Topic: Do action at certain time using RTC (Read 43678 times) previous topic - next topic
johncc
I don't see anything obvious. How about putting a few serial.printlns inyour day, night, lightson, lightsoff, etc functions to see if the alarm is triggering them. At least you'll narrow it dow to a function problem or alarm problem.
He does actually have Serial.printlns in most of those already...
I don't see anything obvious either...
MattHadfield
#16
Jan 30, 2013, 12:41 am Last Edit: Jan 30, 2013, 12:55 am by MattHadfield Reason: 1
Have i really managed to stump the knowledge of all the great Arduino Coders ?
Edit - Not sure if im on the right tracks here, but i thought as a test id put this in to see what the arduinos internal time actually is, and theres a mismatch, could this be the issue ?
http://gyazo.com/ee1a4d9dfa5e6e058e29bc5735d21984.png?1359503649
HazardsMind
From the example, setTime(8,29,0,1,1,11); is included in the setup, did you put this in to test it? Other than that, it should be working.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
MattHadfield
Tried this, changed the alarm time to 8:30 as per the example and it worked ! So why isnt it reading from the RTC time thats my question ?
HazardsMind
did you try the example TimeRTC? Look in the Setup(), it might be just what your missing.
* TimeRTC.pde
* example code illustrating Time library with Real Time Clock.
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
void setup()  {
  setSyncProvider(RTC.get);   // ***the function to get the time from the RTC***
  if(timeStatus()!= timeSet)
     Serial.println("Unable to sync with the RTC");
     Serial.println("RTC has set the system time");
   digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
  Serial.println();
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
My GitHub:
SFO_user
I'm trying my first hand at Arduino and want to do the same with controlling a fish tank.
Can you provide some help on what sensors and hardware you are using.
Many thanks!
jordachefl
Hello,
Here is my version of aquarium controller based on the examples above.
I will post the hardware used and photos in different post later.
Could anyone have a look at my code and let me know any improvements to simplify it.
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Time.h>
#include <TimeAlarms.h>
#include "virtuabotixRTC.h"
// Creation of the Real Time Clock Object
//CLK -> 12, DAT -> 7, RST -> 8, VCC -> +5v, GND -> GND
virtuabotixRTC myRTC(12, 7, 8);
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
//set device address for DS18B20 sensor
DeviceAddress temp_addr = {0x28, 0xFF, 0x8F, 0x06, 0x66, 0x14, 0x01, 0x18};
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float temperature;
int max_temp = 30; //maximum temperature of aquarium - switch off voltage to heater for safety
// RELAYS
int filterrelay = 9;
int lightsrelay = 6;
int heaterrelay = 5;
//int pumprelay = 10; // uncomment if the pump relay is to be used
//BUTTONS
int FilterButton = 3;
int LightButton = 11;
//feeding button variables
int FilterButtonState = LOW;
int Freading;           // the current reading from the input pin
int Fprevious = HIGH;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long Ftime = 0;         // the last time the output pin was toggled
long Fdebounce = 100;   // the debounce time, increase if the light output flickers
//light button variables
int LightButtonState = LOW;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = HIGH;    // the previous reading from the input pin
long time = 0;         // the last time the output pin was toggled
long debounce = 100;   // the debounce time, increase if the light output flickers
// the setup routine runs once when you press reset:
     Wire.begin();
     lcd.begin(20,4);// set the colomns to 20 and rows to 4
     sensors.begin();// temp sensor
     sensors.setResolution(temp_addr, 10);
// Set the current date, and time in the following format:
// seconds, minutes, hours, day of the week, day of the month, month, year
//myRTC.setDS1302Time(30, 6, 16, 2, 25, 8, 2015);//run once only to set time to RTC // comment when test finished
//myRTC.setDS1302Time(59, 59, 8, 6, 22, 8, 2015);  //for test
// initialize the digital pin as an output.
  pinMode(lightsrelay, OUTPUT);
  pinMode(heaterrelay, OUTPUT);
 // pinMode(pumprelay, OUTPUT);
  pinMode(filterrelay, OUTPUT);
  // initialize the feed and light button as INPUT PULLUP (when button is pressed the status is LOW).
  pinMode(FilterButton, INPUT_PULLUP);
  pinMode(LightButton, INPUT_PULLUP);
  Serial.println("Startup Completed");
myRTC.updateTime();
setTime(myRTC.hours,myRTC.minutes,myRTC.seconds,myRTC.dayofmonth,myRTC.month,myRTC.year);
//setTime(8,59,59,1,1,11); //test settime //set time syntax setTime(hour,minutes,secundes,day,month,YY)
  //set initial mode
    if ((myRTC.hours >= 9) && (myRTC.hours < 12) ) {
       Day ();
    else if ((myRTC.hours >= 12) && (myRTC.hours < 16) ) {
      Afternoon();
     else if ((myRTC.hours >= 16) && (myRTC.hours < 22) ) {
      Day ();
      else {
      Night ();
    HeaterOn();//start heater
    //PumpOn();//start pump
    //Alarms schedule
    //test
    /*Alarm.alarmRepeat(18,44,5, Feeding);
    Alarm.alarmRepeat(18,44,15, Day);
    Alarm.alarmRepeat(18,44,25, Afternoon);
    Alarm.alarmRepeat(18,44,35, Feeding);
    Alarm.alarmRepeat(18,44,45, Day);
    Alarm.alarmRepeat(18,44,55, Night);*/
    //real
    Alarm.alarmRepeat(9,0,0, Feeding);  //start day and feed for 15 min (feeder timer set at 09:05)
    Alarm.alarmRepeat(9,15,0, Day);
    Alarm.alarmRepeat(12,0,0, Afternoon);  //switch off lights in the afternoon
    Alarm.alarmRepeat(16,0,0, Feeding);  //evening feeding for 15 min (feeder timer set at 16:05)
    Alarm.alarmRepeat(16,15,0, Day);
    Alarm.alarmRepeat(22,0,0, Night); //night mode
// the loop routine runs over and over again forever:
myRTC.updateTime(); //read time from RTC DS1302
    Serial.print(myRTC.hours, DEC);
    Serial.print(':');
    Serial.print(myRTC.minutes, DEC);
    Serial.print(':');
    Serial.print(myRTC.seconds, DEC);
  // Print date/time to the LCD.
//lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print(myRTC.dayofmonth); lcd.print("/");
  lcd.print(myRTC.month); lcd.print("/");
  lcd.print(myRTC.year); lcd.print(" - ");
  lcd.print(myRTC.hours); lcd.print(":");
  lcd.print(myRTC.minutes); lcd.print(":");
  lcd.print(myRTC.seconds); lcd.print(" ");
  //print on LCD
  lcd.setCursor(0, 1);
     lcd.print("Mode:");
lcd.setCursor(10, 2);
     lcd.print("Temp:");
 lcd.setCursor(0, 2);
   lcd.print("Light:");
lcd.setCursor(0, 3);
   lcd.print("Filter:");
lcd.setCursor(11, 3);
   lcd.print("Heat:");
  // temp sensor reading
    sensors.requestTemperatures();
    temperature = sensors.getTempC(temp_addr);
   Serial.print(" temp - ");
   Serial.println(temperature);
   lcd.setCursor(15, 2);
     lcd.print(temperature);
  //safety precaution - heater off if temperature > 30 C
  if (temperature > max_temp){
    HeaterOff();
  else if (temperature < max_temp - 1){
HeaterOn();
       //Feeding pushbutton
  Freading = digitalRead(FilterButton);
  if (Freading == HIGH && Fprevious == LOW && millis() - Ftime > Fdebounce) {
    if (FilterButtonState == HIGH){
         FilterOff ();}
    else{
        FilterOn ();}
      Ftime = millis();
  Fprevious = Freading;
       //Light pushbutton:
  reading = digitalRead(LightButton);
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    if (LightButtonState == HIGH){
         LightsOff ();}
    else{
        LightsOn ();}
      time = millis();
  previous = reading;
Alarm.delay(100); // wait one second between clock display
void Feeding() {
       Serial.println("***Feeding Cycle Started***");
