Loading...
Pages: [1]   Go Down
Author Topic: Arduino Mega 2560 and RDM630 RFID Problem  (Read 191 times)
Offline Offline
Newbie
View Profile
First question:
How can I connect an RDM630 RFID to the Arduino Mega 2560?
I have try many versions but no one works.
Second question:
Which simple code should work if the connection is ok?
I want to read an Chip-Code and on the Serial Monitor I will get the name of the owner of the chip.
Sorry, but I have the Arduino since few days. I hope that someone can help me.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
First, you post a link to the hardware you want to connect/read from. Then, we can help you.
Logged
Offline Offline
Newbie
View Profile
This are the components which I will connect:
RDM630:
http://www.exp-tech.de/Shields/125Khz-RFID-module---UART.html
Arduino Mega 2560:
http://www.exp-tech.de/Mainboards/Arduino-Mega-2560-R3.html
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
On the page for the RFID reader, there is a link to a wiki that shows exactly how to connect the RFID reader to the Arduino, complete with big pictures.
The programming on that page is typical seeedstudio rubbish.
Logged
Offline Offline
Newbie
View Profile
How you can see I have an other Arduino Board as shown in the wiki.
"Tx from RFID board goes to Digital PIN 2 on Arduino Board."
Which Pin is it on my board? I connect PIN2 nearly PIN0(RX0) and PIN1(TX0). Is it right?
On the Serial Monitor there is only:
"SeriSerial Ready
RFID Ready"
When I test it whith an chip, there is nothing else on the Monitor.
If I connect additionally the Reset-PIN with GND and change the wire from connection PIN2 on my board to PIN1(TX0) the Serial-Monitor shows the Chip-Number when I test it with a chip.
But the programm does not what it should do.
What is wrong?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No, it isn't. The pins on the Mega (and all other boards) are clearly labeled). If RX0 and TX0 are pins 0 and 1, it really isn't too difficult to figure out which is pin 2, is it?
Logged
Pages: [1]   Go Up
Print
Jump to:
