Loading...
Pages: 1 [2]   Go Down
Author Topic: Could use some guidance with limit switches and a prox switch arduino mega  (Read 774 times)
H-Town
Offline Offline
Newbie
"Never Look A Bounty Hunter In The Eyes"
View Profile
Hello Folks,
I am having this problem with my subroutine command not wanting to work in void loop. Could somebody further advise me to what I'm doing wrong. I can get it to work in set up, but of course it will not loop. If I take motorRight & motorLeft out of setup and place them into loop, my program does not exit setup into loop. Also, I can't get my 2nd subroutine to function at all. I must be missing something miniscule or mind is majorly malfunctioned.....  Maybe a little bit of both!
Thank You,
U_R
Code:
  // assign the pin connections for my motors
  motor2.set_enable_pin(7);
  motor2.set_direction_pin(6);
  motor2.set_step_pin(5);
  motor2.set_microstep_select_pins(A1);
  motor4.set_enable_pin(4);
  motor4.set_direction_pin(27);
  motor4.set_step_pin(11);
  motor4.set_microstep_select_pins(A2);
 // set the mag pin and the switch pins as inputs:
    pinMode (swP1, INPUT);
    pinMode (swP2, INPUT);
    pinMode (mP, INPUT);
    pinMode (enablePin, OUTPUT);
   while(digitalRead(swP1)== HIGH) {
   motor2.go(FULL,-900,10);
   if(digitalRead(swP1)==LOW) {
   goto finish;
   finish:
   motor2.stall();
   delay(3000);
  motorRight();    //try code from if else program
  motorLeft();
 void loop() {}
 void motorRight ()
    for(i=0; i<4; i++) {
    while (digitalRead(mP) == HIGH) {
    motor2.go(FULL, 2000, 10);
    if (digitalRead(mP) == LOW) {
    motor2.stall();
    delay (3000);
 void motorLeft ()
    for(i=0; i>3; i--) {
    while (digitalRead(mP) == LOW) {
    motor2.go(FULL, -2000, 10);
    if (digitalRead(mP) == HIGH) {
    motor2.stall();
    delay (3000);
Logged
U_R
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
I'm voting for the latter. I've been writing code in C and C++ for almost 30 years now (it's how I make my living). !00s of thousands of lines of code, and not a single goto.
Yours is not needed, either. If the switch is low, go to a label. If it isn't, drop through to the same place. The goto is absolutely useless.
It would greatly improve the readability of your program if you put each { on a new line, and used the Tools + Auto Format menu item.
Meaningful names are important. One can't even begin to guess what mP means. Comments are important, too. We can see what the code is doing, but we have no idea what you expect it to be doing. If you have a comment like
Code:
// Run the left motor for 10 seconds
and code like
Code:
   while(millis() - then > 5000)
       motorRight.go();
Then we can see that there is (or is not) a discrepancy between what the comment says and what the code does.
It also helps to tell us what actually happens, along with what you expect. "It doesn't work" gives us nothing to go on.
Logged
H-Town
Offline Offline
Newbie
View Profile
Yes Sir,
  I do apologize for my incomprehensive programming skills. I am having trouble interrupting my motor with my limit switch. The program wants to complete the revolutions before stopping the motor. Programming micro controllers is a bit different than programming CNC machinery. So please, beat me up as much as it takes to get it through my thick skull.....
Thank You,
U_R
Code:
  pinMode (swP1, INPUT);  //limit switch left over travel motor #2
  pinMode (swP2, INPUT);  //limit switch right over travel motor #4
  pinMode (mP, INPUT);     //mag sensor (proximity) switch between motors 2 & 4
  while (digitalRead (swP1)==LOW)  //while limit switch 1 is OFF
    motor2.stall();                       //motor stop
    delay(3000);                         //3 sex
    motor2.go(FULL, -900, 10);    // motor 2 rotate CCW 4-1/2 rev's
                                              //THE MOTOR WANTS TO TURN FULL 4-1/2 REV'S BEFORE THE SWITCH STOPS IT
    if (digitalRead (swP1)==HIGH)   //if limit switch 1 is ON
    else {
  if (digitalRead(swP1) == HIGH)       //if limit switch 1 is ON
      if (digitalRead(swP1) == LOW)    //if limit switch 1 is OFF
      digitalWrite(enablePin, HIGH);          // turn motor enable pin ON
      motor2.go(FULL, 2000, 10);            //THE MOTOR WANTS TO TURN FULL 10 REV'S BEFORE THE SWITCH STOPS IT
      delay (5000);                                //5 sec's
  if (digitalRead(swP1) == HIGH)        // check if the input is HIGH
    motor2.go(FULL, -2000, 10);       // step motor 2 CCW 10 rev's
    motor2.stall();                          //stop motor
Logged
U_R
East Anglia (UK)
Online Online
Edison Member
May all of your blinks be without delay
View Profile
Your incomplete code makes it very difficult to help.
Once this command is executed is there any way of stopping the motor before it has done 4.5 revs ?
Code:
What do the parameters of the motor2.go function mean ?  You need to move the motor a little, check the switch, stop if at the limit else move the motor a little bit more and so on until the limit is reached or you have moved the complete distance.
Another question for you.  What should happen when swP1 is HIGH ?
Code:
At the moment your code does everything between { and } above.  Is that right ?
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
