Topic: Slow response - how to improve . . ? (Read 7256 times) previous topic - next topic
robtillaart
try to get the application right for 1 sensor first. Then increase it to multiple sensors and then use array's.
Also read the book Kerningham & RItchie C language 2nd edition. "Worth its weight in brains"
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
taz3m
hello,
I found that by using
Code: [Select]
#define moisture_input [] = {1,3,4,5}
whereby i was defining analog pin 1,pin 3, pin 4, pin 5  to be used to collect information from soil moisture probes.
Instead when i use
Code: [Select]
int moisture_input [] = {1,3,4,5};
It do compiles . .
tz
AWOL
Quote
No, you weren't. You were defining a strange macro.
Do the substitution, and you'll see why the compiler complained.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
taz3m
I already try the application for 1 sensor, it did work . . thats why i would like to extend to 4 now.
Anyway thanks for the reference book .
taz ..
tz
taz3m
Which thing do i need to substitute . . ??
tz
AWOL
A #define is a macro.
When the C preprocessor sees the macro name it substitutes the macro value as a simple 1:1 text replacement.
taz3m
just to see if i did understand the working of the array.
im i doing it right ?
Code: [Select]
/* Declaration of I/Os */
  int moisture_input [] = {1,3,4,5};        // Analog Input pin 1 connected to collect Soil Moisture reading.
  #define dcSource_top 13                      // Power source 5V top connected to digitsl pin 13
  #define dcSource_bottom 12                   // Power Source 5V bottom connected to digital pin 12
   int Moisture[4];                 // Analogical value obtained from the experiment S.probes (1,2,3,4)
void setup (){
Serial.begin (9600);
int SoilMoisture(){
  // Variable to hold value from Moisture input.
  int reading[4];
  // Set driver pins to outputs
  pinMode(dcSource_top,OUTPUT);
  pinMode(dcSource_bottom,OUTPUT);
  // Drive a current through the divider in one direction
  digitalWrite(dcSource_top,LOW);
  digitalWrite(dcSource_bottom,HIGH);
  // Wait a moment for capacitance effects to settle
  // Take readings
  for (int i=0; i<4; i++)
  reading[i] = analogRead(moisture_input[i]);
   //return reading[i];
  // Reverse the current
  digitalWrite(dcSource_top,HIGH);
  digitalWrite(dcSource_bottom,LOW);
  // Give as much time in 'reverse' as in 'forward'
  // stop the current
void loop (){
for (int j=0; j<4; j++){
  Moisture[j] = SoilMoisture();
Serial.print ("value = ");
Serial.print (Moisture[0]);
tz
Nick Gammon
Quote
Code: [Select]
You can't use defines like that. Change that line to:
Code: [Select]
const int moisture_input [] = {1,3,4,5};       // Analog Input pin 1 connected to collect Soil Moisture reading.
Quote
Better.
Quote
Seems you did not like the phrase about clarification . . sorry about that .
As long as it made you smile. :)
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
PaulS
So, SoilMoisture() is defined as returning a value. There is no return statement, so there will be garbage on the stack that is popped off and stored in the array, each time the function ends. If that's what you want, carry on.
taz3m
Quote
Code: [Select]
Here const means that the value assigned to the array wont change, like here the pin number, correct ?
Quote
Better.
Motivating.
Quote
I shall make the effort to always :)  ;)
Quote
oops i think i forget to remove the // coment line here :
Code: [Select]
   return reading[i]; >>  remove // coment
if that is correct i shall be moving towards the reading of the switch.
I did not yet upload, may be this afternooon after work.
Thanks
Taz ...
tz
AWOL
#25
Jan 24, 2013, 09:35 am Last Edit: Jan 24, 2013, 10:05 am by AWOL Reason: 1
Code: [Select]
You really don't want to remove the comment - think what will happen.
Edit: Or, more to the point, think what will not happen.
GoForSmoke
Lux and lumens are units of brightness to human eyes which are most sensitive in yellow.
But plants reflect green and yellow, they absorb red and blue. What is best for plants does not appear so bright to human eyes or to your lux meter. You waste power on less useful wavelengths trying to increase lux, unless you're lighting for picture taking or best look. In general you want 4 red to 1 blue but you can change that some to better simulate different latitudes and time of year.
There are grow sites that you can verify this and maybe get numbers from. Red and blue leds with colored bulbs actually make good sensors for red and blue light, you need 2 pins and 1 resistor each.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
AWOL
Quote
sp. "green" (550nm)
GoForSmoke
Lumens still want a lot of yellow, color of the sun.
taz3m
Quote
Epp im starting to have an idea what really will not happen.  :~
Can you show me or more precisely give me a hint on the above please . .
Quote
Thats a really good piece of information. Thanks.
I think i shall be using the LDR to make known the condition of weather (Day, night, Rainy/Cloudy), so that i can switch on my T5 light based on the following:
http://learn.adafruit.com/photocells/using-a-photocell
Im pretty much interested in knowing how to get Red and Blue leds to act as good sensors. Any idea where should i start with !
tz
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
