Sheffield
Offline
Newbie
« on: January 19, 2013, 06:52:51 pm » |
Hey everyone, Ive just started with arduino and am slowly getting my head around it, im currently trying to build a Fishtank controller that is automated with a manual switch that can be pressed to enable feeding. Now i have the basics in place, the switch works and activates the feeding cycle, but i am struggling to find any readup on how to program an RTC, what i want it to do is at X time turn on the lights and at x time turn them off, but then i also need this for the other relays as well. Heres my current sketch - /* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */ // Pin 13 has an LED connected on most Arduino boards. // give it a name:
// RELAYS
int pumprelay = 3; int filterrelay = 4; int lightsrelay = 5; int heaterrelay =6;
//BUTTONS
int FeedingButton = 7; int HeaterButton = 18;
//LEDS
int lightsled = 8; int pumpled = 9; int filterled = 10; int FeedingLED = 11; int heaterled = 12;
// variables will change: int buttonState = 0; // variable for reading the pushbutton status
// the setup routine runs once when you press reset: void setup() { // initialize the digital pin as an output. pinMode(lightsrelay, OUTPUT); pinMode(lightsled, OUTPUT); pinMode(heaterrelay, OUTPUT); pinMode(heaterled, OUTPUT); pinMode(pumprelay, OUTPUT); pinMode(pumpled, OUTPUT); pinMode(filterrelay, OUTPUT); pinMode(filterled, OUTPUT); pinMode(FeedingButton, INPUT); pinMode(FeedingLED, OUTPUT); }
// the loop routine runs over and over again forever: void loop() { // read the state of the pushbutton value: buttonState = digitalRead(FeedingButton);
// check if the pushbutton is pressed. // if it is, the buttonState is HIGH: if (buttonState == HIGH) { // Start Feeding Cyle Feeding(); } else { // Continue Normal Program
void Feeding() { digitalWrite(FeedingLED, HIGH); // Set Feeding LED On LightsOn(); PumpOff(); FilterOff(); delay(600000); digitalWrite(FeedingLED, LOW); // Set Feeding LED Off LightsOff(); PumpOn(); FilterOn(); delay(1000);
void LightsOn() { digitalWrite(lightsrelay, HIGH); // Set Lights On digitalWrite(lightsled, HIGH); // Set LED On }
void LightsOff() { digitalWrite(lightsrelay, LOW); // Set Lights Off digitalWrite(lightsled, LOW); // Set LED Off }
void PumpOn() { digitalWrite(pumprelay, HIGH); // Set Pump On digitalWrite(pumpled, HIGH); // Set LED On }
void PumpOff() { digitalWrite(pumprelay, LOW); // Set Pump Off digitalWrite(pumpled, LOW); // Set LED Off }
void FilterOn() { digitalWrite(filterrelay, HIGH); // Set Filter On digitalWrite(filterled, HIGH); // Set LED On }
void FilterOff() { digitalWrite(filterrelay, LOW); // Set Filter Off digitalWrite(filterled, LOW); // Set LED Off } Anyone know of any really good guides for RTC at all ?
Logged
Matthew Hadfield Current Project (s) - Fishtank Controller - Arduino Uno I maybe new, but i learn fast
UK
Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
« Reply #1 on: January 19, 2013, 06:55:46 pm » |
Which RTC?
Logged
Sheffield
Offline
Newbie
« Reply #2 on: January 19, 2013, 07:04:04 pm » |
Apologies, forgot to add the most important part !
I have been considering the DS1307 RTC, do you think this will be suitable ?
Logged
Offline
Sr. Member
The last thing you did is where you should start looking.
« Reply #3 on: January 19, 2013, 07:12:45 pm » |
I have been considering the DS1307 RTC, do you think this will be suitable ? Yes this is a good choice. The Time library contains examples for the DS1307 RTC. http://playground.arduino.cc/Code/timeIt also contains TimeAlarms which can be used to do things on a timed basis.
Logged
Offline
Edison Member
« Reply #4 on: January 19, 2013, 07:23:21 pm » |
i am struggling to find any readup on how to program an RTC The simplest would be to use your arduino to keep time: presumably the arduino is running all the time.