  FilterOff();
  LightsOn();
// PumpOff();
   lcd.setCursor(5, 1);
     lcd.print(" FEEDING   ");
void Day () {
  Serial.println("Day mode");
  LightsOn();
  FilterOn();
// PumpOn();
     lcd.print(" DAY       ");
void Night () {
   Serial.println("***Night mode***");
  LightsOff();
  FilterOn();
  // PumpOff();
     lcd.print(" NIGHT     ");
void Afternoon () {
  Serial.println("***Afternoon mode***");
  LightsOff();
  FilterOn();
// PumpOn();
     lcd.print(" AFTERNOON ");
void LightsOn() {
  digitalWrite(lightsrelay, LOW); // Set Lights On
  LightButtonState = HIGH;
  lcd.backlight();// LCD backlight on
   Serial.println("Lights On");
    lcd.setCursor(6, 2);
   lcd.print("ON ");
void LightsOff() {
  digitalWrite(lightsrelay, HIGH); // Set Lights Off
  lcd.noBacklight(); // LCD backlight off
   Serial.println("Lights Off");
   lcd.print("OFF");
void FilterOn() {
  digitalWrite(filterrelay, LOW); // Set Filter On
  FilterButtonState = HIGH;
   Serial.println("Filter On");
     lcd.setCursor(7, 3);
   lcd.print("ON ");
void FilterOff() {
  digitalWrite(filterrelay, HIGH); // Set Filter Off
   Serial.println("Filter Off");
   lcd.print("OFF");
void HeaterOn() {
  digitalWrite(heaterrelay, LOW); // Set Heater On
        lcd.setCursor(16, 3);
   lcd.print("ON ");
void HeaterOff() {
  digitalWrite(heaterrelay, HIGH); // Set Heater Off
   lcd.print("OFF");
/* uncomment if the pump relay is to be used
 void PumpOn() {
   digitalWrite(pumprelay, HIGH); // Set Pump On
   Serial.println("Pump On");
 void PumpOff() {
   digitalWrite(pumprelay, LOW); // Set Pump Off
   Serial.println("Pump Off");
UKHeliBob
Make all the variables the appropriate size and make those that refer to Arduino pins const
Alarm.delay(100); // wait one second between clock displayCheck comments and make sure that they reflect what the code does.  Use Ctrl/T to format the code consistently.
jordachefl
#23
Aug 27, 2015, 01:07 pm Last Edit: Aug 27, 2015, 01:08 pm by jordachefl
Are you refering at this
// RELAYS
//BUTTONS
To be changed in this
// RELAYS
const filterrelay = 9;
const lightsrelay = 6;
const heaterrelay = 5;
//const pumprelay = 10; // uncomment if the pump relay is to be used
//BUTTONS
const FilterButton = 3;
const LightButton = 11;
What is the reason
UKHeliBob
Yes, but the suggestion was to change them to
// RELAYS
const byte filterrelay = 9;
const byte lightsrelay = 6;
const byte heaterrelay = 5;
//const byte pumprelay = 10; // uncomment if the pump relay is to be used
//BUTTONS
const byte FilterButton = 3;
const byte LightButton = 11;
const because none of the values will change when the program runs.  If you do try to change them by accident within the program if you revise it then the compiler will stop you making that mistake.
byte because none of them will ever have a value larger than 255 and ints take twice as much memory as bytes.  Not particularly important in this program but it is good practice to use variables of an appropriate size, which can be faster to manipulate and it is always good to save memory.  There are other reasons too to do with interrupts but they don't apply unless/until you use them.
jordachefl
Did the modifications and auto format. New sketch is smaller by 10 bytes.
