Loading...
Pages: [1]   Go Down
Author Topic: Max input voltages?  (Read 286 times)
Offline Offline
Newbie
View Profile
Is there a page anywhere that lists the max input voltages for arduino?
What would happen if i input 9 volts to an arduino anolog read port?
Thanks
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Yep each product has a page here which lists all the info; here's the one for Uno for example.
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
SG
Offline Offline
Sr. Member
Arduino rocks
View Profile
Then this was the last time you use your arduino board.
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Quote
Just to elaborate, you can change the upper end of the 0-5v analog scale to a voltage other than 5v by using the AREF pin and analogReference(External) but it makes it very clear here that the AREF voltage must never be over 5v.
Logged
IT Crowd:
Offline Offline
Newbie
I know nothing.
View Profile
Quote
Is it gonna damage the arduino board if the aref voltage is over 5V?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Yes
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Quote
Certainly seems to be what they're indicating in bold letters....
Logged
IT Crowd:
Offline Offline
Edison Member
View Profile
"What would happen if i input 9 volts to an arduino anolog read port?"
That depEnds on many factors, like how your arduino is powered.
Generally, you will likely see the clamping diodes getting damaged (by itself not a big deal). But what comes after that is hard to predict.
A pin remains fully functiobal (aka their input/out + periheral functions) even if the clamp diodes are blown.
Logged
Pages: [1]   Go Up
Print
Jump to:
