Topic: DigitalRead always gets me HIGH (Read 780 times) previous topic - next topic
vima
Hello I am using this simple code that I have used so many times before:
const int buttonSwitchA=9;
Serial.begin (57600);
pinMode(buttonSwitchA, INPUT);
  buttonStateA=digitalRead(buttonSwitchA);
  if (buttonStateA==HIGH) {
    Serial.println("printing");
I have a switch in my breadboard. One pin is in the 5V and the other is my "free" pin. My switch works fine because I checked with  using a voltometer, when i press the switch and measured voltage the free pin. (basiccally i do not know how to explain this but I used that mode when there is path, you hear the beep sound. When switch is pressed sound is heard, otherwise not).
So my switch works.
When i plug in the free pin in the arduino input 9, it always read HIGH and prints the message. I tried wit other inputs but still nothing.
Is it a problem of code or what should I checked?
Grumpy_Mike
You can not leave a pin unconnected, you need a pull up or pull down.
Please read:-
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
vima
#2
Jan 20, 2013, 06:59 pm Last Edit: Jan 20, 2013, 07:10 pm by vima Reason: 1
Please read:-
Thanks man! That was it!