#include <Wire.h>
#include <Time.h>
float temperature;
// RELAYS
//BUTTONS
  Wire.begin();
  lcd.begin(20, 4); // set the colomns to 20 and rows to 4
  myRTC.updateTime();
  setTime(myRTC.hours, myRTC.minutes, myRTC.seconds, myRTC.dayofmonth, myRTC.month, myRTC.year);
  //set initial mode
    Day ();
    Afternoon();
    Day ();
  else {
    Night ();
  //Alarms schedule
  //for test
  //real
  Alarm.alarmRepeat(9, 0, 0, Feeding); //start day and feed for 15 min (feeder timer set at 09:05)
  Alarm.alarmRepeat(9, 15, 0, Day);
  Alarm.alarmRepeat(12, 0, 0, Afternoon); //switch off lights in the afternoon
  Alarm.alarmRepeat(16, 0, 0, Feeding); //evening feeding for 15 min (feeder timer set at 16:05)
  Alarm.alarmRepeat(16, 15, 0, Day);
  Alarm.alarmRepeat(22, 0, 0, Night); //night mode
  Serial.print(':');
  Serial.print(':');
  //lcd.backlight();
  //print on LCD
  lcd.print("Mode:");
  lcd.print("Temp:");
  lcd.print("Heat:");
  if (temperature > max_temp) {
    HeaterOff();
  else if (temperature < max_temp - 1) {
    HeaterOn();
    if (FilterButtonState == HIGH) {
      FilterOff ();
    else {
      FilterOn ();
    Ftime = millis();
  //Light pushbutton:
    if (LightButtonState == HIGH) {
      LightsOff ();
    else {
      LightsOn ();
    time = millis();
  previous = reading;
  // Alarm.delay(1000); // wait one second between clock display
void Feeding() {
  FilterOff();
  LightsOn();
  // PumpOff();
void Day () {
  Serial.println("***Day mode***");
  LightsOn();
  FilterOn();
  // PumpOn();
  lcd.print(" DAY       ");
void Night () {
  LightsOff();
  FilterOn();
  // PumpOff();
void Afternoon () {
  LightsOff();
  FilterOn();
  // PumpOn();
void LightsOn() {
  lcd.print("ON ");
void LightsOff() {
  lcd.print("OFF");
void FilterOn() {
  lcd.print("ON ");
void FilterOff() {
  lcd.print("OFF");
void HeaterOn() {
  lcd.print("ON ");
void HeaterOff() {
  lcd.print("OFF");
 void PumpOn() {
 void PumpOff() {
Keypel
I use the DS1307 and it is fine for this. You can simply use the standard time display procedure to do something specific. I use the snippet below to change a file name after midnight.
  GetClock();
  if (hour == 0 && minute == 0 && second <2)
    getFileName();
myFile = SD.open(filename, FILE_WRITE);//<<<<<<<<<<<<< OPEN
tra la la.....
That's brilliant Nick.
I just got my DS3231. It's supposed to only lose a few minutes per year!!
The code I'm using is a little different.
#include <DS3231.h>
// Init the DS3231 using the hardware interface
DS3231  rtc(SDA, SCL);
  // Setup Serial connection
  // Initialize the rtc object
  rtc.begin();
  // Print Time
  Serial.println(rtc.getTimeStr());
  // Wait one second before repeating :)
  delay (1000);
Serial.println(rtc.getTimeStr()); spits out some sort of string array thingy. It looks like this in the Serial Monitor:
17:37:41
17:37:42
17:37:43
Can somebody please tell me how to take rtc.getTimeStr() and put it into a variable called currentTime that is a float?  Just want the hours and minutes. ( no colons or seconds) stored as a float.
then I could do something like
if (currentTime => setTime){
//Do Something Cool.
Nick_Pyner
Yes. While I wouldn't hear a bad word about the DS1307, I find it is pretty poor in a varying environment. The DS3231 is far superior and only a dollar or so more. I use it with no change to the DS1307 software.
I now use a more elegant(!) time check for midnight.
 GetClock();
  if (today != day)
   today = day;
   getFileName();
   ladedah;
Keypel
#28
Jan 05, 2017, 01:20 am Last Edit: Jan 05, 2017, 01:41 am by Keypel
I kept say float but what I really meant was int.
The code I'm using:
#include <DS3231.h>
  rtc.begin();
  // Send time
Spits out:
18:32:35
18:32:36
18:32:37
18:32:38
18:32:39
But I don't know how to compare  18:32:37.
if it was stored as an int I could do something like this:
if ( currentTime => setTime) {
// Do Something Cool.
I tried :
rtc.getTimeStr().toInt()
lol haHa I have no Idea on the correct syntax. Strings and Arrays are so confusing for me.
Nick_Pyner
I'm afraid I have no idea. I just use
http://bildr.org/2011/03/ds1307-arduino/
no strings, no arrays, and no library.
I thought the DS3231 library had an alarm example included.