Logged
UK
Offline
Edison Member
« Reply #5 on: January 19, 2013, 07:32:45 pm » |
i am struggling to find any readup on how to program an RTC The simplest would be to use your arduino to keep time: presumably the arduino is running all the time. ... and the least accurate. Your 8pm light switch-on will end up at 4am after a while  The Arduino isn't great at timing, chiefly because the resonator used for it isn't that accurate. Plus the millis() function isn't all that accurate - it relies on a timer interrupt, and that can be delayed by other things happening when interrupts are disabled, or other interrupts are happening. Not a good idea.
Logged
Sheffield
Offline
Newbie
« Reply #6 on: January 19, 2013, 07:34:39 pm » |
i am struggling to find any readup on how to program an RTC The simplest would be to use your arduino to keep time: presumably the arduino is running all the time. It is, however i may be away from my arduino for extended periods of time, so therefore would rather use an RTC so that even if the power drops once the power comes back on the whole thing restarts itself. I have been considering the DS1307 RTC, do you think this will be suitable ? Yes this is a good choice. The Time library contains examples for the DS1307 RTC. http://playground.arduino.cc/Code/timeIt also contains TimeAlarms which can be used to do things on a timed basis. Thanks for that Larry, id been reading the library but had missed a very obvious link in there, reading through some of the examples this should be fairly easy to do.
Logged
Dee Why NSW
Offline
God Member
« Reply #7 on: January 19, 2013, 07:38:27 pm » |
I use the DS1307 and it is fine for this. You can simply use the standard time display procedure to do something specific. I use the snippet below to change a file name after midnight. void loop() { GetClock(); if (hour == 0 && minute == 0 && second <2) { getFileName(); } myFile = SD.open(filename, FILE_WRITE);//<<<<<<<<<<<<< OPEN
tra la la.....
Logged
Offline
Sr. Member
« Reply #8 on: January 19, 2013, 07:49:23 pm » |
Using TimeAlarms you can: #include <TimeAlarms.h> //Changed Number of alarms dtNBR_ALARMS to 30 max 255
void setup() { Alarm.alarmRepeat(12,15,0, Feed); // Lunch hh,mm,ss Alarm.alarmRepeat(8,15,0, LightOn); // Turn on the light //other alarm events
} void loop() { }
//*********************************************** //Lunch void Feed() { // Put Lunch code here } //*********************************************** //Turn on the light void LightOn() { // Put LightOn code here } //***********************************************
Logged
Sheffield
Offline
Newbie
« Reply #9 on: January 29, 2013, 05:06:31 pm » |
Ok guys, got my DS1307 today, wired her up and shes working fine, however got one problem, the alarms wont trigger ! - any idea where im going wrong here as ive been reading the examples etc and cant see anything obvious - #include <Wire.h> #include "RTClib.h" #include <Time.h> #include <TimeAlarms.h>
RTC_DS1307 RTC;
// RELAYS
int pumprelay = 3; int filterrelay = 4; int lightsrelay = 5; int heaterrelay = 6;
//BUTTONS
//LEDS
// the setup routine runs once when you press reset: void setup() { Serial.begin(9600); Wire.begin(); RTC.begin(); if (! RTC.isrunning()) { Serial.println("RTC is NOT running!"); // following line sets the RTC to the date & time this sketch was compiled } // initialize the digital pin as an output. pinMode(lightsrelay, OUTPUT); pinMode(lightsled, OUTPUT); pinMode(heaterrelay, OUTPUT); pinMode(heaterled, OUTPUT); pinMode(pumprelay, OUTPUT); pinMode(pumpled, OUTPUT); pinMode(filterrelay, OUTPUT); pinMode(filterled, OUTPUT); pinMode(FeedingButton, INPUT); pinMode(FeedingLED, OUTPUT); Serial.println("Startup Completed"); FilterOn(); Alarm.alarmRepeat(23,00,0, Night); // 8:30am every day Alarm.alarmRepeat(06,00,0, Day); // 8:30am every day Alarm.alarmRepeat(21,55,30, Feeding); // 8:30am every day }
