunched up, and in the proper code tags "#"
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Pages: [1]   Go Up
Print
Jump to:
