Loading...
Pages: 1 [2]   Go Down
Author Topic: Supply for handmade arduino  (Read 481 times)
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
The diode prevents the  reset line from spiking up to a high voltage when the reset switch is used and causing the chip to think its going into high voltage programming mode, and appearing to the user as if it had locked up. This is implemented in later model Arduino's.
See Section 3 of Atmel App note.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
AREF is also connected to AVCC, instead of being independent - with its own 0.1uF cap.
No diode across the reset resistor either.
Bare minimum designs have certainly been drawn up better:
That attached drawing has that old error on Avcc pin and C5.
Lefty
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
