Topic: Trying to use Arduino Uno R3 as ISP for ATTiny2313 (Read 6642 times) previous topic - next topic
gringle
Hm, thanks, but re-re-re-checked and checked again when you said it is wrong, I have no idea what might be wrong. It is wired excactly like it is described in the tutorial and I double checked with the picture also, just to be sure. The ATtiny2313 is not upside down. I don't know what to do different.
I guess the resistors would only prevent damage but not solve my problem, right?
Coding Badly
Right.
Quote
Post a picture.  Ensure everything is well lit.  Move the camera away and zoom to frame.  Try to make it about 800 x 600.
gringle
Here it is, thanks for having a look. I kind of hope to be embarrassed by you spotting the error right away.
Coding Badly
Perfect picture.  Very nicely done.
Huh.  Wiring looks fine to me.
Post the verbose output from avrdude with the target removed.  (I think it will fail with a timeout.)
gringle
I will do that this evening. I'm not sure what you mean by "target removed", though. Just without the ATtiny2313?
Erni
Another thing to try is moving the chip to another spot on the breadboard or another breadboard.
If have experienced bad contacts on one mine, althoug not shortycuts.
gringle
I was finally able to upload the Blink sketch to the ATtiny2313! I tried Ernis suggestion and moved it to a different breadboard and it worked right away. I feel kind of stupid for not thinking of trying that on my own.
Thanks so much for your help, guys.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