// the loop routine runs over and over again forever: void loop() { DateTime now = RTC.now(); Serial.print(now.hour(), DEC); Serial.print(':'); Serial.print(now.minute(), DEC); Serial.print(':'); Serial.print(now.second(), DEC); Serial.println();
} Alarm.delay(1000); // wait one second between clock display }
void Feeding() { digitalWrite(FeedingLED, HIGH); // Set Feeding LED On Serial.println("Feeding Cycle Started"); LightsOn(); PumpOff(); FilterOff(); delay(6000); digitalWrite(FeedingLED, LOW); // Set Feeding LED Off Serial.println("Feeding Cycle Ended"); LightsOff(); PumpOn(); FilterOn(); delay(6000);
void Night () { LightsOff(); PumpOff(); }
void Day () { LightsOn(); PumpOn(); }
void LightsOn() { digitalWrite(lightsrelay, HIGH); // Set Lights On digitalWrite(lightsled, HIGH); // Set LED On Serial.println("Lights On"); }
void LightsOff() { digitalWrite(lightsrelay, LOW); // Set Lights Off digitalWrite(lightsled, LOW); // Set LED Off Serial.println("Lights Off"); }
void PumpOn() { digitalWrite(pumprelay, HIGH); // Set Pump On digitalWrite(pumpled, HIGH); // Set LED On Serial.println("Pump On"); }
void PumpOff() { digitalWrite(pumprelay, LOW); // Set Pump Off digitalWrite(pumpled, LOW); // Set LED Off Serial.println("Pump Off"); }
void FilterOn() { digitalWrite(filterrelay, HIGH); // Set Filter On digitalWrite(filterled, HIGH); // Set LED On Serial.println("Filter On"); }
void FilterOff() { digitalWrite(filterrelay, LOW); // Set Filter Off digitalWrite(filterled, LOW); // Set LED Off Serial.println("Filter Off"); }
Logged
Temple, Texas
Offline
Sr. Member
« Reply #10 on: January 29, 2013, 05:48:28 pm » |
Hi MattHadfield, Are you saying all other functions (leds, etc) are working? When you push the button you get the Feeding cycle actions? Have you run successfully the TimeAlarms sample sketch(s)? How do you verify that your sketch is not working...have you waited til 23:00, 06:00, etc? Or did you substitute sooner times for testing... Nicely structured code btw  Cheers, John
Logged
East Anglia (UK)
Offline
Edison Member
May all of your blinks be without delay
« Reply #11 on: January 29, 2013, 06:00:07 pm » |
Not the cause of the problem but, as an observation, you don't need the else after finding the pushbutton pressed unless you plan to do something specific in the future when you find it not pressed.
Logged
Sheffield
Offline
Newbie
« Reply #12 on: January 29, 2013, 06:03:14 pm » |
John, Thanks, being a webdeveloper helps with the structuring a little  Ive run the TimeAlarms Samples, they work fine, pressing the switch the feeding cycle kicks in fine and runs, i was subbing the times to test but nothing at all happens at the time, ive tried everything i can think of, using Arduino Uno, pulling time back from the arduino works fine (See http://gyazo.com/4a7299e4d4e2c8eafaeaffd972ca5bba.png?1359500543) - Any ideas ?
Logged
NE PA
Offline
Full Member
« Reply #13 on: January 29, 2013, 06:19:17 pm » |
I don't see anything obvious. How about putting a few serial.printlns inyour day, night, lightson, lightsoff, etc functions to see if the alarm is triggering them. At least you'll narrow it dow to a function problem or alarm problem.
Logged
Sheffield
Offline
Newbie
« Reply #14 on: January 29, 2013, 06:28:01 pm » |
Quick5pnt0, Its an alarm issue, theres no LED change either on the relay or on a seperate status LED, however these do work when called by the switch, so the alarm just is not triggering. - See here for Screenshot of what happens when button pressed - http://gyazo.com/804dadf4df3828d889f5abdc8c631c7f.png?1359502250
« Last Edit: January 29, 2013, 06:34:22 pm by MattHadfield »
Logged
