Topic: LED problem (Read 3682 times) previous topic - next topic
CrossRoads
Put the 01, 10, 11 as address bits into different logic - like a 74xx138, 74xx139 - selected out (#1, 2, 3) will go low, pull one cathode low.
pranoy
I want the LED to be ON one at a time with the ouputs ( 01,10,11)
There is only one 220 ohm resistor at one of the output pins.
I don't have enough pins so i have to go with 2 pins itself.
the ???????????????? is something i got from chatting in fb.
Grumpy_Mike
You need another on the output of the logic gate.
pranoy
this is a fair ckt dgm with only one yellow LED
pranoy
thanks mike
but i tried it in a 2 way traffic scenario. but still the yellow light turns ON when Red comes in one of the tracks
CrossRoads
pranoy
pranoy
CrossRoads
What does it do?
The LEDs can all be driven thru the IO pins shown:
D1 = 1, D0 = 0 turns on LED1
D1 = 0, D0 = 1 turns on LED2
D1 = D0 turns LED1 & LED2 off
same for 3,4  5,6  7,8
What's the AND gate do that couldn't be done with another IO pin instead?
Grumpy_Mike
Regarding that diagram, the pins that go through a resistor to the LEDs should not be connected to the input of the AND gate, this should be connected directly to the arduino. I suspect that it is this that is causing a problem because the current flowing through that resistor is holding the input to the AND high and thus keeping the yellow on, which still needs its own series resistor.
pranoy
cross roads
AND gate is for turning LED 3 ON D0-1 & D1-1
