Loading...
Pages: [1]   Go Down
Author Topic: millis () rollover  (Read 488 times)
Offline Offline
Newbie
View Profile
I was unsure of what happened at millis() rollover and despite the competent advice here on the board, I tend to like to see things for myself, especially since it has been 30 years since I did any 2's complement math.  I didn't want to wait 50 days and blink when the numbers rolled by so tried this.
attached program counts right on through the rollover, just like the pro's said it would..
Thanks to all here who made programming possible for me...... its fun for a hardware guy.
Quote
#include <Arduino.h>
what really happens with timer function at millis() rollover?
 lets test it.
unsigned long fakeMillis = 4294967290;     //set fakeMillis to a number near the rollover point
unsigned long mark = fakeMillis;           // set a time marker start of timer
//long mark = fakeMillis;                   // try other type variables
//int  mark = fakeMillis;
  do
    ++fakeMillis;                          //increment faketimer
    Serial.println(fakeMillis);            // prints "timer output" through rollover event
    Serial.println(fakeMillis-mark);      //perform typical subtraction for timer does it work through rollover?
  while (fakeMillis>1);   // whatever keep looping
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
unsigned long fakeMillis = 4294967290UL;
...is safer. Acquire the habit.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
The micros() function acts like the millis() function, only 1000 times faster. Rollover in 1+ hours, instead of 49+ days. Just in case you are the impatient types, and want results Now!.
Logged
Offline Offline
Newbie
View Profile
i had seen that notation  ul and f after variables and numbers in code and do not know the exact usage.
please elaborate on the habit i should acquire.
Dean
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
UL stands for unsigned long. It tells the compiler to treat the number as an unsigned long, rather than an int.
F stands for float. For systems where float and double are different sizes, a literal is treated as a double. The F tells the compiler to treat it as a float, instead. On the Arduino, floats and doubles are the same, so F is not needed.
Logged
Offline Offline
Newbie
View Profile
thanks
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Don't worry subtracting two time values will give the right result if the result variable is a signed integer.
(and the time values aren't too far apart - ie less than 2^31 different).
If the result of subtraction is treated as unsigned then it will be exactly the same bit pattern, but the difference will be
conceptually in the range 0.. 2^32-1  (sometimes you always know your difference will be non-negative so this
doubles the range of differences you can handle).
Unlike subtract when you compare two values it matters if they are signed or unsigned - the two comparisons
behave differently (for the same bit-patterns).
Logged
Offline Offline
God Member
View Profile
What's the difference between ++fakemillis   and   fakemillis++   ?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
++ (increment) / -- (decrement)
Description
Increment or decrement a variable
Syntax
x++;  // increment x by one and returns the old value of x
++x;  // increment x by one and returns the new value of x
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The difference is in what happens if the variable is used during the pre- or post-increment operation.
To illustrate:
Code:
char buf[10];
byte index = 0;
buf[0] = '\0';
buf[++index] = 'a';
buf[index++] = 'b';
At the end of this snippet, index will have been incremented twice, to 2. In the first case, index will be incremented, and then the value of index will be used as the array index. So, index will be incremented to 1, and then 'a' will be stored in buf[1].
In the second case, the value of index will be used, and then index will be incremented. So, 'b' will be stored in buf[1], and then index will be incremented to 2.
In this scenario, clearly the post-increment form is the desired form, but there are situations where the pre-increment form is desired (although they are not as common).
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
WARNING: You should never use pre or post increment statements in a macro or function.
What output do you expect ?  6 numbers
Code:
#define SQR(x)  ((x)*(x))
  int a = 2;
  Serial.println(SQR(a++));
  a = 2;
  Serial.println(SQR(++a));
  a = 2;
  int x = add(a++, a);
  Serial.println(x);
  a = 2;
  x = add(a, a++);
  Serial.println(x);
  a = 2;
  x = add(++a, a);
  Serial.println(x);
  a = 2;
  x = add(a, ++a);
  Serial.println(x);
int add(int x, int y)
  return x + y;
And what was your score?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Don't you mean "WARNING: You should never use pre or post increment statements in an _argument list_ to a macro or function"
Macros because of the multiple instatiation as illustrated, function because the order of evaluation is arbitrary and
the compiler can re-order operations I believe...
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
In this situation, the pre or post increment will give the same result. Personally as a matter of style here, I would prefer:
Code:
    fakeMillis++;
Notice I omitted the comment. Comments are supposed to elaborate, not describe what things are doing. eg.
Code:
foo += 2;  // add 2 to foo
Useless comment.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Yes, thank you for making it exact smiley-wink
Logged
Rob Tillaart
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Unsigned math demo. Values shown in decimal, hex and binary. Substitute your own values as needed.
Code:
unsigned long a, b, c;
  Serial.begin( 9600 );
  a = 0xffffff00UL;
  b = 0x10UL;
  Serial.println( "\n unsigned math\n" );
  Serial.print( "a = ");
  Serial.print( a, DEC );
  Serial.print( " = 0x");
  Serial.print( a, HEX );
  Serial.print( " = 0b");
  Serial.println( a, BIN );
  Serial.print( "b = ");
  Serial.print( b, DEC );
  Serial.print( b, HEX );
  Serial.println( b, BIN );
  if ( b >= a ) Serial.println( "b >= a" );
  else          Serial.println( "a > b" );
  c = a - b;
  Serial.print( "a - b = ");
  Serial.print( c, DEC );
  Serial.print( c, HEX );
  Serial.println( c, BIN );
  c = b - a;
  Serial.print( "b - a = ");
  c = b - (b + 1);
  Serial.print( "b - (b + 1) = ");
void loop() {};
Logged
Examples can be found at Learning in the Main Site and at the Playground
Pages: [1]   Go Up
Print
Jump to:
