Topic: GPS Sentence has unwanted characters in it... (Read 2137 times) previous topic - next topic
kuno86
i have a little Problem when i work with my GPS-Arduino by Aspen:
http://www.cutedigi.com/arduino/aspen-arduino-compatible-gps-and-li-poly-board-with-gps.html
I always have random "ÿ"-characters in my GPS-Sentences
Quote
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ$GPGÿGA,154135ÿ.000,5339.ÿ5503,N,013ÿ33.0733,E,ÿ1,06,3.0,1ÿ8.4,M,42.9ÿ,M,,0000*6ÿ6
$GPGSA,ÿA,3,10,13,ÿ23,04,07,0ÿ8,,,,,,,3ÿ.7,3.0,2.3ÿ*3D
$GPRMÿC,154135.0ÿ00,A,5339.ÿ5503,N,013ÿ33.0733,E,ÿ0.00,149.0ÿ6,190113,,ÿ,A*62
$GÿPVTG,149.0ÿ6,T,,M,0.0ÿ0,N,0.0,K,ÿA*07
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ$ÿGPGGA,1541ÿ36.000,533ÿ9.5503,N,0ÿ1333.0733,ÿE,1,06,3.0ÿ,18.4,M,42ÿ.9,M,,0000ÿ*65
$GPGÿSA,A,3,10,ÿ13,23,04,0ÿ7,08,,,,,,ÿ,3.7,3.0,2ÿ.3*3D
$GPÿGSV,3,1,12ÿ,10,75,239ÿ,37,07,65,ÿ163,36,13ÿ,53,075,35ÿ,02,36,263ÿ,27*77
$GÿPGSV,3,2,1ÿ2,08,35,19ÿ4,20,23,24ÿ,083,35,29ÿ,24,260,,0ÿ1,23,074,*ÿ7B
$GPGSÿV,3,3,12,0ÿ4,23,213,3ÿ1,05,16,03ÿ8,,26,08,2ÿ57,,24,03,ÿ336,*7B
$ÿGPRMC,1541ÿ36.000,A,5ÿ339.5503,ÿN,01333.07ÿ33,E,0.00,ÿ149.06,190ÿ113,,,A*61ÿ
$GPVTG,1ÿ49.06,T,,Mÿ,0.00,N,0.ÿ0,K,A*07
I want to use the GPRMC-Line which looks fine after all the "ÿ" are filtered out:
Quote
$GPRMC , 154132.000 , A , 5339.5503 , N , 01333.0733 , E , 0.00 , 149.06 , 190113,,,A*65
Since the GPS-Output has this stupid extra-characters, the tinyGPS-Library dosen't work with it :(
What would be a good way to fix this ?
I already filtered the incoming characters from the serial-connection, but then i fail on the task of doing tinyGPS's job...
wildbill
That y umlaut is most likely the way your serial monitor renders 255 (-1). It's what the serial read command returns when there is nothing to read. Use serial.available to check that there is actually something to read before you do so.
kuno86
Thanks a lot wildbill.
Now all the "ÿ" are gone  :)
WinstonP
Now see!!!! that's useful information and direct without a lot of "fluff" with it.
I THANK you also :smiley-mr-green:
