Topic: Version 1.0.3 (Read 859 times) previous topic - next topic
tytower
Jan 20, 2013, 06:13 am Last Edit: Jan 20, 2013, 06:15 am by tytower Reason: 1
For Linux 32
This downloads OK and  the IDE compiles but has no menu for TOOLS->BOARDS so you cant change the board and there is no menu entry for TOOLS->PORTS  so you can't change the port
The "examples " and "sketchbook" don't come up either
Better than the 1.5. Version for the DUE . Its "arduino" script on download is 0 Bytes so you can't even start that !
tytower
#1
Jan 20, 2013, 08:11 am Last Edit: Jan 20, 2013, 08:13 am by tytower Reason: 1
OK in 1.0.3 itt seems the problems with Java version 7 persist.
Use version 1.6  with this and the menues come up as they should . You have to move to the next menu column and then come back and they magically appear ??
In 1.5 there needs to be a correction of the download so I can't fix that
