Topic: BMP085 Barometric Pressure/Temperature/Altitude Sensor and 433Mhz RF link kit (Read 9784 times) previous topic - next topic
jtcartrite
I'm new to programming and the arduino, but I finally got the BMP085 to transfer data using the 433 Mhz RF so that I can print to Serial, LCD or other display. I'm posting my code here because it took me a few frustrating nights to figure out how to transfer the data. If you have any suggestions to the code please feel free to comment. All I ask is to please remember that I am new to this, but I am a fast learner. Thanks for your time and I hope that this will help someone else out.
I used:
Arduino Uno
Seeedstudio Bluetooth Bee (This wouldn't ever be my first choice for debugging but I bought it for a future project. I just have to learn how to program some apps for it. You do need to pay attention to the Virtual Wire library for the TX/RX pins. Thankfully I read about that before I started)
BMP085 Barometric Pressure/Temperature/Altitude Sensor http://www.adafruit.com/products/391
433Mhz RF link kit http://www.seeedstudio.com/depot/433mhz-rf-link-kit-p-127.html?cPath=139
This is the Transmitter Code:
Code: [Select]
#include <VirtualWire.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
Adafruit_BMP085 bmp;
int LED = A0; //LED to blink when transmitting
int numbers[6]; //Number of variables to send out
  Serial.println("Setup");
  pinMode(LED,OUTPUT);
  bmp.begin();
  if (!bmp.begin())
    Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    while (1)
  vw_set_ptt_inverted(true); // Required for DR3100
  vw_setup(1000); // Bits per sec
  //vw_set_tx_pin(6); // pin 6 is used as the transmit data out into the TX Link module, change this to suit your needs.
    //----------------------------Taking Readings from BMP085---------------------------------------------------
    float temp = bmp.readTemperature(); //Read Temperature in Celcius
    int temp1 = (int)temp; //Read Temperature digits on the left of the decimal place
    int temp2 = (int)((temp - temp1) * 100.0); //Read Temperature digits on the right of the decimal place
    float temp = (bmp.readTemperature() * 9.0 / 5.0 + 32); //Read Temperature and convert to fahrenheit
    /* Altitude with no correction
    // you can get a more precise measurement of altitude
    // if you know the current sea level pressure which will
    // vary with weather and such. If it is 1015 millibars
    // that is equal to 101500 Pascals.
    float alt = bmp.readAltitude();  //Read Altitude with no correction
    int alt1 = (int)alt; //Read Altitude digits on the left of the decimal place
    int alt2 = (int)((alt - alt1) * 100.0); //Read Altitude digits on the right of the decimal place
    //Remove the " * 3.280839895" for units in meters
    float alt = bmp.readAltitude(103149) * 3.280839895; //Read Altitude with correction
    //Remove the " * 0.0002952998751" fro units in pascal
    float bar = bmp.readPressure() * 0.0002952998751; //Read Barometric Pressure
    int bar1 = (int)bar; //Read Altitude digits on the left of the decimal place
    int bar2 = (int)((bar - bar1) * 100.0); //Read Altitude digits on the right of the decimal place
    //-------------------------------End of Readings from BMP085------------------------------------------------
    //-------------------------------Debugging---------------------------------------------------
    Serial.print ("Temperature= "); //Print Temperature
    Serial.print (temp1); //Print Temperature digits on the left of the decimal place
    Serial.print ("."); //Print decimal
    Serial.print (temp2); //Print Temperature digits on the right of the decimal place
    Serial.println (" *F"); //Print degrees in fahrenheit, Change to C for Celcius
    Serial.print ("Altitude="); //Print Altitude
    Serial.print (alt1); //Print Altitude digits on the left of the decimal place
