Author Topic: Vibrotactile Jacket LilyPad Help Needed  (Read 1495 times)
So I am trying to use 4 Arduino LilyPads (http://www.arduino.cc/en/Main/ArduinoBoardLilyPad) along with 16-20 of these vibration motors (https://www.sparkfun.com/products/11008) to create a vibrotactile jacket.
I am trying to use the LilyPads as slave modules controlled by an Arduino Mega.
I intend to control the motors using Pulse Width Modulation (PWM).
I have a few questions, as I was previously using the Arduino Uno and now have to shift suddenly to the LilyPad.
1) Is the LilyPad capable of communication through I2C? (since it is not specified on the page?http://www.arduino.cc/en/Main/ArduinoBoardLilyPad)
2) Is it possible to connect using the USB cable I was using for the Uno/Mega?
3) Since the LilyPad lacks headers, is all the wiring supposed to be soldered? Or is there some alternative? (Soldering Irons hate me  )
4) Since each motor is rated at 75mA previously I used a MOSFET to power them on the breadboard, how do I translate the breadboard circuit into something I can mount onto a jacket?
Lastly, I would be very grateful for any general advice or precautions I should be mindful of!
Thanks in advance!
Requiescat in Pace
Massachusetts, USA
Since the Lilypad uses an ATmega328P it should be able to act as an I2C slave.
Not sure what you mean.  I don't think the Lilypad includes the USB-to-Serial hardware so you typically use a USB-to-TTL-Serial cable ("FTDI Cable") to upload sketches.  The Mega has a USB connector and built-in USB-to-Serial hardware.
I usually see the Lilypad connected with several stitches of conductive thread through the connection holes.
You definitely need some kind of driver to switch 75 mA.  The board schematic shows a 33-ohm resistor so maybe it will work on less current.
If you need the higher current, perhaps the ULN2803 darlington array would work.  I don't know if anyone makes a lillypad-like board that will hold an 18-pin DIP but you could always design one yourself.
Netherlands
Online Online
I2C is on a4 and a5 connector of the Arduino's and these are exposed. (in picture at top just under the connector)
You might try simple I2C slave SW on the lilypads and an I2C scanner to see if they can be found.
Rob Tillaart
Thanks a lot for the help guys, one last question, would the FLORA be a better option than the LilyPad for this?  (http://www.adafruit.com/products/659)
Requiescat in Pace
Netherlands
Online Online
you must make a list of what functionality you need and check if they provide, it's that simple.
Given that the FLora is a later product, it might have learned from 'the working of' the lilypad.
Rob Tillaart
