Topic: Newbie unable to make simple functiuon work ! (Read 830 times) previous topic - next topic
DavidFMarks
  Help please .I am new to this C programming and its driving me up the wall ! I am trying to use a function in a simple program to move a servo. I have checked out the use of functions on the arduino site and in four books and I still can't see what is wrong with the following code which produces the error message "VertEyes was not declared in this scope. I realise that I must be doing something stupid but none of the tutorials have so far enlightened me ! The code is as follows
[//Arduino Servo Test sketch
#include <Servo.h>
Servo VerticalEyes; // Define our Servo
   VerticalEyes.attach(10); //      connect servo to digital pin 10
int vpos=90;                 //define servo position as 90 degrees
VertEyes(vpos);             //call VertEyes function to move servo to vpos
int VertEyes(int vpos);                    // set up function VertEyes
VerticalEyes.write(vpos);               // move servo
SurferTim
Maybe if you remove that errant semicolon?
int VertEyes(int vpos)                    // set up function VertEyes
DavidFMarks
Aha ! Thanks for that. I hadn't registered the fact that there is no semicolon after a function declaration.. The bad news is that I still get the same error message when the semicolon is removed.
SurferTim
#include <Servo.h>
michinyon
Move the VertEyes() function above the loop() function.
So when the compiler gets to the call to VertEyes(vpos) inside loop(),  it knows what it is.
DavidFMarks
Thank a lot folks. My scarecrows eyes are now moving !!
UKHeliBob
What determines whether a function needs to be before loop() ?
I have never needed to do this, particularly as I prefer the loop() function to be near the top of the code where it is easily found.
In this case is it significant that VertEyes is defined as returning an int but doesn't return anything ?
PaulS
Nice of you to share that message.
Whether the function needs to be defined before loop(), or after, depends on the function arguments. The IDE is able to define function prototypes for functions in the same .ino file that do no use references. The function prototypes are not always positioned correctly, though.
The function prototypes allow for forward references - calling a function that has not yet been defined - because the compiler knows what the function will look like.
Whether the use has to explicitly define/position the function prototype(s) depends on whether the function uses references and whether the sketch uses conditional compilation. Neither appears to be true in this case, but the undisclosed error message would have told us a lot.
