Topic: Measuring Amperage (Read 3338 times) previous topic - next topic
Drew Davis
Hello, I'm using some motors that I pulled out of an old printer and I don't know how many volts or amps they need. How would I find this out? Is their any equipment I could buy that I could use to test the Motors with?
Thanks,
Drew Davis
Drew Davis
Also, they have no markings or model numbers.
dc42
You can measure the winding resistance with a multimeter, and from that calculate the maximum current they will take at a given voltage. You could try driving them at 5V, but they very likely need 12V, perhaps even more.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
Drew Davis
krupski
Huh??? The winding resistance has absolutely no correlation to the voltage or current a motor requires!
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
MarkT
If you know the resistance of the winding and the size of motor (which correlates with power dissipation) you can make
an informed guess.  Many electric motors are limited by thermal considerations.
Drew Davis
This is the multimeter I haveā€¦  http://www.sears.com/craftsman-digital-multimeter-with-ac-voltage-detector/p-03482146000P?prdNo=1&blockNo=1&blockType=G1
What selection do I need to put it on to get the winding voltage, or if thats not the best way to find the amperage/voltage of the motors how would I find it out?
Also, what is winding voltage?
Thanks,
Drew Davis
James C4S
The motors must be powered to measure the "winding voltage."
Measuring Current requires you to "break the circuit" and measure current in-line with a power source.
The intended operational voltage of the windings inside the motor.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
krupski
The DC resistance of a permanent magnet motor will be very low. The resistance IN NO WAY correlates to it's operating parameters. Not even close enough to make an "informed guess".
Do you not know how motors work?
JimboZA
My experience with printers is that printer motors are almost always steppers, so that the paper and the optics can be positioned within the required tolerances
Post a pic...
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
majenko
Post a pic...
Are you living in the 90's?  I haven't seen a stepper in a printer since old dot matrix printers.  Certainly all the inkjets I have worked with over the past 5 years or so have been normal motors, not steppers.
JimboZA
Well I joined Xerox in the 80s....
But I did just take our immediately past printer at home to pieces, and it had a bunch of steppers in it; it wasn't that old. That was iirc a Lexmark laser printer, copier, fax, scanner, liquidiser, blender etc.
majenko
Ah, it'll need the stepper for the blender.
Lasers do sometimes have steppers, yes, but there are 10000x more inkjets around, so chances are it's an inkjet
Drew Davis
I don't think it is a stepper motor, but I have never really seen one. It just has two wires and it comes from the part of the printer that goes back and forth applying ink to the paper. I can't figure out how to post a picture, but i'm pretty sure it is just a regular dc motor.
Thanks!!!
majenko
Thanks!!!
Yes, that will be normal DC, and either 12 or 24 volts - probably 12, but without markings it's pretty hard to tell.
A stepper motor has more than two wires.
