Topic: Serial between two Arduino Unos (Read 696 times) previous topic - next topic
jonbierma
I am working on a project that requires two Arduino Unos to communicate.  Is it possible to communicate serially between the two using digital pins 0 and 1 (RX and TX?)
Having mixed results so far with using serialSoft and trying to test the functionality using a computer.
holmes4
On pins 0&1 you use Serial NOT softserial. Just connect pin 0 on each uno to pin 1 on the other. For other pins use newsoftserial.
Mark
larryd
A UNO can talk to your PC serial monitor using RX & TX.
So sure you can have 2 UNOs talk to each other. Use wires between them not the USB.
You just have to program them so they can interact.
No technical PMs.
The last thing you did is where you should start looking.
zoomkat
You will probably need to also connect the two boards grounds together.
