Loading...
Pages: 1 [2]   Go Down
Author Topic: LED problem  (Read 834 times)
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Put the 01, 10, 11 as address bits into different logic - like a 74xx138, 74xx139 - selected out (#1, 2, 3) will go low, pull one cathode low.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Jr. Member
View Profile
I want the LED to be ON one at a time with the ouputs ( 01,10,11)
There is only one 220 ohm resistor at one of the output pins.
I don't have enough pins so i have to go with 2 pins itself.
the ???????????????? is something i got from chatting in fb.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
You need another on the output of the logic gate.
Logged
Offline Offline
Jr. Member
View Profile
this is a fair ckt dgm with only one yellow LED
Logged
Offline Offline
Jr. Member
View Profile
thanks mike
but i tried it in a 2 way traffic scenario. but still the yellow light turns ON when Red comes in one of the tracks
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
What is IC1?
Logged
Offline Offline
Jr. Member
View Profile
7408 and IC
Logged
Offline Offline
Jr. Member
View Profile
i meant AND ic
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
What does it do?
The LEDs can all be driven thru the IO pins shown:
D1 = 1, D0 = 0 turns on LED1
D1 = 0, D0 = 1 turns on LED2
D1 = D0 turns LED1 & LED2 off
same for 3,4  5,6  7,8
What's the AND gate do that couldn't be done with another IO pin instead?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Regarding that diagram, the pins that go through a resistor to the LEDs should not be connected to the input of the AND gate, this should be connected directly to the arduino. I suspect that it is this that is causing a problem because the current flowing through that resistor is holding the input to the AND high and thus keeping the yellow on, which still needs its own series resistor.
Logged
Offline Offline
Jr. Member
View Profile
cross roads
AND gate is for turning LED 3 ON D0-1 & D1-1
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