    Serial.print (alt2); //Print Altitude digits on the right of the decimal place
    Serial.println (" meters"); //Print unit of measure
    Serial.print ("Altitude= "); //Print Altitude
    //Serial.println (" meters"); //Print unit of measure
    Serial.println (" ft"); //Print unit of measure
    Serial.print ("Barometric Pressure= "); //Print Barometric Pressure
    Serial.print (bar1); //Print Barometric Pressure digits on the left of the decimal place
    Serial.print (bar2); //Print Barometric Pressure digits on the left of the decimal place
    //Serial.println (" Pa"); //Print unit of measure
    Serial.println (" inHg"); //Print unit of measure
    //----------------------------------End of Debugging-------------------------------------------
    digitalWrite(LED, HIGH); //Turn on LED when transmitting
    numbers[0] = temp1; //Temperature digits on the left of the decimal place
    numbers[1] = temp2; //Temperature digits on the right of the decimal place
    numbers[2] = alt1; //Altitude digits on the left of the decimal place
    numbers[3] = alt2; //Altitude digits on the right of the decimal place
    numbers[4] = bar1; //Barometric Pressure
    numbers[5] = bar2; //Barometric Pressure
    vw_send( (uint8_t *)numbers, sizeof(numbers));
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(LED, LOW); //Turn off LED when transmitting
This is the Receiver Code:
Code: [Select]
int LED = 13;
int numbers[6];
 pinMode(LED, OUTPUT);
 vw_rx_start(); // Start the receiver PLL running
 //vw_set_rx_pin(5); //pin 5 is used as the RX pin
 uint8_t buf[VW_MAX_MESSAGE_LEN];
 uint8_t buflen = VW_MAX_MESSAGE_LEN;
 if (vw_get_message(buf, &buflen)) // Non-blocking
   //------------------Debugging---------------------
   Serial.print(buflen, DEC);
   Serial.println(" bytes received!");
   //------------------Debugging----------------------
   for (int i = 0; i < buflen; i++)
     //-------------------Debugging-------------------
     Serial.print("buf[");
     Serial.print(i, DEC);
     Serial.print("]=");
     Serial.print(buf[i], DEC);
     Serial.print("  ");
   Serial.println(); //For Debugging
   //memcpy(buf, numbers, buflen);
   for (int i = 0; i < 6; i++) //If you add more integers you have to change the 6 to how many intergers you have.
     numbers[i] = word(buf[i*2+1], buf[i*2]);
     Serial.print("numbers[");
     Serial.print("]=");
     Serial.print(numbers[i], DEC);
     Serial.print("  ");
   Serial.print("Temperature= ");
   Serial.print(numbers[0], DEC);
   Serial.print(".");
   Serial.print(numbers[1], DEC);
   Serial.println(" *F");
   Serial.print("Altitude= ");
   Serial.print(numbers[2], DEC);
   Serial.print(".");
   Serial.print(numbers[3], DEC);
   //Serial.println(" meters");
   Serial.println(" feet");
   Serial.print("Barometric Pressure= ");
   Serial.print(numbers[4], DEC);
   Serial.print(".");
   Serial.print(numbers[5], DEC);
   //Serial.println(" Pa");
   Serial.println(" inHg");
Krodal
Well done.
You say that you are new to programming, but it looks very good.
Good indents, lots of comments.
Also you choice for VirtualWire and Adafruit code is a very good choice.
Do you use 5V or 12V for the transmitter ?
If you really want to improve the code, there is a small detail. If you use this:
Code: [Select]
Serial.println("Hello"); The string "Hello" is in ram is copied from flash memory during startup (I think, I'm not sure). But you can set the string only in flash memory with the 'F()' macro:
Code: [Select]
Serial.println(F("Hello"));.
jtcartrite
For now I'm only using 5 volts. I will be using 12 volts for the final assembly.
Thank you for the comments. I will look that up on the flash memory.
I took an online java class and the instructor said to be very thorough when writing a program so you can go back and change it easily.
Krodal
If only every programmer would have such an instructor, we would have less software problems, less security leaks and so on.
